Question about Kenmore 73952 Gas Dryer
No Heat Dryer runs fine everything in working order but no heat?
  • 2 more comments
  • tello_5746 Jan 25, 2009
    every thing works fine but heat did'not ignites
  • camachojrart Jan 29, 2009
    I have a Kemore 70 Series works fine but no Heat at all can you help?
  • Anonymous Feb 16, 2009
    everything works except theres no heat.
  • kmontrose May 14, 2009
    dryer runs fine but no heat at all. its a maytag
  • 750 Answers
Hello
Welcome to Fixya
Remove the vent line from the rear and try the dryer.
If it heats then that means there is a clog or kink in the vent line blocking the vent air from exiting which will stop the dryer from getting hot!
If not then it's another one of these problems.
Defective Ignitor (Gas Only)
When heated the ignitor used on your gas dryer must obtain a specific high temperature
in order to activate the flame sensor. This ignitor is fragile and susceptible to cracking.
A hairline fracture that is barely visible to the naked eye is enough to change
the resistance of the ignitor to a point that is will not work properly.
You can test the resistance of your ignitor. You should get a reading of 50-400 ohms of
resistance.
If the ignitor gets hot and then goes off after about 10-15 seconds and there is
no ignition, the problem is probably not the ignitor. It is most likely the gas valve
coils that are defective.
If the ignitor comes on and stays on, it is the flame sensor that is defective.
If the ignitor is not getting hot it could also be one of the thermostats that is defective.
The power for the ignitor is passed from the timer, through all of the thermostats,
limit switches and fuses to the ignitor. So if you are not getting power to the ignitor
during ignition, you should check the continuity of the individual thermostats and fuses.
DRYER DOES NOT HEAT
Defective Gas Valve Coil (Gas Dryer Only)
If the gas dryer will light once but will not relight until it cools down, it is likely the gas valve coils are faulty. These coils loose some strength when subjected to heat. When they become old, the addition of heat may be enough to prevent them from opening the gas valve when hot. However the coils still work when when cool.
An easy way to diagnose the coils when the burner is not lighting, watch the ignitor. If the the ignitor glows for 10 to 15 seconds but no flame is created, then the coils are faulty. If the ignitor is not glowing the problem is elsewhere.
Recent Customer Symptoms:
The dryer burner doesn't always come on when starting. If the burner does come on, once it goes off if won't come on again until the dryer cools down.
Defective Flame Sensor (Gas Dryer Only)
The flame sensor's job is to monitor the ignitor for sufficient heat
to ignite the gas. A properly operating flame sensor will pass a
continuity check under room temperature.
Common Symptoms
If the flame sensor is defective in the open position,
the ignitor will not get hot when the dryer is started.
However, if it is defective in the closed position the ignitor
will get hot, but the flame sensor will not allow the flame to ignite.
In this case, the ignitor will usually stay hot for a long period of
time.
Defective Thermostat
The thermostats are responsible for maintaining the proper temperature
in the dryer. Check the exhaust temperature of the dyer and if the
temperature is above 150 degrees, you will most likely need to change
the operating thermostat.
The thermostat can also fail in the opposite mode.
It can prevent the element from heating at all.
A failed continuity check at room temperature will verify this condition.
There are some special thermostats that are single pole double throw.
These thermostats are often used to control the timer when set to the
Automatic Dry cycle. If the dryer timer will advance in the Timed Dry
cycle but not the Automatic Dry cycle, then the thermostat could be the
problem.
Defective Thermal Fuse
The thermal fuse is in series with one leg of power to the motor.
If the fuse is open (no continuity) the motor will not run.
The thermal fuse is located in different locations according
to the model and brand of dryer.
Solution:
Check the thermal fuse for continuity with a volt/ohm meter.
If it is open, it will need to be replaced
Thank You For trusting us with your question
Please remember to leave a solved rating before you leave!
Posted on Feb 03, 2009
Runs fine low heat
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101
May 25, 2011 | Maytag Neptune MDG9700A Gas Dryer
The everything in the dryer is running fine but the heat isnt working
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 14, 2010 | General Electric DBSR463EGWW Dryer
The dryer will not heat. I have no error codes and everything else works fine. I did order a heating element assuming that was the issue but now wonder if I would've had an error code and it could be...
If you are having problems with your gas dryer not heating the most common problem is that the ignitor goes bad. Even though it glows sometimes it is still not working properly.
If you have an electric dryer, you can have many different things that can go wrong causing the dryer not to heat.
heatman101
Oct 05, 2010 | Samsung DV337 Electric Dryer
Dryer has stopped producing heat
I have a Thin Twin manual that will give you an idea of where to start:
THIN TWIN SERVICE MANUAL
Jul 12, 2010 | Whirlpool WHP1500S Electric Dryer
Dryer will not heat. lint filter is clean. dryer runs fine bosch dryer nexxt 500.
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Nov 08, 2009 | Bosch Nexxt 500 Dryer
90 series will not stay running or heat
DO NOT KEEP THE BUTTON PUSHED IN AND RUN IT...It's the motor relay and the even heat board in the console. By keeping the button in, you're bypasssing a safety feature and could cause fire. It won't heat like that anyway. Repl. the relay witht the small blue wires and the board in the console and you should be fine.
Jan 30, 2009 | Kenmore 659 Electric Dryer
Dryer doesn't dry clothes. seems to run on low heat.
Make sure dryer is unplugged. Take the back off and you will see two heater exchanges and probably the element. One of those heat exchangers is for hot setting. When you find out which one go to nearest electrical shop with it and order. I reckon thats what your problem is. I've changed mine and everything was alright.
Oct 04, 2008 | Frigidaire Dryers
Dryer is running but it's not hot
If the electronic start is not working, it may need to be replaced. Call an appliance parts store and ask some specific questions to them about how you can test that component and if they carry a replacement for your specific make and model. Good Luck!
Jul 05, 2008 | Whirlpool LGR7646E Dryer
Kenmore 73952 Gas Dryer Logo
474 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal DeAngelo
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
