Question about Pentax Optio S7 Digital Camera
On power up, lens extends camera beeps then retracts. The functionality of the camera is intact, if the play button is pressed with the power up button the pictures can be viewed, but normal power up the camera beeps and the camera retracts cannot take any pictures. This problem occurred when the camera was powered up too close to a surface blocking the lens from fully extending. Thanks for any help
  • 3 more comments
  • Tony McFadden Jul 18, 2007
    This problem has occurred with the camera before and has been fixed, i was just hopeing to fix it myself without sending it to pentax.
    thanks anyway
  • Anonymous Feb 17, 2008
    THe exact thing has happened to me. Turns on, beeps, retracts. Can still view pics. Don't know what to do...
  • Anonymous Mar 21, 2008
    so mine turns on then it doesnt show anything, then it turns off=((
    & it's my parents caaam ! i'm so screwed . & okaay i've
    never dropped it & there arent even any scartches
  • skidoo Apr 11, 2008
    On power up the lens extends but sound rough like the gears inside are messed up.
  • Anonymous May 27, 2008
    Lens extends,camera beeps,then retracts battery OK.
    Tank-you for any help. Maria
Normally, the zooming lens will retract back to its origin if there's something blocking its mechanism when it is powered-up either externally or internally.
I just hope that in your case it is external. But if not, probably it is its focusing lens gear is not aligned or wear out (internal mechanical problem), and only Tech support can handle this.
Posted on Jun 25, 2008
I had this same exact problem with my optio s7, and couldn't find an answer online to fix it.
I tried tapping the camera on a table (not too hard - just a firm tap), and it works normally now. I know this sounds a bit extreme, and perhaps you have already solved your problem, but this solved a lot of frustration for me.
Posted on Oct 24, 2007
    Genius:
  • 2,985 Answers
Damed lens mechanism Not repair will be economic Check out the Pentax Tech support but I fear a new camera is on the horizon.
Posted on Jul 15, 2007
  • Anonymous Jul 15, 2007
    Oh dear my typing- this should read
    Damaged lens mechanism
    No repair will be economic
    But I fear a new camera is on the horizon.
    Not that it make your problem any better
SOURCE:
Hi i had an e18 error appear and the lens was stuck. the lens is now going in and out but the focus is compleatley shot every thing is blured any ideas?? thanks
"E18" indicates an error that involves the lens unit or lens cover in your camera .This error appears where the lens is prevented from properly extending or retracting .The error may also be displayed if the lens camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera.Hold the camera so that your fingers do not touch the lens unit when you are shooting. Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case.If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred and might require service from canon. Or else try pressing the power button on and held it down while extending the zoom lens. The lens will extend out and the camera will be freed from the error.
Thank you !!
Jun 22, 2010 | Canon PowerShot SD550 / IXUS 750 Digital...
Digimax S800 Samsung : Lens won't retract
check first if battery is ok, maybe your problem is your barrel, if barrel not function properly you need to change motor or barrel allignment. if barrel is ok you have short circuit in your assy pcb main.
Apr 23, 2010 | Samsung Digimax S800 Digital Camera
Three beeps when i try to turn it on
i had the same problem a while back. I fooled around with my camera lens a bit and it turned out that one side of the lens was sticking out a bit. I pressed down on this and pushed the power button and it worked. The next time I turned it on the same thing happened but if you keep doing the same thing it should work.
Hope this helps!
Aug 21, 2009 | Samsung L100 Digital Camera
My samsung l830 camera lens is stuck open and when i press the power button it beeps 3 times and remains blue then does nothing
If the lens on the camera is stuck out, look to see if it's a little crooked. If it is, try to gently straighten it. If it still won't retract, try to gently push it in as you turn the power on.
If it won't turn on (the green light blinks and it beeps 3 times) push and hold the 'power' button and the 'play' button at the same time for a few seconds - it worked for my S730. Good luck!
Jun 28, 2009 | Samsung Digimax L830 Digital Camera
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
HELP
This happened to me once. SOMETIMES you can correct this yourself. The lens must be extending from the camera at EXACTLY 90 degrees if the lens is crooked, then straighten it, gently! If you succeed, the lens may retract as it is supposed to. You could also futher damage it with this procedure, so THINK ABOUT IT FIRST.
Mar 08, 2008 | Polaroid i733LP Digital Camera
Nikon L3 Lens wont extend
Hi:
If the camera has not been abused, such as dropping, impact of some sort, or restricting the extending lens, then there is an internal problem.
See my other posts on suggestions of selling it.
Nov 27, 2007 | Nikon COOLPIX L3 Digital Camera
E18 Message - Beeping.
The E18 error message relates to a problem with the zooming mechanism (lens would not retract or extended) Press the power button on and hold it down while extending and twisting the telescopic zoom lens. It might fix your problem. In any case it could not make it worse Good luck!
Sep 13, 2007 | Canon PowerShot A520 Digital Camera
Non-functioning camera
open the unit. look for anything electrical disconnected from sloppy factory
May 19, 2007 | Kyocera Finecam S5R Digital Camera
Pentax Optio S7 Digital Camera Logo
253 people viewed this question
Top Pentax Cameras Experts
Ekse
Jerry Greenberg
Jerry Greenberg
FIKRET UNALIR
FIKRET UNALIR
Level 1 Expert
Are you a Pentax Camera Expert? Answer questions, earn points and help others
