Question about Avaya 9610
No ethernet error on avaya 9608 Ip phone - Avaya 9610
SOURCE: avaya 4610 ip phone--wireless handset?
CS60 from Plantronics. A bit expensive but perfect
Posted on Feb 25, 2008
SOURCE: Avaya 5610 IP Phone
Press mute reset (mute 73738)
Posted on Oct 21, 2008
SOURCE: IP Phone available for IP office?
If your IP Office is Rel 4.2 or higher, You can purchase a license that will allow you to load a vpn script into the phone. Once you set up your VPN router at corporate, the phone gets plugged into any open internet connection and syncs up with the VPN router and makes a tunnel which then will connect with the phone system giving you a remote IP phone extension of that system.
For the PC, just load client software on it, and it works the same.
Since the tunnel is directly from the device (phone or PC), your home network will not be apart of the office network.
Posted on Mar 12, 2009
  • 10 Answers
SOURCE: Using AVAYA 4610SW IP phone
Answer to the second problem :-
1. The changes in the ring tone has to be made by accessing the Avaya server where the phones are registered.
2. Log in to the avaya server...... enter change station <station number> on the command prompt
3. In the personalized ring pattern field, you can select one out of the 8 available options by typing any digit between from 1 to 8.
4. The ring pattern of that particular station will change accordingly.
5. Keep the personalized ring pattern of all the stations different by assigning different digits against this value
Posted on Apr 02, 2009
  • 10 Answers
SOURCE: How to configure Avaya's IP Phone 5610?
Ensure the reachability of the call server from that port. To ensure the same, configure a laptop with the IP address and default gateway of the intended IP phone. Then try pinging the call server from the laptop.
If this works then the setting should work for IP phone too. Double check on the router IP address and Vlan ID configured on the phone.
How to set up different ring tones for internal and external calls coming to Avaya IP 9608.
doubt that there are any since it is a land line check with the manufacturer
Sep 26, 2016 | Avaya 9608 IP Telephone
Low volume on headset
Press the volume up button.
When the phone is idle, the volume with set teh ringing volume.
When the phone is in speaker phone mode, the volume adjusts the speaker level.
When in headset mode, the volume adjusts the headset volume....
Dec 06, 2012 | Avaya 9608
Avaya 9640 can't power on when network cable plugged in
Do you have a POE switch? you need power on the port to power the phone...
Nov 06, 2012 | Avaya 9608 IP Phone
Hi I buy the new phone AVAYA 1616I, but it does not work, it always "finding router" can you help me onm this?
Hi tung_nd,
I see that your are having issues with your AVAYA, see details below.
* First find out the IP address of your Router.
*Inout that IP address in your AVAYA, this should make you AVAYA detect the Router or Network.
*once the Network is detected then you can set you AVAY for use.
Your AVAYA will need an IP address to connect to this will enable it for use, this should fix your concern.
Make sure that you have all the details that you need to be able to set up your AVAYA like the port number that it wwill be using in the aNetwork.
There will be 2 ethernet ports on the back of your AVAY one will be connected to the Router which should give the AVAY the power to turn it ON and the network connection to provide data transfer, the other ethernet port will be connected to your computer this is where the data from the router goes to if you have files that are shared in the network, and if you are running application from a Network.
I hope that this will be helpful regarding your query.
Have a nice day,
mvincentc
Apr 28, 2011 | Avaya 1616 IP Phone
Tcp connection error on my avaya phones
What error? No ethernet? What do the phones display fter that?
May 18, 2009 | Avaya 4620SW IP Telephone
I have a Avaya 4690 ip phone. when I reseat the ethernet cables for the phone after initializing it comes up with "registration error". How do I fix that?
That phone is registerring with a server. There is nothing you will be able to do. You need to contact your system administrator
Jan 09, 2009 | Avaya IP Office 4690 Speakerphone...
Blank Screen
I would verify what the firrmware is of the phone. It is possible that the phones need to be upgraded.
Mar 27, 2008 | Avaya 5610 IP Phone
Phone does not connect to IP
replace the nic card or ethernet card.Mail me back at amu1974@rediffmail.com if the issue does not get resolved
Thanks and Regards
Amlan
Nov 16, 2007 | Avaya 5610 IP Phone
Avaya 9610 Logo
840 people viewed this question
Top Avaya Computers & Internet Experts
Michael Vincent Cruz
RSole
Are you an Avaya Computer and Internet Expert? Answer questions, earn points and help others
