Question about Delta Faucet #RP320 Divert Assembly
My old diverter does not have an e-clip, but the replacement 320 does, and won't fit. What's up, should I just 'force' it in or pitch the e-clip?
Makes high pitch noise
Grohe has a lifetime warranty on faucets. Call them and ask for parts. There is some internal part that vibrates. It could be the cartridge that makes it work or if it is a kitchen faucet with a separate spray, the diverter can do this.
Jun 24, 2014 | Grohe Plumbing
Fisher and Paykel diverter won't work
The plunger should be out when wax solenoid is hot.
When non energized outputs to drain pipe.
Check to see if it's the right way around.
Oct 27, 2012 | Fisher and Paykel Washing Machines
Replace left axle half shaft on a 1999 Suzuki Esteem automatic
Shouldn't be anything other than the clip.
Most times I use a pry bar to snap it out.
Jul 08, 2012 | Cars & Trucks
Acer Aspire 5002WLMi Laptop won't recognize full 320 Gigabytes of new PATA hard drive. It's always been running a 80 Gigabyte 4200 RPM but that drive is old...a 2005 HD. New WD320 only reads 137...
The BIOS in the ACER determines the maximum size of the hard drive it can support.
Check the laptop's specification to see the max size you can install in this model laptop.
It appears that the max size your laptop can support is 140 Gb (unformatted). 137Gb formatted.
I suggest you install a hard drive up to 140 Gb capacity in your laptop and place the 320 Gb hard drive in an USB hard drive adapter case and when you attach this hard drive to the USB port in your ACER laptop then you will be able to get the full 320 Gb capacity after you delete the partition and create a 320 Gb partition and format the hard drive.
Nov 02, 2011 | Acer Aspire 5002WLMi Notebook
My 32" Hampton Bay Minute
Sounds like an excellent idea. In case you don't get a certain reply, i suggest that you remove a blade from your old fan and take it with you to a store that has one on display. Check the spacing of the holes, and the number of blades. You might also find that the width of the blades and their pitch (which is determined by the bracket the blades are attached to) work out in combination to give you about the same performance. But if the bigger fan has a much flatter pitch, you might find it won't deliver as much air as your old fan did with the old blades. Good luck, Al K
Jul 26, 2011 | Hampton Bay 40106 Minute II Ceiling Fan
1994 softail springer with harley carburator. fuel fitting on carb that was there had a plastic clip and small line going to hose. This hose broke and I was given a different fitting. This fitting presses...
The original fuel line fitting on the Keihen carb is a pressed in fitting made of brass and plastic. The plastic piece breaks off leaving the brass nipple in the carb. Harley makes a replacement fitting as well as the aftermarket parts suppliers. The Harley replacement is better because it's made completely of brass where the aftermarket replacements are made of brass and plastic like the original. To get the old fitting out, thread it with 1/4 X 20 tap and use a bolt, washer, and a deep well socket as a "puller" to get the old fitting out. To press the new fitting in, lubricate the fitting and the hole in the carb and use a vise to press the fitting in. Be sure to position the fitting correctly so that the fuel hose goes on in the right direction. I'm sorry but I don't have the part number handy. Your local dealer can look up the number easily.
Good Luck
Steve
Jun 07, 2011 | Harley Davidson FXSTS Springer Softail...
The diverted valve will not turn ,it worked when installed but won't turn now .how do I replace the diverted.
The spout unscrews from the wall.Take that part off and bring it to the store to match it.Then just screw the new one on.
May 18, 2011 | Moen 2995 Chateau Three Handle Standard...
Water is leaking around base of "spout" and
If you have properly replaced the diverter assembly, there is either a problem with valve or debris was left in the valve from old diverter when new diverter was installed. Disassemble diverter by pulling spout back off. remove new diverter and check valve. Cup your hand over faucet and turn cold water handle on to attempt to flush any debris left behind. Try several times then reassemble. If this doesn't do the trick then replace. Get a quality filtering system and take care of your new faucet by making sure it's dry and polished after use. You won't be replacing your fixtures as often from calcium and corrosion.
Apr 23, 2011 | American Standard 4271S 'The Standard...
I have a Delta shower assembly with a pull-down diverter. When I engage the diverter for the shower, half the water seems to make up to the shower and the other half is forced through the back of the...
One of 2 things is happening. Either the o-ring is shot, or you have a hairline fracture of the plastic around the brass adapter. The o-ring is a #18, but if there's a crack in the plastic you'll need to replace the spout.
Oct 03, 2010 | Delta Faucet Delta RP17453 Pull-Down...
Delta Faucet #RP320 Divert Assembly Logo
43 people viewed this question
Top Delta Faucet Plumbing Experts
Steve Wood Plumbing...
Level 1 Expert
joeiaaz
Level 1 Expert
Are you a Delta Faucet Plumbing Expert? Answer questions, earn points and help others
