Question about SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive
USB Stick problem code
When I put the USB to my laptop computer (with Win 7 OS) , it start flash without stopping and the computer cannot recongize it and give a error code 10. Can anybody tell me what is the problem with my USB flash drive, thanks.
  • 8,457 Answers
Look like your USB flash drive have some corrupt data or some damages in it circuitries for this causes.
Posted on Jan 18, 2013
Mr BrokRench
  • 1623 Answers
SOURCE: My flash drive will not operate when plug into my lap top.
Hello kjh87....
1) If you are using a USB cable with your device, check the cable to make sure it matches the speed of the device. Use USB 2.0 cables with USB 2.0 devices and USB 1.1 cables with USB 1.1 devices. Swap cables and check the device, if this does not work, proceed to Step 2.
2) Next, open Device Manager and look under the heading for USB Serial Bus Controllers. If there is a device with a yellow exclamation mark next to it such as USB Mass Storage Device. Double-click on the entry and check the Device Status. If the status shows something like
"This device cannot start. (Code 10)"
proceed to Step 3.
3) The easiest way to solve a USB error code 10 in Windows XP
is to follow the steps below to remove and reinstall all USB controllers.
A. Click on Start
B. Right Click on My Computer, click on Properties
C.Click on the Hardware tab
D. Click the Device Manager button.
E. Expand Universal Serial Bus controllers section.
F. Right-click every device under the Universal Serial Bus controllers node, and then click Uninstall to remove them one at a time.
G. Restart the computer, and allow the computer to reinstall the USB controllers.
H. Plug in the removable USB storage device, and then test to make sure that the issue is resolved.
For more information on Troubleshooting USB device problems, visit the Microsoft Support Article on this subject.
I hope this helps...
Posted on May 28, 2009
SOURCE: my usb 4gb flash don my computer only reads in a secure K with 1m
See http://www.maxell.eu/FAQ2/FAQ.html
Venture USB contain two partitions - one named 'Public' and the other 'Secure'. Unfortunately we have noticed a compatibility problem between these drives and some computers running Windows Vista. In these cases only one drive is showing in 'My Computer' - usually the 'Secure' drive. As a result you are unable to access the user manuals and software which are in the 'Public' drive and cannot alter the partition sizes to allow access to the entire capacity.
Please follow the below instructions to resolve the problem:
1. Connect the USB to the computer
2. Please unzip and run the attached program
3. After completion please unplug the USB
4. Re-insert the USB to the USB port
5. You should now be able to access both drives.
Please click here to download the program and instructions
Posted on Jan 28, 2010
SOURCE: win 7 does not recognize pen drive
Go to my computer, Removable Disk (E:), there you can open and add stuff to your usb, most computers dont recognize it.
Posted on Apr 05, 2010
wvuPJ11
  • 54 Answers
SOURCE: My SanDisk Cruzer 8 GB
http://files.extremeoverclocking.com/file.php?f=197
Download and install this HP flash drive formatting utility and use it to format the flash drive using the FAT32 file system and it should work afterwards. Good Luck!
Posted on Mar 01, 2011
Geekman
  • 32281 Answers
SOURCE: Hi , My san disk
Files on a flash drive canbe corrupted if it is not removed from the USB port properly.
Before removing the flash drive click on the Safely Remove Hardware icon andthen click on the flash drive you want to remove and then remove the flashdrive when the computer message says it is Safe to remove.
To restore the flash drive to working order you need to format the flash drive,BUT you will lose the data stored on the flash drive.
If you need the data on the flash drive these WEB sites may help: -
Data and Digital Photo Recovery
www.artplus.hr/adapps/eng/dpr.htm
www.CardRecovery.com
Posted on May 30, 2011
Satellite U925t. Asks to insert disk in drive. And it does not have a disk drive. What to do?
Some devices and software still use those antiquated things called disks to load their programs and drivers. That's why I will never buy a notebook/laptop without one. However, if you HAVE the disk they are asking for, there are two ways you can do this. The first, and easiest (but not cheapest), is to get an external USB disk drive, connect it to the device, power it up, wait for it to be recognized, install the disk and go. The next best thing is do take the disk you have to a computer or laptop that has a disk drive, install it there, and using a peice of free software such as IMAGEBURN, create an ISO file of the disk. Put this onto a flash stick, install it to your device, and use the OS to mount the ISO as a virtual disk (WIN 7/8/10 all can do this). Then you can go from there.
Sep 19, 2016 | Computers & Internet
Format my hp 635 laptop
Make sure you have all your data backed up
Also make sure you have your re installation disk and proper cd keys to perform a clean install.
power your unit - press F9 for boot options - insert your 7 disk into cd rom and choose boot from CD-ROM. Follow instructions provided from install disk.
Oct 18, 2014 | HEWLETT-PACKARD HP Compaq 635 156 Notebook...
Password Access
Hi Norman,
In case your OS is Windows 7 - Please read this solution (link):
How To Reset Windows 7 Password
G'Luck !
Apr 04, 2014 | Dell Inspiron 1545 Notebook
HOW CAN I PUT A NEW OS ON MY LAPTOP THAT I PUT A NEW HARD DRIVE IN
You can't copy the operating system from your PC to your laptop. However, you can install a new operating system which is Windows 7 64 Bit which is the same with your PC. You have to have the DVD (Windows 7 Installation Disc), drivers for your laptop, and the DVD for the programs that you want to add to your computer.
