Question about Delta Electronics SADP65KB B 65W 19V 342A Notebook AC Adapter (Black)
I need a circuit sadp-65kb b used for repair
I burned down the charger and I would like to fix it myself. For self-development.
My battery back up keeps turning it's self off
Sounds like a battery that has developed memory from not getting charged all the way may be the charger it may need replaced and if so you will probley have to replace the battery pack also hope this helps
Apr 15, 2017 | Miscellaneous
Xerox 3030 (engineering copier)-- "Toner Fault. Call for assistance" is on the little display screen. Can I easily fix this myself?
I expect you've probably got this fixed by now? In my experience people who own these machines want them working all the time. This error code problem can be over concentrated or under concentrated developer. Possibly needs developer changing, or the DEV sensor could be U/S. Good luck.
Dec 05, 2014 | Xerox Office Equipment & Supplies
Charger not working
it did u plug the charger into a different outlet
Aug 13, 2014 | Cell Phones
My charger plug broke off my charger cord and is stuck in the port of my tablet.How do I fix it myself?
The only way i know of is to take off the back casing and look at where the the charger port is and you might be able to remove it with an object a little bit bigger than the end of the charger. otherwise you cant do it your self withput messing something up on the tablet.
Jun 05, 2014 | Nextbook Premium 8 Se Android
Cigarette lighter on 2007 dodge caravan burns out cell phone chargers
hey ronkardos,
did you find a solution? My caravan started developing similar issue.
Jan 08, 2012 | 2007 Dodge Caravan SXT Minivan New Cars
My Mozilla Firefox is not working well it crash when am using it most time and l cant download from my YouTube with it how can l fix this my self?
Its a glitch with the latest release, had the same problems myself. I'd suggest deleting it from your system, then downloading the latest version and seeing if it happens again.
Mar 26, 2011 | iTEKIRO Replacement Laptop AC Power...
Nokia N73 not charging. There is no issue with battery as it is working in other cell phone. I have also tried different chargers. The problem seems to be with point where the pin is inserted.
hello,
this means that your phone have develop charging port problem, that is the charging port is bad
what you have to do is to replace it with another that is of good condition
you can do the fixing your self if you have the tools to unscrew phones get a new charging port from the store unscrew your phone remove the bad month pics and fix in the new one you but from the store
note if you can't do it your self take it to a very good phone work shop around you to do the fixing for you then you will be able to charge your phone from it own charging port again.
thank you and thanks for using fixya.
Mar 29, 2010 | Nokia N73 Cellular Phone
Moisture developing between the glass on the ovendoor
when the oven comes new ,,you must burn the coating of for about an hour..a form of food grade rust proofing..let unit bake at 400 for 55 to 65 minutes empty
Dec 24, 2008 | Frigidaire 30" Self-Cleaning Freestanding...
Delta Electronics SADP65KB B 65W 19V 342A Notebook AC Adapter (Black) Logo
Top Delta Computers & Internet Experts
john h
Andrew Taylor
Andrew Taylor
Are you a Delta Computer and Internet Expert? Answer questions, earn points and help others
