Question about Toshiba Satellite M45-S169 Notebook
Laptop cd rom problem
Hi I have a laptop that I cannot use the CD ROM drive It gives me incorrect function even though I okk at it and it tells me the drive is ok the name of the drive is MATSHITA DVD RAM JU-8415 Can you help me please You sent this ---Hi I have a laptop that I cannot use the CD ROM drive It gives me incorrect function even though I okk at it and it tells me the drive is ok the name of the drive is MATSHITA DVD RAM JU-8415 Can you help me please I did the recommended procedure for this and it came back Incorrect Function what now?
    Novelist:
  • 126 Answers
The very first thing what u can try is that take the cd drive out of the computer and the put it back in and then try and play the cd or dvd and try with the dfferent cd's or dvd's and still if it doesnt play then what u can do is that delte the upper filter and the lower filter from registry tye regedit on the run box and then open the hkey_local_machine>system>current control set>control>class>4d36e965-e325-11ce-bfc1-08002be10318....double click on this and then on the right hand side u can see the upper filter and the lower filter just delete that and then restart the computer and it will work and still if it doesnt work then replace the cd/dvd rom
Posted on Jan 25, 2009
AM USING A GATEWAY LAPTOP WITH OPTIARC DVD RW AD7640S ATA. IT WAS WORKING INITIALLY BUT FOR SOMETIME NOW WHEN I INSERT ANY CD, IT TELL ME TO INSERT A CD INTO THE DEVICE EVEN THOUGH ITS INSIDE. AM USING...
2 possible issues....1 driver for the dvd rom is corrupt.....try using the cd the unit came with and re-installing the driver....2 bad rom....if your under warranty...try just sending the rom in....if now...flip over the laptop....find the 1 screw that will let you slide out the rom...look for the part number/ model number....find one on ebay....real cheap there...usually under 10 bucks....try cc.texas.smart.shop (member) that is me and i have a few gateway roms avail.
Oct 12, 2010 | Gateway (5500652) (  5500652)...
My cd-rom when in it cd tell me is no accessible and incorrect functionaly
may be the problem with your cd drive lence. Otherwise check the cd which you used in your cd rom on other system if its working fine means your cd drive has problem. check that
Jun 17, 2010 | Computers & Internet
Cd-rom in my daughter's laptop has stopped working. i have an identical laptop and swapped out the cd-rom drives but still does not work. I'm trying to download the drivers for the cd-rom drive but can't...
I believe we need drivers for CD ROM if both laptop are of same models. Can you plese insert the faulty CD ROM to your laptop and verify whether it is working or not. If yes, then you'll have take your daughter's laptop to service center. Could be a problem with mother board.
Please come back and give ratings to my solution if this turns to be helpful for you or also if you need more clarification.
Thnx
Mar 31, 2010 | Computers & Internet
I have bought a Super slim external USB portable 24x CD-ROM for my Dell notebook. I can't get DVD's to play on it. The laptop recognises the removable device but there is no option to play the disc. Can...
CD ROM drive will play only 700 mb CD disks(normal CDs)...and not play DVD disks...u need DVD ROM drive to play DVDs....there is a big difference among both in it's function.
a DVD drive "may" play both DVDs and CDs....
but
a CD drive will "only" play CDs
Feb 18, 2010 | Computers & Internet
I want to replace my acer laptop Cd rom , from where can i remove old one
Here are the steps on how to remove your old CD-ROM so you can replece it.
Remove all power sources from the laptop. This should include not only the AC power adapter but also the battery.
Locate and remove the screw that locks the CD-ROM in place. Some laptops may have two screws that serve this function. In addition, many will also have a sliding switch that needs to be moved in order to remove the drive.
Slide the drive out gently. It should easily come out and does not require excessive force.
Replace the defective CD-ROM drive by sliding the new one gently into place in the laptop bay, the same way the old one came out. Again, excessive force should not be applied. The drive will only fit into the bay one way.
Secure the CD-ROM drive in place by replacing the screws that were removed previously. Reconnect all power supplies to the laptop and power it on. If the replacement CD-ROM is the exact same make and model as the previous one, the system will probably recognize it right away. If it is a different make or model it will prompt you to supply the appropriate software and drivers to optimize the use of the new CD-ROM drive.
Jan 22, 2010 | Acer (91.49C37.001) CD-ROM Drive
E: drive, cd rom drive will read a cd with data, but not a new cd
CD Driver or CD Writer encounter such problems are a normal reading in data. Sometimes it does or not. To identify the real situation on your CD/CDWriter drive is very difficult to you.
Here is the answer to your problem.
# You use your CD/CDwriter drive for how many long years and now got a problem.
# The speedometer of your CD/CDWriter (lens eye) can no longer read any available CD or have data's also or even BLANK DISC.
# Use any CD CLEANER to clean up your CD/CDWriter Drive to remove the dust inside.
Aug 07, 2009 | E-Machines emachines (emachinees) CD-ROM...
Will it read?
Yes, that's what it looks like. Make sure you put this in the right section next time, though.
Jul 08, 2009 | Intel Toshiba Satellite Mini-PCI Laptop...
Cannot open cd-rom drive!
The thing about cd/dvd drives in general is that they die and thats the case here even if you deleted anything of the operating system its self would notice that the cd drive was missing the driver and ask you about it since you havent stated that its safe to say that the drive is dead
Mar 13, 2009 | IBM ThinkPad T60 Notebook
Hi I have a laptop that I cannot use the CD ROM drive It gives me incorrect function even though I okk at it and it tells me the drive is ok the name of the drive is MATSHITA DVD RAM JU-8415 Can you help...
go into your device manager uninstall the device driver , but do not delete it, restart the computer, it should work, if it doesn't try manually updating it to the previous device driver, also boot from a cd to see if the drive works outside of windows.
Jan 18, 2009 | Toshiba Satellite M45-S169 Notebook
DVD NOT SHOWING
hi frined
change ur data cable & power cable & try to ditecing
if not show then do one ting go in a device manager >system devices>pci bus>right click on it & uninstall then ur pc is restarts
& insatll ur all divce drivers correctly
thnx using fixya
Apr 01, 2008 | LG (CRD-8400CB) CD-ROM Drive
Toshiba Satellite M45-S169 Notebook Logo
127 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
