Question about Kenmore 43142 Front Load Washer
Kenmore 45986 door lock
Front loader door lock has locked with door open, and will not release, door lock light is not on.
  • harpo503 Feb 06, 2009
    My door will not lock into place so that the cycle can start. I don't know if the door is already locked and just will not release or if the locking mechanism is not functioning in order to begin the cycle.
  • agentblanco Feb 20, 2009
    The washer door will not lock when closed and the start button is pressed.
  • 15,935 Answers
This advice is for Kenmore Elite and Whirlpool Duet model front loading washers. If you experience a problem where the door becomes jammed and will not unlock or open, here's an easy way to gain access inside your washer WITHOUT calling the repairman.
1. Remove the lower panel under the door by loosening the three screws under the bottom edge on the front of the washer. HINT: If you prop up the front feet of the washer with some small blocks of wood, this will make access to the screws much easier.
2. With the screws removed, the lower panel should drop down then come off. If the panel sticks, a light tap on either side will knock it loose.
3. Reach your hand up inside the washer behind the front casing on the right-hand side. This is where the door latch assembly is located.
4. At the bottom of the door latch assembly is a small pull tab. This is the manual release for the door. Pull the tab straight down and the door will come open.
Sometimes these doors will not unlock for whatever reason. If there are no error codes being generated, this could have just been a momentary glitch. If you see "Fdl" "DLE" or "Fdu" error codes, these are usually indications of a failed door latch assembly and will require replacement.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 12, 2010
Light flashing won start
Common error with front loaders is the door interlock. Make sure the door is positively closed. A gentle open hand push at the erea of the door lock often gets a machine started.
Jan 30, 2014 | Kenmore Elite 45986 Front Load Washer
The door is locked and won't open; how do i unlock it manually?
unplug it,remove the bottom panel,stick your hand up where the door lock assy. is and on the bottom of the door lock assy. there is a plastic wire that releases the door manually,grab it and pull down and the door will release.
Jul 10, 2011 | Kenmore Elite 45986 Front Load Washer
Kenmore elite he washer lock light. cannot open
You can manually Unlock the door Lock System
1. Unplug washer or disconnect power.
2. Remove the lower kick panel.
3. Reach up along the inside of the front and locate the bottom of the door switch/lock unit.
4. Located on the bottom of the door switch/lock unit is a tear-drop shaped tab.
5. Gently pull the tab down about a ¼" or until a click is heard.
6. The door may be opened.
Thank you !!
May 31, 2010 | Kenmore Elite 45986 Front Load Washer
Door won't open
the lock switch is probably stuck. make sure machine is off but plugged in still. Push in on the door while gently giving a couple of thumps around the lock area and the lock will probably "click" open.
Aug 16, 2009 | Kenmore Elite 45986 Front Load Washer
How do you open a locked kenmore elite front loader door after the power/motor is broken
You can use the manual release to open the door. The following link explains:
If you have any questions about this repair, or if you need additional assistance, please let me know. I hope this helps you.
Jul 18, 2009 | Kenmore Elite 45986 Front Load Washer
Kenmore front load washer shows door not locked but the door is locked and will not unlock. it will not start either.
Try pressing 'end of cycle' for 3 seconds. You hear a click? Then wait for 2 minutes before trying the door, do not force door. No luck? Plug off the mains. Tilt machine backwards to unscrew 3 screws below the front panel, the kick panel. Slide the panel downwards & out.
Put your hand up towards the lock portion (inside the machine that is), you will feel a tear shaped thing, pull this thing a quarter of an inch down, the door will click open. Check to see that all wires are connected well.
Next try some WD40 on the door mechanism on machine, not on door, & try the door open/close a few times. Would be nice to know what service remember.(!)
Mar 09, 2009 | Kenmore Elite 45986 Front Load Washer
Front load washer door won't open
There is an override switch directly below the latch under the machine on most front loaders.
Jan 24, 2009 | Kenmore Elite 45986 Front Load Washer
I am getting an DL F code on my front loader
"dL" indicates Door Lock Failure: dL flashes if the following conditions occur:
Door lid is not closed completely due to interference.
Wash media buildup is preventing the lock bolt from extending.
Machine/motor control detects open door lid switch when attempting to lock.
Machine/motor control cannot determine if door lock is in a locked state.
Check for lock interference with lid or lock bezel
Jan 04, 2009 | Kenmore Elite 45986 Front Load Washer
Door is Locked
you need to re-connect the power, leave for a few (20 seconds) then open the door. assuming you have emptied out all the water. the door have a timer fitted.
Dec 14, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 43142 Front Load Washer Logo
99 people viewed this question
Sal De
 Brian Main
Brian Main
