Question about Emerson MW8102SS 1100 Watts Microwave Oven
Please i have looked everywhere::::: i need a hv capacitor for emerson mw8115ss suffix b. info on capacitor is: ch85-21090-2100V-AC 0.90uf+-3%b 10/85/21 50/60Hz No PCB's V000480 Made in Ningbo China
    Scholar:
  • 87 Answers
P/n MOS0857 on sears com.
http://www.searspartsdirect.com/partsdirect/getSubComp.pd?modelNumber=MW8102SS&productCategoryId=0123245&brandId=0352&modelName=MICROWAVE&diagramPageId=00001&componentDescription=CABINET%20PARTS&documentId=50020101&backToLink=Return%20to%20Sub%20Components%20list
Posted on Jan 25, 2009
How can i get a manual for a emerson model #MWG9115SL SUFFIX F?
I suspect that the manual is the same for the MWG9115SL F and other suffix models. The manual for the MWG9115SL is available from the Emerson Radio Corp. customer support page: http://www.emersonradio.com/owner_manuals.php . The direct link is http://www.emersonradio.com/resources/owner_manuals/manual_1325712698.pdf .
I hope this helps.
Jan 30, 2015 | Emerson Microwave Ovens
Started arcing inside like it was on fire. It started to arc inside and making a loud noise. You could see big flashes coming from inside where the motor is. It did'nt last very long. I wont be buying...
When the micro starts arcing it is reasonably serious. One or more of the components are broken down. What needs to be done is firstly, "pull the plug out" The cover needs to be unscrewed and removed. You will then see the electrical components on the R.H.Side. There is a magnatron (creates the heat).and a capacitor (discharge voltage) and a HV diode. (DCcurrent to charge the cap). The magnatron needs to be replaced, and the HV diode. Please do not do it yourself as there are lethel voltages sitting there waiting for a wrong move. A technician needs to do the repairs as he has the appropriate tools to discharge the cap and do relative tests.
Aug 29, 2010 | Emerson Fans Emerson MW8115SS Microwave...
I need a manual for MW1161SB suffix A 120V
mcdevito75 here, You should be able to contact Emerson online or check with any store selling Emerson microwave ovens for contact info.
Jul 09, 2010 | Emerson Microwave Ovens
Whirlpool microwave model MH1150XMS-0 is not working
your door monitor switch has gone out. they are 3 switch that monitor the door. remove control panel. they are located behind frame where the door clips go into.
Jun 24, 2009 | Emerson MW8102SS 1100 Watts Microwave Oven
I need a user manual for the mw8115ss emerson
Go to this web site.
http://www.emersonelectronics.ca/emerson/en/support/index?page=manuals
where it asks you to input your product code, type in "mw8115" (without the quotes) then click "go"
Please take the time to rate this solution
Jan 28, 2009 | Emerson Black Microwave Oven
How to change a light bulb in a emerson mircowave model mw8115ss
If this is freestanding m/w:
1. disconnect from outlet
2. take the cover off.
3. light bulb located on right upper corner.
Nov 30, 2008 | Emerson Black Microwave Oven
Model mw8115ss suffix a Emerson Microwave not working
This is usually caused by either a bad door switch, a loose door switch mount, or a misaligned door.
Even though a door switch clicks, it may still be bad inside. Its continuity must be checked.
Door switch or mount trouble can be caused by slamming the door or by opening the door while it's cooking without hitting the Stop pad first.
There are plastic mounts inside the microwave which hold the door switches and onto which the door latches lock when you close the door.
The screws on these mounts may be loose. If they get too loose, the switches will not be activated properly.
Sometimes it's a broken tab on the switch holder, allowing the switch to rotate just out of position. This tab can be hard to see, since it is under the bottom edge of the switch.
One test that sometimes helps is to gently lift up (and/or push down) on the door or handle as you try to start it. If it works or tries to work, then it's a door switch mount or door alignment issue.
If you or someone you know decide to look into it, we have critical information on safety, disassembly and door switches at our site, and our link is at our listing here on FixYa:.
Aug 03, 2008 | Emerson Fans Emerson MW8115SS Microwave...
Emerson mw8115ss microwave
If you don't have your manual, you can download it here:
http://emersonradio.com/owners/MWO%20manual/MW8115SS.PDF
The manual will also have contact info for Emerson in case you want to check with them on this.
The magnetron may be going bad, and they usually have a warranty of several years on that.
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 06, 2007 | Microwave Ovens
Ummmm I feel stupid
The manual is on the Emerson site at:
http://www.emersonradio.com/owners/MWO%20manual/MW8115SS.PDF
But it doesn't seem to mention a way for you to change the lamp.
Manufacturers used to include access panels in the rear or side so you could easily change the bulb. That exposed the customer to 110V connectors, and that posed a real liability threat, so they stopped using them.
You now must generally remove the outer cover to replace the bulb.
If you or a friend decide to work on it, we have *critical* safety, disassembly, and troubleshooting info at our site, which is linked at our listing here on FixYa: http://tinyurl.com/yzjozk
Nov 18, 2007 | Microwave Ovens
Emerson MW8102SS 1100 Watts Microwave Oven Logo
173 people viewed this question
Top Emerson Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Jerry Greenberg
Jerry Greenberg
Are you an Emerson Microwave Oven Expert? Answer questions, earn points and help others
