Question about Kwikset Locks & Locksmithing
Kwikset lever install
How to install 44594/01 kwikset lever
  • 10 Answers
SOURCE: how do i rotate the kwikset cylinder 180?
try this powerpoint video I made and uploaded to youtube. It is quite primitive but if you can pause and read it at each step it may help. This was for the kwikset lever entry lock. Thanks,
Posted on Sep 18, 2009
rsmith972278
  • 160 Answers
SOURCE: how do i remove exterior handle kwikset titan?
You need to insert the key and turn it clockwise, then insert a stiff metal tool like a straightened out heavy paper clip into the hole on the shaft of the lock by the circular flange next to the door. Push it in until you feel it give and pull out on the handle at the same time. If you need more help please contact me.
Best of Luck,
RSMITH972278
Posted on Nov 14, 2009
  • 8404 Answers
SOURCE: how to remove a tumbler from kwikset entry knob ?
You need a kwikset removal tool. Search kwik set core removal tool to take you to a lock smith supply, or try to buy one locally.
Notice, purchase of this tool may not be legal in your juresdiction and MIGHT be considered burgary tools.
Posted on Dec 27, 2009
agent91
  • 2100 Answers
SOURCE: How to install kwikset door knob with lock
Are the holes in the door? Are you replacing the old lock? Need to know these things, or I will be typing a bunch of stuff you don't need. Most doors come pre-bored. If not, you need 2 bits, One is 2 1/8 inch cup bit, the forstner type is a lot more expensive, and a 1 inch paddle bit, again, the forstner bit is expensive. Measure up the door app 39 inches, unless there is a lock rail on/in the door, then measure to the center of that. Then on the inside of the door, measure back 2 3/8, most locksets now are adj for 2 3/8 or 2 3/4, you can use either one. You can drill either hole first, To drill your one inch hole in the edge of the door sighting along both sides of the door with your eyes crossed so you can make sure you are going straight, you don't want to bust through the side of the door. Then get the big bit out and drill from the mark till you just come through the other side, then back it out and drill from the other side so you don't tear out the hole. Your 1 inch hole should be all the way into the big hole.Then get you chisels, the sharp ones, put the plunger in the one inch hole, nice and straight, then mark the outside with a sharp pencil, cut the line with the chisel then cut out the waste about 1/8 to 3/16 deep, make sure it fits nice and tight, Predrill the two screw holes, or you will split the door.Get the lockset out, the key to the outside, and the button on the inside of what you are locking. Line up the holes, you might have to spin the button to get them to line up, then put in the 2 long screws. Mark the jamb with the striker, To get it right, put the striker on the door, hooked into the latch, mark the edge of the door with a pencil,then put the striker on the jamb, backwards, to the line you just marked, then out line it, use your 1 inch bit to hog out the middle nice and neat, cut the rest out the same way with the chisels, predrill the holes, you should be all set. OH the deadbolt? You didn't mention that, it goes the same way as the lockset, only the hole is smaller, 1 1/2, I think, you will have to check that. Now you know why people call carpenters.
Posted on Feb 17, 2010
  • 6 Answers
SOURCE: Kwikset Smart Key Deadbolt Won't Unlock
Kwikset Smart Key locks are complete junk. I am a locksmith and I am constantly going from house to house replacing these "dumb key" locks with original kwikset pin tumbler locks. What happens is either your key or the wafers inside the lock wear slightly, slightly enough to cause your keys to not turn, and since these locks cannot be picked due to a side bar system, they must be drilled off and thrown away when this happens Unless you have another access point to get in the house. If you do remove lock from the inside, throw it in the trash, buy original kwikset and replace.
Posted on Apr 29, 2010
How do i attach the door lever?
http://s7d5.scene7.com/is/content/BDHHI/24910-04
Kwikset lever handles are held on with hex set screws. A wrench is included in the package. It's either a 3/32" or 2.5 mm. Note that the lock must be unlocked to remove or install the outside handle.
