Question about NEC Versa Gold Submersible Pump
I have versa gold submersible pump, it works intermittently. There is enough water in the pond and it is submerged
  • 21 Answers
Intermittent running usually points to intake or impeller obstruction. Remove the impeller screen and cover, inspect the impeller, the screen the discharge exit point for debris. Unlike other brands the impeller is not replaceable if worn or damaged.
Posted on Mar 05, 2009
Running pump stopped
I assume that the plug in is working properly. Always check power supply first. Is there a GFCI circuit that it is plugged into. Then check the pump to make certain it us turning. How long had it been on before unplugging it. It could be worn out. Sometimes it takes a jolt to start the motor again. How big is the motor. Possible bad capacitor. Could be a solid state motor, then it's bad. Is it a magnetic motor, that could be turning the wrong way.
May 16, 2014 | NEC Versa Gold Submersible Pump
My little giant pumps intermittently and its the second one i had do this!
water being pumped have high solids content ? , get sample in clear glass let set overnight look at bottom closely , Lots of stuff settle down there ? if so your gonna need a filter of sorts to remove solids before pump gets a hold of it
Oct 17, 2012 | Little Giant 5-MSP Water Wizard...
Pump works for about 20 seconds then stops for 40 seconds then starts again.
this sounds as if motor is overheating and the thermal switch is stopping it (why it restarts by itself) if a pump is overheating then a few reasons need be looked at , is pump encountering higher viscosity's than designed for and is having trouble moving liquid fast enough , is distance pump has to lift liquid over what it's designed to do most of these pumps use liquid it's moving to provide cooling to pump , is liquid it's moving warm/Hot allready if so use different type of pump (non submerged) and last but not least is pump worn out and is failing moving parts wearing together make heat !!! ?
Jun 27, 2010 | Little Giant Submersible Fountain Pump
I have a submersible water pump It seems to suck ...
That is pretty much par for the course with a submersible pump. Eventually the pump will be damaged by running dry as it depends on the water to keep it cool. Can't you set it up a little on something so it won't **** dirt?
May 20, 2010 | Garden
My Simer 2300-03 has been great except that it overheats after awhile. Too little water??
Yes. I recently used a similar pump (Flotech 1/6 hp) running for about 24 hours - but it came with this warning "don't use continuously unless submerged in at least 4 inches of water". This is because it will easily overheat, as yours has been doing. Mine worked for pumping water out of my basement (not the speediest little pump), but only because there is a sump hole in the floor where the pump could remain submerged.
Mar 31, 2010 | Simer 1/6 Hp Submersible Utility Pump
I have a 1 month old Model FPOS1775A Flotec pump. The discharge hose is 3/4 inch with a level run of 20ft.It pumps water but only at 2 and a half minute intervals even when fully submerged!!! I now have a...
If the pump is only pumping for a few seconds at a time it may be a problem with the control board. On two of mine, the 10mf 100v smd capacitor came loose. Resoldered and potted with hot melt glue. One of them is working with the other yet to be tested. Don't recall what the exact symptoms were, only that it wasn't continuously pumping water while submerged.
Unit is oil filled so should be dismantled in the upright position.
Feb 23, 2010 | Flotec 1/4 Horsepower Sink Pump System
Pond pump types
There are basically two types of pond pumps to choose from - externally mounted and submersible. External pumps were traditionally used in water gardens. They sit outside the pond, with a hose that leads from a strainer in the pond to the pump. From there the water is forced either to a waterfall, stream or fountain. Because external pond pumps are often noisy and require extra plumbing, they are usually not suited for most backyard ponds. Due to easier accessibility and ease of repair, however, external water pumps are often the best choice for larger water gardens and public installations. Submersible water pumps are usually preferred by most do-it-yourselfers. They sit underwater where they are quiet and unseen. These pumps are easy to install, require no priming and stay cool thanks to the surrounding water. Submersible pumps draw water from the bottom of the pond, either through a strainer or biological filter. A hose attached to the outlet then feeds water to whichever water feature you have installed.
Aug 27, 2008 | Little Giant Opwg 71 71 Gpm Out of Pond...
NEC Versa Gold Submersible Pump Logo
395 people viewed this question
Top NEC Garden Experts
Dennis Key
Dennis Key
roeb
john h
Are you a NEC Garden Expert? Answer questions, earn points and help others
