Question about Whirlpool Duet GHW9150P Front Load Washer
The door is open and the door lock is stuck in locked position
The door lock on our washing machine would not lock.  I tried applying wd40 the the lock and moving it back and forth then it locked with the door open.  Now I cannot get it to open.
Found this at http://applianceguru.com/forum2/7688.html ... take off the bottom front panel below the door ... 3 screws ... then reach up under where the door lock is ... there is a round tab that hangs down ... pull it and it releases the door lock.
Posted on Feb 03, 2009
  • Whirlpool Master
  • 3,463 Answers
With the power off, push a screw driver or similar in the aperture of the door lock, and push it from side to side, this should release the door lock, if it does not, then you will need a new door lock fitting.
Plz rate my solution.
Thanks.
Posted on Jan 25, 2009
Washing machine had a door closing and opening problem, i thought i fixed it with a squirt of good old wd40 door now operates fine, but washing machine just hums and clicks now. o gosh what have idon
The WD40 should not have done any harm, unfortunately the faults with the door lock cannon be fixed with CRC, You will need to replace the door lock assembly and hopefully the machine will resume normal operation.
Apr 03, 2017 | Beko Washing Machines
The door on my kenmore front loading washing machine is open but the lock is stuck in the on position
Turn off the electric to the dryer,the lock should open,close the door and turn electric back on, make sure the lock's not obstructed
Nov 13, 2014 | Kenmore Washing Machines
W6444 washing machine door won't close
Try some WD40 spray on the door and lock. Just a bit. Try closing and opening the door. The machine should be in the <off> position.
Mar 16, 2013 | Asko W6021 Front Load Washer
Door will not open at end of cycle
Possible that the safety link to the end cycle is not released. So check from the bottom to see the lock settings and check if the release link is stuck or the lock by itself is jammed.
Use a good degreasing spray like WD40 to remove any jamming in the door.Once released use the spray to wash off all dirt or foreign material from the lock setttings. The open and shut a number of times to clear the lock movement.
Sep 01, 2010 | Creda W100FW Front Load Washer
Gallery washing machine door latch stuck in lock position
I have the same problem with my Gallery. I can not open it at all. I have tried unpluging it and putting it through another cycle to see if it will open. No such luck. Any suggestions?
May 19, 2010 | Frigidaire ATF6000ES Front Load Washer
Whirlpool duet washer door is open. I can't close it because the latch is stuck in the "locked" position.
The first thing to try is to hold the cancel button for 15 seconds. The more labor intensive solution is this: Remove the panel beneath the door (2 or 3 screws). Reach up, there is a little "ring" beneath the door lock. Pull this down, it releases the mechanism.
May 03, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet Washer GHW9150PW1
Swich off the machine, try some WD40 on the door mechanism (on machine lock, not on the door) and open & shut for a minute or two. Then try the machine, spin only just to try.
Rate pl, if solved, or dont!
Mar 04, 2009 | Whirlpool GHW9150 Front Load Washer
Door lock
Switch off. Try some WD40 on the machine lock (not on door) and open & close door many times, to ease out the lock.
Jan 28, 2009 | Hotpoint WMA54 Front Load Washer
Washing machine dooe lock
Try some WD40 on the machine door mechanism, not on the door; & open/close the door while the machine switch is off.
Apr 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Ghw 9150 lock mechanism problem
lock; on machine, not on door. And open & close for a few times with the power off.
Oct 14, 2007 | Whirlpool GHW9150 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
364 people viewed this question
Dan Webster
Dan Webster
Sal De
