Hitachi air conditioner flashing error code ao eo 41
  • 4 Answers
There are so many hitachi models available. Can you perhaps state the model No. It will be on the Condencing Unit outside near the piping and terminal cover.
Posted on Jan 18, 2013
Krazytech
  • 725 Answers
SOURCE: E1 code flashing on my air conditioner
E1 indicates that it is time to clean the air
filter hope it helps
Posted on Jul 26, 2008
louislevel_2
  • 374 Answers
SOURCE: Air conditioner not blowing cold air anymore
hi! there,
if no cold blowing,evaporator is not working,have you ever heard compressor is running,check this out,no compression of course you dont have cool on evaporator.if the compressor is running check the oprating current,if still have enough freon charge,if not running check thermostat reset setting on the coldest,ifn still not run check overload relay on panel control reset lever to put back compressor to run,check condensing fan if working,if not check also over load protection,this should be done by ac tech nician.have a nice day,dont gorget to rate me, thank's
Posted on Apr 18, 2009
greenspan
  • 1734 Answers
SOURCE: sunbeam 9000 btu air conditioner
Ask here, they can get virtually every Sunbeam manual
Posted on Jul 28, 2009
SOURCE: ERROR CODE 5 FLASHES CARRIER SPLIT SYST. AIR COND. 42G250HP-1
5 flashing is ' compressor drive' and check the high pressure, condenser fan motor capacitor for proper running
Posted on May 21, 2010
6ylucy
  • 742 Answers
SOURCE: Error code E2 on Boston innovative products Air conditioner.
find the user manual here:
http://manualfox.com/link/bostoninnovative.htm
Posted on Jun 26, 2010
I have a flashing code CH41 on my LG Room 4-way ceiling cassette Air Conditioner model
I'm seeing a 41 that is a pipe temp sensor error. No ch41, what is the model number.
Jul 17, 2017 | LG Heating & Cooling
How too solve daikin error code c4
c4 error code has nothing to do with outdoor pcb. Use code 41 to check the value of the liquid line sensor and test with mulit meter. Pretty rare fault. Turn the power off for 5
Mins and reboot your system.
Nov 10, 2014 | Cfm Daikin R410a Split System Air...
Reset fault codes
http://airconditioningfaultcodes.blogspot.com/2013/05/hitachi-error-codes.html
I think this link should have the answers to your question.
Hope this helps.
Jan 12, 2014 | Hitachi Heating & Cooling
I have a problem code...its says check EO
Signal transmitting/receiving
error
(Indoor controller does not
respond to remote controller
signal.)
During individual unit control
1) Bad contact of transmission
wire
2) Signal transmitting/receiving circuit
is abnormal.
1) Check the transmission wire.
2) Check with another remote controller. If "EO" is
still indicated, replace the indoor controller
board.
If other check code appears. replace the original
remote controller.
P3 Signal transmission error
(Remote controller does not
respond to indoor controller
signal.)
wire
is abnormal.
3) Wrong operation due to noise
wave emitted
Nov 10, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Eo error code indoor unit runs 2-3 seconds then gives eo error code problem started when mr chipmunk chewed mr slims 12 volt wire connecting to out door unit and shorted it . Outdoor unit has bad control...
You need a professional here. Once this has been repaired, I would suggest running the wiring to the outdoor unit inside some sort of piping to protect it.
Jul 20, 2010 | Mitsubishi Mr. Slim MXZ30TN Air...
Hitachi Aircon
According to the error codes for hitachi, there is no AO code. The codes on the code list are all numeral.
Jan 09, 2008 | Heating & Cooling
Heating & Cooling Logo
305 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Donni Steen
