Question about Pitney Bowes 9920 Plain Paper Fax
Sharp F0-1460 Hi My fax machine has been serving me well until I get an error display DOCUMENT JAMMED I have opened up all the lids,and careful looked for anything stopping it working. I dont know what to look for to solve this problem. Please help Ray
    Scholar:
  • 77 Answers
"DOCUMENT JAM" refers to your original document that you are trying to send. Lift the top of the Automatic Document Feeder (ADF) and look for a tiny peice of torn paper. If not, look for a stuck sensor flag (might look like a small plastic finger). If still no go, clean the roller that feeds the original, it may be worn out and slick. Hope it helps Ed
Posted on Jul 14, 2007
SOURCE:
How to reset error 5100
Jams in the Document Tray
When a document jams or misfeeds in the Document Tray, <OPEN COVER> and <SEE FIG. 1> <!!CHECK!! 5100> are displayed on the LCD.
Note
You do not need to unplug the fax when clearing document jams.
* When <OPEN COVER> and <SEE FIG. 1> are displayed alternatively
1. Press [Stop].
Important
Do not pull out the jammed paper manually at this point.
2. Hold down [Start/Copy] for a few seconds.
* The document will be fed out automatically.
* If the document is not fed out, gently pull the document out of the fax.
* When <!!CHECK!! 5100> is displayed
1. Check if any paper is jammed.
If jammed, make sure to take out all the jammed paper.
2. After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
Jams in the Multi-Purpose Tray
If paper jams in the Multi-Purpose Tray, <CLEAR PAPER JAM> is displayed on the LCD.
1. Gently pull any jammed paper out of the fax as shown, then press [Stop].
* Pull it gently in either direction.
* If you cannot pull the paper out, continue with the steps below.
2. Open the Printer Cover.
3. Gently remove the jammed paper inside the fax.
4. Press [Stop].
The fax returns to standby mode.
Sep 24, 2013 | Canon FAX-JX200
Faxing
How to clear the "Check Original " error message? Description: This error can occur if the document being sent or copied is not inserted properly, fed incorrectly or is too long. Follow the troubleshooting steps and recommendations listed below:
  1. Remove any paper that is not jammed from the ADF.
  2. Open the top cover by lifting the lever on the right side of the top cover.
  3. Pull the original toward the front of your fax machine.
  4. Close the top cover. Press down on both sides of the top cover until it clicks.
jam06.gifBefore placing the document(s) in the Automatic Document Feeder (ADF), verify the error message "CHECK ORIGINAL" no longer is displayed on the LCD. If the error message continues to appear on the display, unplug the unit for 30 seconds and then plug it back in.
Let me know if you need any further help
May 06, 2008 | Brother MFC-8440 All-In-One Laser Printer
How do I unjam a fax machine 1010
to clear document jam:
1 Open the front panel.
2 Carefully remove the jammed document.
3 Close the front panel firmly until it clicks
into place.
If the fax paper jams while you are receiving or printing, Remove jammed paper and press
Cancel appears in the message.
if the paper is jammed in the printing area
1 Remove the jammed paper by pulling it out
smoothly in the direction of the arrow as
shown.
If the paper tears when it is being removed
check to ensure that no small pieces have
been left inside the machine.
2 Press Cancel.
3 If this was a fax, reprint the fax. For more
information, see reprinting faxes on
page 29.
if the paper is jammed in the paper feed
area
1 Remove the jammed paper as shown.
removed check to ensure that no small
pieces have been left inside the machine.
2 Reload new paper with the print side
facing toward you.
3 Press Cancel when finished.
May 04, 2012 | HP 1010 Plain Paper Inkjet Fax
CHECK 5100
When a document jams or misfeeds in the Document Tray, CHECK 5100 are displayed on the LCD.
When CHECK 5100 is displayed
1 Check if any paper is jammed.
2 After taking out jammed paper, turn the fax off, then turn it back on with [ON/OFF].
If paper jams in the Multi-Purpose Tray, CLEAR PAPER JAM is displayed on the LCD.
1 Gently pull any jammed paper out of the fax as
2 Open the Printer Cover.
3 Gently remove the jammed paper inside the fax.
4 Press [Stop].
Feb 20, 2012 | Office Equipment & Supplies
Machine reads document jam,checked machine seems ok,cannot sent fax.
Hi there!
The error message that you are getting means there's a jammed paper inside the machine particularly in the feeder. This may also appear if the panel is not closed securely. Try to open the control panel and look for any pieces of jammed paper or debris. Closed the front cover or the control panel, it should display the regular screen date/time. Once you have the regular screen load the document on the feeder, the display should change and should ask you to enter the fax number.
Hope this helps!
Please rate if it worked, Thanks
Mar 30, 2011 | Office Equipment & Supplies
Display says line error and print out says jam
• Check the connection. The cord from the TEL.LINE jack to the wall jack should be no longer than
six feet.
• Make sure there are no modem devices sharing the same telephone line.
• Check with the other party to make sure their fax machine is functioning properly.
• Have your telephone line checked for line noise.
• Try connecting the fax machine to a different telephone line.
• If the problem still occurs, your fax machine may need service.
Clearing a jammed document
If the original document doesn't feed properly during transmission or copying,
or DOCUMENT JAMMED appears in the display, first try pressing start/memory . If
the document doesn't feed out, remove it as explained below.
Important:
Do not try to remove a jammed document without releasing it as explained
below. This may damage the feeder mechanism.
Jan 17, 2011 | Sharp UX A255 Plain Paper Thermal transfer...
Can not reset machine from Document Jammed mode.
you will have to take this to a service agent as one of the paper sensors has jammed
Apr 09, 2010 | Sharp UX P100 Plain Paper Thermal transfer...
Machine reads "document jammed"
its the problem of the rollers which pulls the papers they r worn out.I've seen this before repairing computers and asked about fax machines while I am there. There are rollers that cling on to the paper and move it through the machine. When the rollers are worn down they do not grip the paper. For a short fix you can get something rough like sandpaper, brillo pad, etc, and gently scratch the rollers to give them some traction. This will temporarily solve your problem until you can get the rollers replaced.
Jan 07, 2009 | Panasonic KX-FL541 Plain Paper Laser Fax
''Document Jammed'' error message
Open the document feeder and look for a switch actuator stuck in the down position.
Nov 19, 2008 | Panasonic KX-FL511 Plain Paper Laser Fax
"document jammed" but no paper in the machine
There are a few sensors in the paper path which can easilt dislodged when pulling paper to rapidly from unit. Check all sensor flags and make sure they are moving freely.
I’m happy to help further over the phone at https://www.6ya.com/expert/jayw_0e86fb055a7b73de
Jun 01, 2007 | Sharp UX P100 Plain Paper Thermal transfer...
Pitney Bowes 9920 Plain Paper Fax Logo
118 people viewed this question
Top Pitney Bowes Office Equipment & Supplies Experts
Adorjani Laszlo
Marvin
Marvin
john h
Are you a Pitney Bowes Office Equipment and Supply Expert? Answer questions, earn points and help others
