Question about Sony Cyber-shot DSC-W55 Digital Camera
I start the camera, it does not open,
The screen is showing "turn the power off and on again"...bathey is full,
  • Sony Master
  • 586 Answers
  This error cause when the main board starts malfunctioning. Therefore you have to change the main board. Which is called BD board.For your convenience please visit:
www.sony.net
or
www.sonyworld.com
Here you can find contact info of nearest service centres.
Thanks for using FIXYA.
Posted on Jan 31, 2009
How di I reset my Pixma printer MP150 from
Use this method with your own risk!!
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 The connected digital camera / video camera does not support Camera
Direct Printing
E14 The Ink cartridges whose destination are wrong
E15 Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 Failed to scan head alignment sheet
E22 Carriage error
E23 Paper feed error
E24 Purge unit error
E25 ASF(cam) sensor error
E26 Internal temperature rise error
E27 Waste ink absorber full or platen waste ink absorber full
E28 Ink cartridge temperature rise error -
E29 EEPROM error
E33 Paper feed position error
E35 15 USB Host VBUD overcurrent error - USB
E37 17 Abnormal motor driver error
E40 20 Other hardware error
E42 22 Scanner error
Reset E27 Waste ink absorber full or platen waste ink absorber full
First way
turn off printer.
- put your finger and hold on/off with reset/stop button together
- turn on printer power switch
- release on/off button but in the same time still hold stop/reset button and then press on/off button again and hold.
- wait at the moment
- relese stop/reset button 2X.( your will see alarm led blingking for 2X)
- relese on/off button.
wait until your printer digital screen shows number 0.
- after printer panel screen shows number 0.
- press reset button 4x
- press on/off button 1x
wait until your hear printer roller is moving
after your hear roller moving, wait until your dont hear anything from your printer :)
then turn off and turn on your printer again and your will see your printer back to normal.
Second Way
turn off printer.
Good Luck
Jul 18, 2010 | Canon Office Equipment & Supplies
Showing turn the power off and on again.
Error: TURN THE POWER OFF AND ON AGAIN is displayed on the LCD screen when the Lens Mechanism is stuck or when affected by any malfunction. If turning the power on and off again does not resolve the error message, try doing a power reset and Initialize option.
Performing a manual power reset
Turn off the camera.
Remove the battery pack.
Press and hold the power button for 30 seconds.
Allow the camera to remain without power for 60 seconds.
Reinsert the battery pack.
Turn on the camera.
To reset the Camera back to factory default, select the INITIALIZE Option from the Main Settings 1 Menu under Settings Menu of the Camera to OK. This will set the user defined settings back to factory default. The images and videos will not get deleted.
If the issue persists, service may be required.
Thanks,
KenSolutions
FixYa
Oct 19, 2009 | Sony Cyber-shot DSC-W110 Digital Camera
No picture on screen after 1 second
Try this. Go to your tools menu, look for something like power saver or display off and change the duration that the screen stays on.
Jul 08, 2009 | Samsung Digimax S500 Digital Camera
Camera will not turn on sucessfully. Says "Turn Off and On Again"
This is not an elegant solution, but it seems to be working. (I might have read some one else mentioning it for another brand of Samsung camera). I hit the end of the camera where the attachment to the computer gets plugged in against the palm of my hand pretty hard about 6 times. Then I tried it and it worked! There is some logic there since it started having the problem right after I put it down on a soft surface from about three feet.(Ididn't really drop it, but tossed it there - gently, I thought - because my hands were full and I was starting to lose everything). In the future I will treat the camera a little more gently knowing that mechanism is somewhat easily knocked out of adjustment.
Mar 26, 2009 | Samsung L77 Digital Camera
When turn camera on lens opens and close
there is a friction in the movement of the lense assembly. It is not reaching to its proper position. This happens if you drop the camera, or the camera is exposed to sand. a repair technician can fix it.
Mar 21, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Olympus Stylus 710 Error: D: 5f08 5f0a 5e02 5f08
i have the same problem with my camera it show 5foa 5f08 5e02 with the blue screen
Sep 24, 2008 | Olympus Stylus 710 Digital Camera
Sony Camera DSC-W30
Shoot 10-15 times hard thats all..
Jun 08, 2008 | Sony Cyber-shot DSC-W30 Digital Camera
My memory card says full!
Try opening your My Computer screen, connect the camera to the computer and watch for the new removable disk to show up. Depending on the camera there may be two that show up. Right click on the removable disk/disks and choose format, click start and click okay. This should fully reformat the memory and you'll be able to take pictures again.
May 26, 2008 | Fuji FinePix A360 Digital Camera
Screen shows only 'Access'
You have probably dropped the camera. If you are brave enough to open the camera up you can put the rollers back on track. Not a difficult problem to solve.
Oct 17, 2006 | Sony Cyber-Shot DSC-P93 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
56 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
Are you a Sony Camera Expert? Answer questions, earn points and help others
