Question about VIEWSONIC VA Va1948m-led 1948m-led 19 class hd widescreen led lcd monit
Monitor keeps pwoering off after 20 minutes - VIEWSONIC VA Va1948m-led 1948m-led 19 class hd widescreen led lcd monit
Pwoer issue
I would remove all the conections to the PC.
USB; Monitor; audio; everything.
Unplug from the wall or mains.
While unplugged hold the power button in for a full minute.
Also check on the back of the tower that the Power Supply switch is on (- rather than o)
Next plug the computer directly into a wall outlet and try again.
Thanks.
Apr 19, 2012 | Acer Aspire One PC Notebook
No Signal
yes start the computer then keep pressed the key F8 untill the display comes then hightlight the option last good known configuration and select the problem will be solved
Mar 06, 2010 | Acer 22" X223w LCD Monitor
Acer Monitor Not Staying On
It sounds like there's a problem with the monitor itself. It may be that the lamp in the computer is dying, which would explain why it keeps going out. Other possibility is that the monitor isn't receiving power properly either through the cable or inside the monitor itself.
If your're not the kind of person who wouldn't mind opening the monitor up and hopping in there, then I recommend you take it somewhere it can be diagnosed like Best Buy.
Hope I helped :)
Nov 28, 2009 | Acer X223WB 22" WIDESCREEN LCD Monitor
The monitor keeps going blank after a minute or so
hey right click on your desktop.go to properties.in the propertes menu go to screen saver tab.click on the screen saver tab.in the screen saver tab menu you will see a tab called power.click on the power tab.change your settings there for the monitor.let me know if it works.
Sep 09, 2009 | Proview PL713B 17" Flat Panel LCD Monitor
Sceptre 20" Monitor will not stay on
First check the monitor sleep mode for your monitor in windows control panel, check that its not going into hibernation/stanby. if thats not it. and the monitor keeps shutting down. You may have to replace it newer models have more features and could be cheaper by saving you the hassel check newegg.com or orverstock.com
Jul 08, 2009 | Sceptre X7GNAGAV 17" LCD Monitor
Pl716s2 flatscreen
Hey...
Well, your lucks just run out....you got a busted backlight inverter.
Aug 22, 2008 | Proview PL713S 17" Flat Panel LCD Monitor
Off/on switch
check the power supply whether it has some dry joints by soldering the whole area.
Aug 20, 2008 | Gateway FPD2275W LCD Monitor
Proview monitor PL716s
you ave some blown caps on the vga board replace them and all will be well
Dec 28, 2007 | Proview PL913S 19" Flat Panel LCD Monitor
Monitor shuts down after 20 minutes
Sounds like the monitor is overheating. The internal power supply maybe going bad. Ray
Jun 19, 2007 | Kogi l7eh-ta ko 17" Flat Panel LCD Monitor
Screen blacks out
OK you need to try this monitor on another pc so as to write off a faulty graphics card. If your settings on monitor match the pc and youve tried the auto settings button, there is a faulty lcd for replacement.
Nov 10, 2006 | Samsung SyncMaster 510N 15" LCD Monitor
VIEWSONIC VA Va1948m-led 1948m-led 19 class hd widescreen led lcd monit Logo
Top VIEWSONIC VA Computers & Internet Experts
David Payne
David Payne
Are you a VIEWSONIC VA Computer and Internet Expert? Answer questions, earn points and help others
