Question about Escort 9500CI
Ci started saying rear shifting laser then going crazy with alerts right when I turned the car on then just stopped working all together like no power just doesnt come on
It was just saying rear shifting and going nuts right when I turned on the car and I would have to turn it off then it would be normal. Then all of a sudden was driving down the road and the whole system just stopped working all together. Like just powered off and hasnt turned back on. And yes I checked to see if the power button would work.
  • 162 Answers
How long has it been installed for? What type of vehicle?
Posted on Jul 07, 2014
Laser alert constantly goes off
Laser is very sensitive to false alarms often set off when driving by an airport, or military base. Set your laser on City Mode and pay attention exactly where it goes off. Mine goes off constantly in the same place which is a air force base in Tucson, AZ. Unless you drive like crazy shut it off in the city although the cops like to use a hand held one in school zones. In 6 years of driving in Arizona I have had one real laser alert, and other than false alerts, real ones are far and few in between. Check when and where the unit alerts and use different sensitivity settings. One more thing, if your laser warning goes off you already have the ticket since the cops use them at close range unlike the radar bands. Hope this helps.
Sep 29, 2014 | 2012 Pro Sti Magnum Dash Mount Radar...
What is the slope buttons used for
If you have the standard RL-H3C then there are 3 buttons. Starting from the left there is the "height alert" then "manual" then "Power".
Height alert is a function that after the laser levels and spins monitors the position of the laser. If the laser moves more then a tiny amount then the height alert function is tripped, and the laser flashes it's lights and stops spinning (or spins slowly) to let you know the base line position of the laser has changed. Pressing the height alert button twice shuts this mode off.
Manual mode means after the laser is leveled, it completely ignores the level vials. You can turn the laser any way you want to and it will always spin and not cause any errors.
Power is self explanatory.
If it's a RL-H3CS then it has two arrow buttons, that when in manual mode, allot one axis of the laser to be manually adjusted up and down to do a manual slope.
Sep 22, 2014 | Topcon Rlh3c Rotating Laser Level W...
94 Suzuki Katana 600 electrical problem
Don't know why key stopped working but you do need to stop wiring up stuff just may
Mar 04, 2014 | Suzuki GSX 600 F (Katana Motorcycles
97 grande cherokee 4.0 straight 6....dropped automatic trans and replaced the torque converter and seal that was leaking. put back together and shifts and bogs down in reverse but drive hesitates until...
I'd venture to say your linkage is out of adjustment - don't mess with the bands if the transmission worked before. Move the shift lever all the way to the lowest gear detent (farthest away from Park), then tighten the linkage cable adjustment until the shifter on the transmission is right at its stop on the transmission. The shift indicator needle should be centered on the letter. (If the transmission is now working properly and the needle is still off, you can adjust the needle inside the shifter housing by sliding its clip on the bracket attached to the shift lever. I didn't say it would be easy to get at it...)
Nov 14, 2011 | 1997 Jeep Grand Cherokee
97 Olds Achieva starts, then dies, gages crazy,then stop working
Brakes don't work when I try to stop while making a right turn.
Mar 04, 2010 | 1997 Oldsmobile Achieva
Gear shift is locked. we can only shift the car
The automatic transmissions on these vehicles are known to die early in the life of the car and Volvo is well aware that the vehicle has a dud auto transmission. The symptoms you have mentioned are an indication that the transmission has had it. It's basically just running in limp mode now.
You don't say what mileage this vehicle has clocked up but even low mileage vehicles have had to have the entire transmission replaced due to failures like yours. You also, no doubt, have a transmission alert showing on the dash.
The bad news is that a replacement automatic transmission will now be necessary and this will be costly. Even then, with these cars, you could experience another transmission failure after just another 30000 miles or so of driving.
Sean
Dec 19, 2009 | 2005 Volvo XC90
False laser alerts
Bel has a firmware fix to solve these issues. It if free if your RD still is in warranty. Of course, covering the rear laser sensor may solve the problem. That isn't a really bad idea since the rear laser sensor on all radar detectors is pretty much useless anyway.
Jun 06, 2008 | Pro RX65 Radar Detector
Mits WD 52525 format issue.
Here's something that might also be useful. After you turn on the set, and get the regular red blinky lights, hold down the Device and Menu buttons together for about 5 seconds.
The Power light will start to flash in a two digit sequence.
For example, 3 flashes, then 7 flashes = 37.
Here are the error codes, and the corresponding problem:
12 = No error detected, check power supply.
32 = Lamp Cover is open.
33 = Air filter cover is open.
34 = Lamp abnormality
36 = Light Engine (DMD or Lamp Fan stopped)
37 = Exhaust or Lamp Ballast Fan stopped
38 = Lamp Temperature High
39 = DMD Temperature High
41 = Short is detected
44 = DVI cable between FMT and Engine disconnected
Jan 21, 2008 | Mitsubishi WD-52525 52" Rear Projection...
Escort 9500CI Logo
47 people viewed this question
Top Escort Radar Vehicle Parts & Accessories Experts
Arnie Burke
Arnie Burke
Bill Boyd
JC Garza
JC Garza
Level 1 Expert
Are you an Escort Radar Vehicle Part and Accessory Expert? Answer questions, earn points and help others
