Question about Mitsubishi WS-65807 65" Rear Projection Television
Volume goes up on it's own
When watching TV, the volume suddendly increased to over 60. I could not turn the volume down or turn the TV off with the remote. I manually turned off the TV and waited for a few seconds, when I turned the TV back on, the volume was still high. I turned it off again and unplugged it and let it sit for a few minutes. I turned it on and it is fine. This is the second time it has happend in the last week. The TV is 4 years old. Is this an indicator that it is going to completely break down?
Replace front switches
Posted on Jul 14, 2007
SOURCE:
Tv volume goes down
Try a (hard) factory reset
Dec 13, 2017 | Televison & Video
TV volume increases by itself and doesn't decrease or respond to the remote control
Connect all A / V sources to the Home Theater Receiver then Video-Out from the receiver and totally mute) the TV.
Sep 30, 2008 | Soyo DYLT032D 32 in. LCD Television
I have a constant ringing sound coming from the tv. It goes up and down as I increase or lower the volume by remote. As I change the audio option to "Spanish", regular "English" audio comes out on c
The fact it shows on tuner and not DVD means not likely a audio problem--check all audio settings in the set's menu AND if you are using a box for signal look there--has to be a setting.
Some JVC sets (brand indicated here) also had issues with when watching the background audio (like a sporting event) was louder than the people talking and could be interpreted as ringing--This is a setting in the set called something like "Theater" or "Hall"
Has to almost certainly be a setting in the set.
Mar 28, 2012 | JVC Televison & Video
Volume automatically goes to maximum on TCL TV
The volume (+) button on the TV is stuck or soiled if the volume automatically increases when the TV is turned on. To find out:
  1. Turn off the TV.
  2. Press and hold the volume (-) button on the TV then turn it on.
  3. If the volume doesn't automatically increase, you have a stuck button.
  4. If it does increase, you have a faulty key control board.
  5. In either case, you have to replace the key control board.
To find it out further:
Warning: Beware of electric shock.Please do not proceed if you do not have the skill to do the following.
  1. Unplug the TV.
  2. Let it stand for 15 minutes to allow voltages to drain completely to avoid the risk of electric shock.
  3. Remove the screws securing the TV's back cover and pull it off.
  4. Disconnect the cable that runs from the main board to the control key board.
  5. Turn the TV on using the remote.
  6. In this manner you can use the remote control to run the TV while waiting for the control key replacement board.
To do a hard reset of the TV, unplug it and let it sit for 2 hours or long enough to completely drain the internal voltages.
Nov 20, 2009 | Televison & Video
Volume turns up or down on its own
yes direct into the buttons the WD40 is the best thing i've ever seen, that will not damage anything you can spray it without fear and then try to activate the buttons a few times, of course with the tv off.
May 20, 2009 | Akai PDP4294 42 in. EDTV-Ready Plasma...
Sharp Aquos LC-26D4OU HDTV volume adjustment problems
If you use a digital cable box, it could be that the volume on that isn't turned up all the way. I didn't even realize the box had volume controls until 2 years after I got it...makes a HUGE difference now
Jun 14, 2008 | Sharp LC-26D43U Television
Hi, I have a samsung le32r74bdx lcd tv and the volume has just gone to 100 and i can't turn it down?
First, start by unplugging set to try to reset. Then make sure that all settings in audio menu are correct. Also look for stuck volume up button on set and on remote. Sometimes buttons get lodged under surrounding frame. Also try to push volume down button on tv and watch for display on tv to see any change. If when you release button volume increases by itself, remove batteries from remote to eliminate it as cause. If nothing you try works expect to replace main pcb. You can probably price it online with model number. Good luck, Russmann.
Jun 09, 2008 | Samsung Televison & Video
Volume lowers
replace digital board. A hardware update is available that might solve it.
Feb 12, 2008 | Zenith E44W46LCD 44" Rear Projection...
Tv volume goes down of its own accord
Some dust in the button to lower the volume on your TV or on your remote control might be causing it to think it's being pressed. Try playing around with it, pressing it hard so as to relieve it of any pressure on the inside.
Jan 09, 2008 | Televison & Video
TV WILL NOT TURN ON
i HAVE THE SAME TV, SEEMS LIKE THE LAMP IS OUT. BUT ONLY TWO YEARS USE? WOW. iVE HAD MINE FOR 3 YEARS WITH ATLEAST 6 HOURS PER DAY USE. WELL GOOD LUCK AND DONT LET A TECHNICIAN CHARGE YOU 200 FOR LABOR TO TAKE OUT A FEW SCREWS
Dec 17, 2007 | LG 52SX4D 52" HDTV
Open Questions:
See all Mitsubishi WS-65807 65" Rear Projection Television Questions
Mitsubishi WS-65807 65" Rear Projection Television Logo
155 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
