Question about Welding Tools
Where can l buy parts for a astro 110 power mig
5 Suggested Answers
SOURCE: wire feed assembly
go here and buy the parts i have one too, fix it and sale it!!!!! (JUNK WIRE FEED )
http://store.daytonamig.com/wifeteas.html
Posted on Jul 25, 2009
  • 71 Answers
SOURCE: gas leaks from the torch handle
sounds like it needs a new tube inside the torch handle
Posted on Nov 07, 2009
J-Chris Ward
  • 731 Answers
SOURCE: what are the hot and negatives on my astro power
If you use argon gas the gun is positive and the clamp is ground/negative. If no gas is used then it is the opposite
Posted on Feb 05, 2011
  • 436 Answers
SOURCE: I'm looking to replace the
Easy enough, Your gas nozzle is compatible with a tweco part number 21-50, this nozzle has the insulator included
You can locate at any local weld supply like MSC Industrial or Praxair.
Hope this helps
Thanks
Please rate FIXYA
Posted on May 20, 2011
Astro power powermig 110
Ebay is a maybe. Guns are somewhat interchangeable, so it might be better to get the gun which has the tips available more readily.
You might try your local welding shop first, followed by an online vendor who carries perhaps Tweco, Northern Tool, Enco, Harbor Freight maybe.
Sep 20, 2012 | Welding Tools
I need a new gun for my Powermig 110 the triger brok off any Idea where I can find or if Tweco makes one that will fit.
If you can afford it upgrade to the 140 or bigger. Tools are also a great investment. Don't buy cheap. Look at ebay for replacement parts for the 100. When you go to ebay look at the feedback % and how many times they have sold, not bought. I've had good luck there but I am very picky.
Bryan
Feb 07, 2012 | Astro Pneumatic ASTRO ECONOMY SHOP TOOLS
I'm looking to replace the mig gun on a Power Mig Astro Power 110, but would like to replace it with a Tweco. Any thoughts? Thanks....Bob
Hope this helps
Thanks
Please rate FIXYA
May 20, 2011 | Astro Pneumatic ASTRO ECONOMY SHOP TOOLS
I HAVE A POWER MIG 110 DOES NOT FEED WIRE UNLESS YOU HOLD DOWN ON ROLLER.I HAVE CLEANED ROLLER.THIS WELDER CAME WITH 030 WIRE.ALSO WHAT THICKNESS OF METAL CAN THIS WELDER WELD. THANK YOU JIM
Hi:
If your drive rolls need an extra pressure on them, that means you are using an oversize rolls, you did not mention what kind of wire is it (solid or fluxcore) probably your drive rolls are 035.
If youa re using fluxcore wire (no gas needed) the you should buy a knurled type roll that will cure the problem. Your machine is capable to weld up to 3/16" thickness using flux core wire or 10 gauge using solid wire-gas.
If this was useful to you please vote, thanks.
Apr 14, 2011 | Astro Pneumatic Welding Tools
Hi, I have a Astropower Powermig 110 and the gun noozle keeps coming out. I have no problem replacing this but I have no Idea on what replacement part to buy. The gun (handle) is red in color with a lever...
Hi:
Your gas nozzle is compatible with a tweco part number 21-50, this nozzle has the insulator included. You can find it at any Praxair welding store. Price is around 12.00 bucks.
Mar 04, 2011 | Astro Pneumatic ASTRO ECONOMY SHOP TOOLS
What mig welder would you I buy to restore a old car.
I always tell my customers that the best machine for a body shop is a millermatic 212 if you have 220V available if not, go to a Millermatic 211 this is one is a dual voltage unit 110V/220V. if you can afford it buy a spool gun SG100 for all aluminum parts, the machine will cost you 999.00 and the spool gun 215.00. Best investment ever for your shop.
Oct 28, 2010 | Clarke Power Products Clarke 130EN Mig 110...
Does anyone know who make Astro Power wire welders. Im in need of parts for one .
As far as I know, they are made by Cebora which is an Italian company. Try welding-direct.com as well, you should be able to search for parts through them.
Good Luck!
Sep 03, 2009 | Astro Pneumatic Welding Tools
Wire feed assembly for a Astro power mig welder 110
Jul 11, 2009 | Miller matic 140 Mig Welding Package W/As...
Gas leaks from the torch handle
Mar 28, 2009 | Welding Tools
Have a 110 volt mig wire feed. motor slows to a
To get parts for your welder you'll need to have the serial number off the tag on the case. This problem could have other causes, have you:
Checked the tension on the wire spool? You ought to be able to pull the wire by hand easily.
Checked the tension setting on the pinch rollers? Too much tension can drag down the motor speed.
You could also have a bad control card depending on which model wire feeder this is.
Regards,
Carl
Feb 28, 2009 | Hobart Welding Tools
Welding Tools Logo
143 people viewed this question
Top Welding Tools Experts
Bill Boyd
Are you a Welding Tool Expert? Answer questions, earn points and help others
