Question about Akai LCT2715 27 in. LCD Television
How to unlock kx-181 channel converter
Only 4 to 13 channels have opened
I have a sharp crt tv model:25c-bs370,although i'm using cable signal which more than 100 channels,still the channel it receive is limited only to 35 channels...how to rechannel the unit?my tv came...
Hi,The Television from japan have no lowband channel,It can be rechannel but the channel additional is onlly the lowband channel it maybe add only 2 channel.So the best things you do is to buy and install a channel converter to your TV.A channel converter is 100 plus channel thats why you can use your cable to japan television.To install the channel converter you need to set your television to Video setting and use RCA connector and plug it to video/sound input of your TV and video/sound output of channel converter.The cable connected plug it to channel converter.
Jul 11, 2011 | Sharp Televison & Video
Hot to unlock channels for the TY-187 Tv cable converter?
i want know the unlock code for ty-187... plss help me
May 03, 2011 | Televison & Video
I'm trying to set up the TV channels for the View Sonic 2750. I'm unable to program channels 3 & 4 to allow the cable converter box to work. The cable channels start at 181 and stop at 90 the air...
try using the number keys on control an manually program numbers in that way, if you select auto tune, it will only try to program any channel it gets signal for, once you type the numbers in that way, it should ask you to save that channel number, in which of course you select yes... try that, also refer to owner manual or mfg website.
Oct 17, 2010 | ViewSonic N2750w 27 in. HD-Ready LCD...
Tried the RF Out setting and now Ican't reset it or even get the STB to respond to set up or anything.
If you changed the RF out channel setting on the DTV converter and now can't see the output of the converter try changing the channel on the TV set. THe DTV converter boxes are designed to output either RF channel 3 or RF channel 4. If you were on channel 3 and changed the converter output to channel 4, you will have to change the TV channel to channel 4 to see it again.
Hope this helps.
Jun 15, 2009 | Insignia Digital-to-Analog Converter for...
I installed the converter box on channel 3 instead of channel 4
No reason to delete converter box from channel 3. Most converter boxes have a selection switch on the back for channel 3 or channel 4. Slide switch to 4 and set tv to 4.
Jan 13, 2009 | Televison & Video
How do I get my local channels from my VCR.
If you have a cable or satellite converter all inputs are converted to channel 3 or 4. If your vcr is attached to this output you will only get whatever the converter is tuned to. If you have cable, try connecting the cable that's now on the input to the converter to the input of the vcr and then add the channels automatically. However, the converter also descrambles premium channels, so you cannot get them into the vcr without going through the converter first, and some digital cable channels will not work on all vcrs. If you use the converter, always leave the vcr on channel 3 or 4 or use the converter video/audio outputs. You will not be able to record one channel and watch another without some additional hardware including an rf switch, rf splitter, and more cables.
Dec 04, 2007 | Zenith VCS442 VHS VCR
Akai LCT2715 27 in. LCD Television Logo
52 people viewed this question
Top Akai Televison & Video Experts
Jaime Hernandez
Radames Pagan
Radames Pagan
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
