Question about Kenmore Elite 45986 Front Load Washer
Where is the button trap located on a kenmore front loading washer
    President:
  • Kenmore Master
  • 2,651 Answers
Behind the lower panel, theres 3 screws across the bottom of machine remove them and youll gain acess to the button trap
Posted on Jan 25, 2009
Kenmore 417.43042200 Front load washer. Replace shock absorbers and coin trap
Hello Karen,
The following video should fully explain everything that you should know on how to do this replacement and any warnings.
Good Luck!
Rich Lilja
Apr 27, 2017 | Kenmore HE2 Plus Front Load Washer
I have a he2 kenmore front end loader washing machine...it stops mid load and flashes F20
Something is in your pump trap, easy fix. pop open the bottom panel by removing the three screws under it. requires a torx bit or a nut driver. if you can tilt the washer back so the front legs are a foot or 2 off the ground, it will make this a lot easier. once open you will see a twist off cap. before you remove this be prepared for the residual water to eject out when you open it. these can not get all the water out so there is always some, tilting it back will minimise this or putting hose clamps on the pump to tub hose can help but not nesesarry. twist it out and clean it out, also stick your fing into the two holes where the trap is located to see if any coins have gotten stuck. once clean, make sure you line up the trap arrow with the base. then button it back up, good luck
Dec 04, 2009 | Kenmore HE2 Plus Front Load Washer
Lint trap
First you need to remove three screws on the front lower panel. This will expose a round "plug" to your right. This is the lint/drain trap. Place a bucket under the plug. Slowly unscrew this plug and aloow the water to drop into the bucket. Make sure your plug is clean and reset it.
Jun 10, 2009 | Kenmore HE2 Plus Front Load Washer
LOCATION OF LINT TRAP?
Remove 3 screws from the bottom front panel and drop it down. The pump will be in front of you on the bottom.
Mar 27, 2009 | Kenmore Elite 45986 Front Load Washer
Ge front load washer does not spin or drain
Unscrew the botom front panel,behind that you will see a lint trap,with the power off,and unplugged,place lot of towels on floor at this trap,unscrew slowly,as water will exscape,trap will pull out with plug,clean trap,,,,,,,,,,,,,,,,,,,,,,,trap is about 1.5 inches round,it located at bottom right side of my machine,,,,,,,,,good luck
Nov 16, 2008 | GE WSXH208A Front Load Washer
Getting the cover off of the kenmore elite front load washer
Torx screw driver i belive it is a #10 you can buy at any hardware store
Aug 02, 2008 | Kenmore 44102 Front Load Washer
Kenmore 90 washer won't drain
ckd pump traps for debris on kenmore remove front panel on samsung i think a rear approach is best
Jun 03, 2008 | Samsung WF337AA Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
76 people viewed this question
Sal De
fordexpert
Robert Rankin
