Question about Savin Copier Supplies; Toner for 2535/2535P/2545/2545P, Black
SC863 savin 2535
I have code sc863-06 what do i do
SC 863-06 means HDD data read failure. Internal HDD of your unit might be faulty cause by a bad sector. On/off the machine might help a bit but sometimes HDD is in very bad condition you need to contact your tech. to check your unit. HDD should be reformat but only tech. can help you to reconfigure it back properly.
Dec 02, 2015 | Ricoh Aficio Office Equipment & Supplies
Double Sided Copies on Savin 2535
The image shows a flat page with a 1, arrows to an image of a sheet with the lower right corner turned up with a 2 on it. On a Ricoh, just remember that the first image is the input and the second is the output.
Feb 06, 2014 | Savin Office Equipment & Supplies
Password for User Tools
Go to www.savin.com (I used savin because the 1035 is the same as a 2535 or B003), go to downloads, select manuals, select B/W Digital and 2535/2545, select the System Settings manual, download it and on page 48 it tells you how to lock out the Key Operator settings.
Jul 28, 2009 | Ricoh Aficio 1035 Copier
Savin 4035Esp - Functional Problem Message with Code SC863
Hello sir; SC 863 means your copier hard drive not good,you need to replace one. can't repair.
May 15, 2009 | Ricoh Office Equipment & Supplies
SC863
SC-863
DESCRIPTION
The data stored in the HDD
cannot be read correctly.
Bad sector detected during
operation of the HDD
POSSIBLE CAUSES
Defective HDD
Defective controller
POSSIBLE SOLUTIONS
1. Reformat the HDD.
2. Replace the HDD when SC863
occurs more than ten times or it
takes more than twenty seconds
to get ready condition.
3. Replace the controller board.
Apr 03, 2009 | Office Equipment & Supplies
Sc 322 error
Troubleshooting a laser is a lot of work. You're better off getting a tech that can do it safely and correctly. That error code has to do with the motor.
Aug 21, 2008 | Office Equipment & Supplies
Savin Copier Supplies; Toner for 2535/2535P/2545/2545P, Black Logo
Top Savin Office Equipment & Supplies Experts
CheckitRight
CheckitRight
George Mclaughlin
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Savin Office Equipment and Supply Expert? Answer questions, earn points and help others
