Question about Cell Phones
Battery removal on a htc one x mobile phone from Telstra
Rear cover looks very awkward to remove if in fact it does
Ajkill
  • 2035 Answers
SOURCE: Having a hard time removing cell phone battery cover
Model number of the phone.
Posted on May 17, 2008
SOURCE: how to remove face plate
how to remove a contact person in "my fave". motorola zoom 4x
Posted on Aug 01, 2008
  • 5 Answers
SOURCE: Removing Battery cover for cell phone
There are so many models out there and many different ways to remove battery covers.
Besdies the brand I also need the model of the cell phone in order to tell you how to remove the cover.
Try looking up the model from the place you purchased the phone from, if you purchased it online you most probebly can find the model number in the description of the listing.
Posted on Mar 11, 2009
kakee
  • 1268 Answers
SOURCE: want to remove battery in sprint htc touch phone
This unit rquires special kind of screw driver for mobiles or gadgets. Normally, its a star shape screw driver. You must take apart the unit's casing by removing all the screws for you to dry the unit. There's a cover at the back panel that you must remove first
Posted on May 07, 2009
  • 245 Answers
SOURCE: problem removing battery cover of cect i9 cellphone
Usually these covers slide off. Look at it carefully and you can see that there is only one direction it could possibly move. Push it in that direction with both thumbs. I am not familiar with that particular model.
Posted on Jul 25, 2009
My htc s1 is not getting switched on
Hello Dear:::
1.Check the device's battery level for at least two bars of strength.
2.If the battery level is low, charge the battery.
3.If the issue is not resolved, remove the back cover.
4.Remove the battery.
5.Wait 10 seconds.
6.Press and hold the W key.
7.While pressing down the W key, re-insert the battery.
•The device restarts and after approximately 15 seconds, the 'Recovery' screen appears
•Release the power button but *continue holding the home button*, for another 30 seconds.
Step
Thanks
Jan 11, 2013 | HTC One S 4g Mobile Phone - Gradient Blue...
Would like to unlock my htc desire from telstra network
There are many way to unlock your mobile by using box,software,code..I suggest you code is best way to unlock your mobile...If you need unlock code means you can get the unlock code here superunlockcodes.com to your mobile htc desire or otherwise contact the service provider...
Jun 07, 2011 | HTC Desire Cell Phone
Phone froze up cant put in security pattern..cant do anything.
Remove the battery cover, remove battery.... replace battery and cover.. power up phone. Good tips here: http://michaelquale.com/911134/how-to-remove-the-battery-cover-on-the-htc-hero/
Hope this helps :)
Jun 02, 2011 | HTC Hero Smartphone
My screen is frozen as well as a error message reading as followed,(Run FILEOP/windows/menu_FILEOP_Operation failed.
The problem you are experiencing with your phone is due to the fact that the windows operating system running on your phone has either jammed up/crashed,hence its experiencing errors while trying to load the operating system.
Here is a solution to your problem;
1.Put off the phone completely.
2.Remove the back cover and take out the battery.
3.Re-insert the battery and put it back on.
4.The problem ought to be solved by now,but if it persists it means the final solution is to re-run the operating system on the phone,which can only be carried out by a qualified software engineer.
Thank you for using fixya.
Mar 17, 2011 | HTC HD2 Smartphone
How can we replace battery?
This chair takes 2, U-1 batteries which are available locally and on-line at a steep discount. Make sure you get deep cycle gel batteries.
Remove the front battery box cover by pulling out the frame pin at the bottom front of the cover. The cover should lift up and off the frame.
Pull out the battery tray slowly and observe the connections on the four battery terminals. There is a connector (large, black 2 pin housing) to disconnect the batteries and pull the whole assembly out. If you cannot get to this connector, you can replace one battery at a time while the box is halfway out of the chair. This is a little more awkward and harder. Make sure you orient the battery terminals red to + and black to - . Install the batteries in the same orientation that you removed them.
If something gets disconnected you can open the rear electronics tray by sliding back the top rear cover or by removing by turning the 2 black pins (also called clip or stud) with a dime and a quarter turn counter clockwise (2 different designs). Reach in carefully and look for the large black 2 pin connector to the batteries.
You can save considerably by getting the batteries at a discount and doing the labor yourself.
Hope this helps.
Dec 10, 2010 | Pride Mobility Products New Pride Mobility...
My HTC Hero is frozen, is there a way to take the battery out?
Hi. Remove the battery cover then you can remove the battery. Here's how to remove the battery cover:
Aug 27, 2010 | HTC Hero Smartphone
Want to remove battery in sprint htc touch phone
May 07, 2009 | HTC Touch Cell Phone (Unlocked) - Soft...
Need unlocking code and steps for g1 phone
The only way to get the unlock code is to have T-mobile service for at least 90 days(unless you're lucky). Call the service help line and tell them that you are going over seas and would like the unlock code for your G1. They will need your account info as well as the IMEI number of your phone(this can be found under the battery on the phone). In roughly 24hrs. you will receive an e-mail from HTC with your phone's SPECIFIC code(codes don't work for other G1s).
HOW TO:
1. Turn off the phone and remove battery/SIM
2. Insert other carrier's SIM and replace battery/cover
3. Power up phone and enter unlock code in menu that comes up.
4. Enjoy your unlocked G1
Mar 16, 2009 | HTC G1 Smartphone
5 Telstra Icons On Samsung u900t
The U900 you have was got from a Telstra dealer it is very hard to have them removed without corseing errors with your hanset
Jan 28, 2009 | Samsung U900 Soul Cellular Phone
About removing sim from htc mobile
You have to remove the back cover, and on the left hand side there is a removeble cover (the silver strip on the side of the phone). When you remove that, you will see on the left the sim card. Press it in with you finger nai and voila.
Mar 06, 2008 | HTC Touch P3450 Smartphone
Cell Phones Logo
13 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