Before installing a new OS to your laptop, make sure that you have saved all the important files to an external saving device such as a USB flash drive. You have to make sure that your laptop has all the specs to run Windows 7. Please visit the link below to check the minimum requirements (system) for Windows 7.
http://windows.microsoft.com/is-IS/windows7/products/system-requirements
Hope this helps.
Nov 14, 2012 | Microsoft Windows Vista Ultimate Edition
Lap top went black and won't start
*This method only applies to Aspire ONE A150 only
1) Format USB memory stick with FAT file system.
2) Download BIOS for A150
http://global-download.acer.com/GDFiles/BIOS/BIOS/BIOS_Acer_3310_A_AOA110%20&%20AOA150.zip?acerid=633850493862245097&Step1=Netbook&Step2=Aspire%20One&Step3=AOA150&OS=X01&LC=en&BC=Acer&SC=PA_7
3) Extract all files the downloaded file and place FLASHIT.EXE and BIOS file onto the memory stick
4) Rename BIOS file to ZG5IA32.FD
5) Turn netbook of, with power AND battery connected
6) Plug in memory stick with BIOS file and Flasit.exe
7) Press and hold Fn+Esc the unit will go on, hold until power LED is flashing then release keys. If it does not flash, then release and press power button once.
8) You'll notice the LED of both the usb memory stick and the power LED will flash together.
9) After a few seconds the flashing will stop and the unit will reboot or switch off completely.
May 28, 2010 | Acer Aspire One PC Notebook
My computer was pre-installed with Windows 7 OS. I want to change it to Windows xp what shoudl i do?
You need to confirm that your computer is backward compatible with the older XP OS. You should Google your computer manufacturer and use their 'contact' facility to confirm that this will work.
If you revert to XP you might find that you cannot use programs specifically designed for, or provided with, Win 7.
I would recommend that you stick with Win 7 and use Windows updates for any fixes or patches.
It is a pain to switch from an OS you're used to to a new OS but once you've sorted all the bugs etc with Win update you'll find it's worth the effort. I started with Win 3.0 - in the OS stoneage days!
Apr 25, 2010 | HP Computers & Internet
I removed U3 stuff from my Cruzer micro 2.0GB; now I get message
I would like to point out that this must be something the u3uninstall utility did to the usb stick. Mine was working at full speed while I had the U3 stuff on there, and stopped working at full speed in both windows 7 and ubuntu 10.04 after I used the tool. Sorry this isn't a solution, but it's additional info. It's strange it makes it seem like the problem is your OS or drivers and not the usb stick itself, or what the u3uninstall utility did to it.
Jan 30, 2010 | SanDisk 2GB Cruzer Micro SDCZ62048A10 Hard...
I reinstalled my OS win XP . now no usb
Open Run and launch regedit
Browse to the following location
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\USBSTOR
In the right pane, look for an entry named Start. If you find one delete it. Your USB devices should start working immediately.
If not please report back.
Nov 11, 2009 | Acer TravelMate 240 Notebook
CyberShot DSCW55 driver wont work on win xp x64
No, their is not one if its not compatible you will have to purchase a camera that is compatible with win xp 64. Another option is to get a USB card reader ($15-$20) and put your memory stick inside it and goes directly into the usb port. You can pull your photos off just like a portable memory stick. I use this option for my Sony camera and my laptop has a media port that takes the card directly with no need to have a USB card reader....
Sep 26, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Windows XP stopped recongizing eGo external Hard Drive I just installed a new iomega eGo 1 TB desktop Hard Drive yesterday, got the bugs worked out and my Dell w Windows Xp seemed to recognize it, Today,...
2 things... the USB port is bad, or the USB cable is too long and the HDD isn't getting a good signal.
1. Try another port and see if that works
2. Nip over to WalMart, Circuit City, Micro Center, PC World or Best Buy and get a shorter, Thicker USB cable of the same type - a cable which can provide the signal strength your ext HDD requires.
Also a possibility... The HDD may be 'lost' as Win cannot accept one of that size or the label/signature fell off and it is an orphan. It MUST have a driveletter, and it MUST have a special WIN signature byte on the HDD for it to work.
Bootup as normal, let everything get quiet, then plug in the ext HDD
Rt Click My Computer, Manage, Device Manager and in the Rt side, highlight the TOP icon. Then under Help, click the Computer with magnifying glass icon and wait. This forces your OS to 'Look' for any new devices.
When it finishes looking, look again under My Computer to see if your new HDD is now there. It will have to be formatted and have a driveletter for this part to work. Jump down to Disk Manager and see if it is there. You may have to Rt. Click and import it as a foreign drive or Rt click and give it a Driveletter ;-) If it is not, use a shorter, thicker (more wires) USB cable and try again.
Windows doesn't like Any HDD without win signatures on them - aka:'foreign disks' so ANY time this happens, if OS doesn't see it, use disk manager and Import it, then Rt click it and give it a Diskletter.
Jan 15, 2009 | Computers & Internet
SanDisk Cruzer Micro 4GB USB 2.0 Flash Drive Logo
Top SanDisk Electronics - Others Experts
k24674
Piyal Perera
Piyal Perera
Are you a SanDisk Electronics - Other Expert? Answer questions, earn points and help others
