Question about Amana ABB1927DE Bottom Freezer Refrigerator
Amana ice make problem
I have noticed that when my automatic ice maker fills up some of the water is dripping through to the ice tray freeezing solid the already made cubes. Any ideas what the problem is help. thanks
  • ben johnson Jul 20, 2007
    still trying to figure out how to pry open the ice maker any help would be great
  • MY2JAYZAC Mar 15, 2008
    HI.The problem is it started to make hollow ice cubes then after awhile none at all .Before this it worked fine .any help would be greatful thank you
  • 883 Answers
There is a screw adjustment that accounts for the variations in water pressure among various installations. Without one, problems such as yours will be widespread. Pry open the plastic cover over the icemaker. Look for a screw that has markings and/or arrows near it. I believe that turning the screw counterclockwise will decrease the amount of water allowed in. Experiment with each turn direction as necessary. You should see the amount of water fill with a flashlight. A proper fill should be about 3/4 to 7/8 filled. Never fill 100%. The cube ejectors may break then.
Posted on Jul 14, 2007
SOURCE:
The drip pan is filling up with water and then over flowing. We have to empty it once a day. Then I noticed the ice maker has stopped making ice. Any ideas?
Turn icemaker off see if water problem stops ice tray water valve may be overflowing tray cycle timer may be faulty or faulty water control valve.
Jul 31, 2015 | Whirlpool Refrigerators
Why is my Uline ice maker filling with water not ice ?
At first I wanted to say it has to fill with water to make ice but I know you mean the ice bin is filling with water. You either have an issue with the water control valve leaking or your timer isn't working properly. Listen for the water to flow and when it seems to shut off look at the tray fill spout and see if it actually stopped dripping. If it continues to drip (not flow normally) then the valve is leaking. If it isn't dripping but the water in the ice tray over flowed, then the issue is either with the timer or the adjustment is incorrect.
Jun 04, 2014 | U-Line ULN Marine Series 12-lb Crescent...
My ice maker in my side by side refrig/freezer leaks water so that a solid block of ice is formed in the tray maker. This prevents dispensing of cubes. What can I do?.
The cause of that is the water inlet valve is not fully closing but instaed its staying open a little and seeping water through it all the time which is dripping into the storage bin for the icemaker and freezing all the ice into one huge block. To repair that the water inlet valve on the back of the ref. where the house water supply line attaches to would need to be replaced.
GENE
Sep 22, 2011 | Amana Refrigerators
Noticed 3 days ago. The ice tray was frozen solid to the top with water not ice cubes. looks like iceberg all the way back to where water line connects to ice maker. Now water had leaked somehow up to the...
What I have seen in a thing like this is a simple water valve drip. Some of them drip like a faucet. This causes the cubes to stick together and all kinds of grief. I have your service manual.
LG bottom mount ice box service manual
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 10, 2011 | LG LRBN20510WW Bottom Freezer Refrigerator
Ice tray filler tube freezes up and clogs up so no water goes into tray
The water inlet valve on the back of the unit where the water supply comes in can have a slow leak and will cause ice to buildup and block the fill tube. Disconnect the ice maker line from the valve and watch to see if it has a slow drip. It doesn’t take much to eventually block the fill tube.
The valve can leak because of sediment in the water preventing it from closing or low water pressure.
May 22, 2010 | Amana SXD524VW Side by Side Refrigerator
Thanks for your response Woodchuck 789- it is greatly appreciated. I tried checking the dual inlet valves as you suggested - switching electrical connectors and checking output, etc. The valves seem...
its hard to ck a valve that drips / and the ice maker may be over filling . if ice cubes are stuck to gether it is over filling . if driping . it may be a bad valve that does not shut off tight. I would replace the valve .. ****
Jan 07, 2010 | Amana 22.6 cu. ft. Side-By-Side...
Amana refrigerator model th121tw ice cube maker is not freezing. It freeezes some ice cubes but accumulates water in the tray below
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Try swapping the wires on the dual water inlet valve. Then try the water dispenser. The water should go to the ice maker. This will tell you weather or not the ice maker valve is working and if the line is clear.
Aug 29, 2009 | Refrigerators
Water on the ice maker doesn't shut off - drips into the ice pan
Most models of Ice makers have an automatic timer for the amount of water that is allowed to enter the Ice Maker tray. If your timer valve is going bad you need to replace it. First I would reduce the amount of water coming from its source. There should be a tapped valve under your sink, connected to your water line. You have to turn the top of the valve clock wise to reduce the amount of water the is going to the back of your refrigerator. That is where you will find the timer valve. Reducing your water flow should help reduce the volume of water being let into your Ice Maker.
Jul 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Freezer Ice Maker Won't stop filling with water
The water solenoid at the back where the water line attaches to the fridge has failed
Jun 29, 2009 | Refrigerators
Water Leaks from Ice Maker of Sub-Zero 642
Sounds like the water inlet valve to icemaker is leaking - not closing completely after filling the tray. Rare, but possible. Prove it by shutting off icemaker arm or switch. If that is the cause, the drip will continue.
If dripping stops when I/M is off, then it is ice blockage in I/M fill tube and or diverter funnel at end of ice tray. Remove I/M, clean ice from both, and re-assemble.
Replacing that valve (water supply to refrig connects to it in the back) should solve it.
Jun 13, 2009 | Sub-Zero 30.1 cu. ft. Cabinet Depth...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
171 people viewed this question
Top Amana Refrigerators Experts
Sal De
Steve Allison
Steve Allison
Carmen Mikulic
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