Sep 06, 2014 | Kwikset Brooklane Venetian Bronze Entry...
Re-assemble a kwikset front door lever and knob type latch
Since the exterior side of the lock only has a keypad and no lever, I'm not sure what you mean by the "outside lever". Here is a clear, easy to follow video of the installation. Please carefully review each aspect of your installation against it to see if you can spot an installation mistake:
http://www.kwikset.com/Videos/Vitro/smartcode.aspx
Sep 03, 2012 | Kwikset 909 909-L03 Lifetime Polished...
Could you send instructions for thumb door handle ours fell apart and we don't know where the pieces fit....thank you
Sure, let me give you a link to the installation instructions for the Kwikset Lido(keyed lock):
http://s7d5.scene7.com/is/content/BDHHI/44593-01
If this is not what you had in mind, go to this page:
http://www.kwikset.com/Customer-Support/Product-FAQs/Search-Faq.aspx?prod=FAQ+Categories_Levers_Lido
and select the model most like yours. Clicking on the picture will bring up installation and warranty links, etc.
Please note that if I haven't been able to help you, then I urge you to contact Kwikset Customer Support:
http://www.kwikset.com/Customer-Support/Contact-Us.aspx
Jun 17, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
We have the thumb press elongated handle on the outside of the front door entry. I was ready to enter the front door when I pressed the thumb handle and the whole set fell apart. Need instructions to put...
For the Lido Keyed Entry, go to this page:
http://www.kwikset.com/Products/Details/Door-Levers/740LL-26D-SMT.aspx
and click on "Installation Guide", found under the red text " Technical Documents"
If I've steered you to the wrong lockset, the product main page foe Kwikset can be found here:
http://www.kwikset.com/Products/Categories/Handlesets.aspx
Feb 13, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
Kwikset 730LL-RH handle fall out, How to fix it?
I'm including a link to the installation/assembly instructions for the Lido LL730 3:
http://s7d5.scene7.com/is/content/BDHHI/44594-01
I'd recommend that you contact Kwikset Customer Support if you are unable to repair it:
Kwikset Corporation
Consumer Service
19701 DaVinci
Lake Forest, CA 92610
Kwikset Customer Service
Call: 1-800-327-LOCK (5625)
Here's the link for their customer service page:
Feb 11, 2011 | Kwikset 4 Lido Lh Passage Levers Satin...
Waustin@lnshow do i reset a kwikset 909 smart code lever? works fine with key.
Here's the installation instruction link for your lock:
http://s7d5.scene7.com/is/content/BDHHI/kwikset-smartcode
Notice that the above is a .PDF file type. That means that you need to have Adobe Reader or similar installed on your computer to view it. So if you are unable to view the file, download (for free) and install Adobe Reader first. You can get it here:
http://get.adobe.com/reader/
Feb 07, 2011 | Kwikset 909 909-15 Satin Nickel Smart...
I have a kwikset lever door lock, is there a diagram or manual available for it which shows the inner mechanisim parts?
No. Throw it out and buy something else. Carbine, Lockwood, Brava, even Gainsborough is better than kwikset.
Oct 04, 2009 | Kwikset Locks & Locksmithing
I recently purchased a kwikset jda-9760718-002
You can download them from kwikset here. Just choose your version of the lever, select Installation & Troubleshooting instructions from the search list, and scroll down to the .pdf document file listed in the next window.
But that lever is pretty standard, and there are also some kwikset installation directions here
You can use some pretty generic instructions if you just google "install lockset"., that may have some useful pointers.
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Jul 29, 2009 | Kwikset Sheridan Handle Set
Locks & Locksmithing Logo
121 people viewed this question
Top Kwikset Locks & Locksmithing Experts
Jim Thurston
Mike
marty morrison
marty morrison
Are you a Kwikset Lock and Locksmithing Expert? Answer questions, earn points and help others
