Question about Akai LCT2662 Television
Akai lct2662 remote control will not work red led march tv works
  • tom_schulty Jan 25, 2009
    the remot control works on other akai 2662
    but not this one no standby has auto exit no source has red led not r/g
    turn on power red on push like standby tv come on but not from [ REMOTE ] when tv is on no red led on
  • tom_schulty Jan 27, 2009
    no eperts not helpful it not the remote
  • 4,806 Answers
Hi there
sounds like the remote has lost its programing, have a look here for the correct procedures for None LCD and LCD remotes.
http://www.hifi-remote.com/forums/viewtopic.php?t=3943
Good luck and thanks for using Fixya!
Posted on Jan 25, 2009
  • 362 Answers
Hi Tom,
I am not sure I understand your problem completly.
Carefully clean the IR window on the front of the TV and the remote.
If you have a universal remote, program it to the tv and see if it works.
You may have a bad IR sensor , the universl remote should tell.
Let me know how it goes.
Lone99star
  • 10,515 Answers
It would seem the akai remote codes you have are not programed in the remote you should wright to akai and tell them 1000s of people you have chatted to have the same problem is there any way you could send me a replacement please or could you give me the codes and i will program them my self thank you hope you get this email or letter or phone call what have you to lose....
 Purchase a universal remote. would cost u @$14..However, it wld work with akai as well....
take care.
    Genius:
  • 2,920 Answers
You can buy a universal remote and use it for the tv.they are about 10.00 akai isnt the best tv to buy but they have their problems as well. try the universal remote and see if that helps
    Brigadier General:
  • 8,619 Answers
Hi
Try to change the batteries of you remote .
  • Rylee Smith
    Rylee Smith Jan 25, 2009
    The Infrared Sensor (IR) which catches the signal from your remote has been blocked by some obsticle or is faulty and needs a replacement, thats the reason remote is working with other TV and not this one .
AKAI 32" Power Malfunction
check all 1000mf-16v & 470mf-16v in power supply. may be blow.
May 06, 2010 | Akai LCT2662 Television
My akai tv does not turn on. we lost the remote and have to do it on the tv itself, I checked the power outlet and it is working. also checked that the tv cord was connected properly and it is as well.
I will say this is interesting I have 4 akai in my home and I repaired them all myself. first I would ask that you unplug the tv for 1 hour and plug it in and try with the manual pwr button.
if that does not work we wil have to go inside the case to look at the power pack and video board for what will need to be repaired9usually capacitors have been damaged).
let me know.
Jan 31, 2010 | Akai LCT2662 Television
LCT 2662 after caps replaced I loose backlight.
make sure the caps you installed are the exact replacements. Changing voltage capacity or timing will cause the circuit to fail.
Feb 21, 2009 | Akai LCT2662 Television
TV won't turn on
You will have a defective power supply if you remove back then remove the cage around the power supply you will see the defective capactors,maybe as many as 20 defective.replace all of them and tv should work like new.cost for all capactors should not run over 35.00
Nov 09, 2008 | Akai PDP4273M Television
LCT2662 Remote needed
AKAI E7501-050001 (#E7501-050001)
TV REMOTE CONTROLFor use with model #s: LCT2662, LCT2662N
Oct 21, 2008 | Akai LCT2662 Television
Akai LCT2662N Channel Changing Problem
there is a button that controls how many digits you can enter. it is located betwwn the 0 and source or below the 8 buttons
Sep 02, 2008 | Akai LCT2662 Television
AKAI LCT2662 Schematic
I was looking for the same thing- I found this, which I am 99% sure is the same TV under a different name - even the remote is identical.
MODELO: BSV-2652
May 24, 2008 | Akai LCT2662 Television
Akai LCD, Model: LCT2662
replace all the capacitors on the board. The ones that were originally place on the board are defective. I would replace them with the next larger voltage rated capacitor.
Nov 02, 2007 | Akai LCT2662 Television
Akai LCT2662 Television Logo
Top Akai Televison & Video Experts
Jaime Hernandez
Are you an Akai Televison and Video Expert? Answer questions, earn points and help others
