WD 1205 CI Washing Machine
I have WD 1205 CI washing machine, which has damaged the drum part, i.e the back support of the drum has been broken up, kindly help me where the part will be available, so i can repair the machine.
  • Washing Mach... Master
  • 17,130 Answers
Please check on this link for spares: Parts
Posted on Jan 18, 2013
  • 65 Answers
SOURCE: Kitchen Aid KAWS700600 washing Machine
this machine is accessed from the front. take two control panel screws off flip up panel. unclip lid switch connection. take screwdriver and insert vertically in front of gold clips pry by pushing handle to rear of machine. rotate entire housing toward you . to reassemble ensure front lip of cabinet goes UNDER forward edge of frame
Posted on Feb 18, 2008
SOURCE: Trouble with Indesit WI 102 washing machine
I had trhe same problem and was going deaf!!! I know this is probably too late for your machine but it may be usefull to someone else with this model.
Originally thought the bearings had gone but had great trouble trying to source some through UK websites so decided to strip the machine. Did this by touch (no manual!) and eventually found that the bolts holding the bottom weight to the drum had all come loose (all 3!). Trying to access them to tighten was the biggest problem as the front of the machine is welded on.
Managed the above by removing the rubber door seal from the door only and tightening two of the bolts from inside the door. The third I managed to access from beneath the machine. All were tightened using 10mm socket on a bar with extension (curtain pole!) slid over the end.
During this process I had the machine on its side, removed the securing brackets, top weight + springs and wedged the drum from beneath and the side as much towards the rear of the machine as possible to aid access.
Good Luck!
Posted on Feb 22, 2009
  • 106 Answers
SOURCE: Loud banging noise durning washing machine spin cycles.
First plug off the wall. Open the machine from behind to examine if any shock-absorbers(known as dampers) or springs have come off or broken. Your dealer could help with spares. But you could do the job yourself.
For spares:
RepairClinic.com (which is good)
espares.co.uk
AppliancePartsPros.com
Posted on Mar 02, 2009
SOURCE: WHIRLPOOL WASHING MACHINE AWO/D 5716 - CANNOT LOCATE PUMP
Remove the bottom casing covering the front of the machine just above the floor. Unscrew the circular cap SLOWLY- beware of vast amounts of water escaping though!
I had to use a low height roasting pan to catch water, and just unscrew the cap enough so as to control the flow of water, and enable to empty water away until its all gone. Incidentally, an old hairgrip was found to be the cause of my problem.
Confusingly, "clean pump" meant clean filter!
Posted on May 20, 2009
SOURCE: MALBER WD 800 WASHING MACHINE USER MANUAL
how can i find user manuals of Malber Wash Machines???
Posted on Aug 08, 2009
How to remove drum of lg WD 8007 ci clean master
Why would you want to remove the drum to clean it? There are far easier ways to clean it.
May 08, 2015 | LG Washing Machines
What's broken to make washing machine drum unlevel
If this is a front loader washer then the springs holding the drum in place (inside the washer) are weak and off balance or the bearings are damaged.
Need some detailed mechanical check. See this post on this topic.
Front loader washing machine shaking vibrations Laundry Room Forum...
Aug 07, 2014 | KitchenAid Washing Machines
My Isis 1205 washing machine won't spin and the
chk drive belt or motor to see if working or see if u have a trapped object ?
Mar 11, 2012 | Washing Machines
LG washing machine doesn't heat water
bad cable or slide contacts or even a connector block is disconnect from a connector , it can happen when the If the motion result of the drum was too large, and can happen when a suspension eye was broken on the drum to know every brand has its own remarkable safety tricks on marketing technical arts. ( or its only a circuit thermal circuit breaker that has a problem with a slide cable connector on it or the breaker itself is damaged. Track the circuit from the program clock you can sometimes find a remarkable defect in modern washing machines.
LG WD 80130F Manuals
Aug 11, 2017 | LG WD-80130F 7.2kg Washing machine
Washing drum broken what is the cause of a drum
http://www.servicematters.com/maytag_library/docs/16010061.pdf
Above are your service and repair manual. below is a DIY self help troubleshooting site to assist you.
http://www.washerhelp.co.uk/diy-repair-help.html
A drum may have been damaged by an overload, but it is unlikely, as the machine would simply shut down and not run, you cannot Force a machine to work with an overload, these are NOT great machines, they are of "Lower" quality than many. This is a common fault.
Jun 10, 2010 | Maytag Neptune MAH5500B Front Load Washer
Where can i buy a washing machine drum paddle (for inside the machine) one has snapped off today.
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the laterwashing machines often come loose and come off altogether. They can bereplaced. call them lifters. You usuallyinsert a small screwdriver down one of the holes (it's the 3rd one on ) andgently press down while sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
Mar 23, 2010 | Indesit W 123 Front Load Washer
Replace broken drum paddle on indesit wixl123 washing machine and were to purchase part
On hotpoint, creda, Ariston ,indersit and someother makes see video
To fit new paddle, make sure the retaining lugis up slightly see video, line up the lugs on the paddle in the slots in thedrum, and push firmly with both hands towards the rear of the drum, you shouldfeel it click into place, make sure you fit it the correct way round and youare fitting the correct paddle lifter for your washing machine.
Huge selections of lifters are available on thewebsite DrumPaddle lifters
Oct 19, 2009 | Indesit W 123 Front Load Washer
Indesit WD 10 wachine machine : how to loose the drum
There is usually a bolt on the bottom that holds the drum stable during shipping and who ever put it back on a used washer is goofy!
turn it over and you should see a big bolt
Oct 17, 2008 | Washing Machines
Drum Paddle broken Hotpoint Aquarius
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Mar 08, 2008 | Hotpoint Ultima WF860 Front Load Washer
Hoover Elite 1205 washing machine
Does an Hoover elite 920 gearbox fit the hoover elite 1205 thanks
Sep 18, 2007 | Washing Machines
Washing Machines Logo
64 people viewed this question
Top Washing Machines Experts
