Question about Fisher and Paykel GWL11 Top Load Washer
Beeping Washing Machine
My Fisher and Paykel washer seems to do the same thing as the others have posted. It starts the wash cycle then decides to stop and start beeping, and flashes the cold and hot water lights. If I press start, it will start up again, but then just stops and starts beeping again with the same flashing lights about 2 minutes later. I think I might need the new hall sensor that you speak of, but I don't know where to get it as I am in California, U.S. If you can point me in the right direction or if I can get that part through you, can you please contact me? Thank you.
I know that this reply is way too late, but it's for the benefit of anyone following this thread looking for an answer. This problem is usually caused by moisture damage on the lower edge of the power and processor pcb. remove the processor unit open it up, and look at the bottom of the pcb. if htere is water damage (scale, corrosion etc) lightly clean the area with some very fine emery paper, wipe it clean, and seal it with a NON-CONDUCTIVE waterproofing agent (ie fish oil, or even some NON-GRAPHITE grease). this should fix it.
Posted on Jan 16, 2008
  • Fisher and P... Master
  • 909 Answers
DIFFICULT CALL AS THE HALL SENSOR NORMALLY INDICATES OR IS USED FOR PRECICION TEMP. CONTROL.IF THE TEMP. WERE INCORRECT, IT WOULD SIMPLY CONTINUE THE CYCLE AT AN INCORRECT TEMP. I FEEL BOARD IS DEFECTIVE.
Posted on Jul 19, 2007
2 Suggested Answers
ngfam1
  • 639 Answers
SOURCE: Hall Sensor Fisher & Paykel mw051
Discount Parts
Major Appliance & Consumer Electronic Parts. TOLL FREE 1-(888)-338-3790 8:00AM - 12:00 MIDNIGHT 7- DAYS A WEEK
Here is a good parts discounter we use. If in stock they ship quick .
Please give me a good rating before you sign off fixya.com
Posted on Sep 02, 2008
Fisher & paykel IWL12 Fault code 12
Your water inlet valve is likely defective. The supply hoses behind the machine lead to the watervalve.
Jan 08, 2013 | Fisher and Paykel Fisher Paykel Intuitive...
Last cycle completed, maching beeped and washing taken out. Machine light is on rinse cycle and beeps will not reset to start new load.
Hi just read your posting.From the information in your posting you mentioned that the rinse light is on when the machine is beeping.Starting from the left to right on the wash progress lights which lights are lit when the machine is beeping,Is it the 1st and 6th or the 3rd and 7th etc?Please reply with this additional information and i am sure i can help you rectify your machine.Looking forward to your reply.
May 17, 2011 | Fisher and Paykel GWL11 Top Load Washer
My fisher and paykel washing machine is not starting a cycle as it is not getting any water. The pipes are turned on and is properly connected. It results in service light(spanner icon) flashing with a...
Hi just read your posting.Now when the machine beeps do any lights light up to indicate an error code?You have mentioned the spanner shows up but do any others light up as the machine is beeping?Please reply with additional information and I am sure I can help you.Looking forward to your reply.
Oct 04, 2010 | Fisher and Paykel WA37T26G Top Load Washer
Washing machine pumps intermittedly when filling up and then wont progress to the next cycle it stats beeping and 2 lights come on one each end of lights board
Hi just read your posting.Could you please confirm the model number of your machine for me.Now you mentioned in your posting the 2 lights that are lit when the machine is beeping are the 1st in the row and last.These lights are in a row of 8 lights so starting from the left to right the lights that are lit are 1 and 8.Is this correct?Please reply with aditional information on the questions and I am sure I can help you.Looking forward to your reply.
Oct 03, 2010 | Fisher and Paykel Fisher & Paykel Washer
Our Fisher Paykel washer shuts off during wash cycle and makes a beeping noise that intermittently comes and goes. There is also a small leak at the right front part of the washer.
Hi just read your posting.I need to know the model number of the machine.Also when it beeps do any lights light up or any error code appears on your display if you have that model.Please reply and I can help you rectify this problem.
Jun 03, 2010 | Fisher and Paykel GWL11 Top Load Washer
Spin Led stays on and beeper beeps
this spin light that is on is a fault code no:1 which means the electronic motor control has a memory problem solution replace motor control module ... hope this helps..:0)
May 24, 2010 | Fisher and Paykel GWL11 Top Load Washer
Fisher & paykel smartdrive 508 filling slowly
remove the hoses and check for any kind of clogging or restriction in the line there may also be a problem with your fill valves
Mar 08, 2010 | Fisher and Paykel Fisher & Paykel Washer
On our Fisher and Paykel, the spin cycle does not
ok guest you can set a fisher and paykel machine to skip one rince cycle so as to save water,
Feb 20, 2009 | Fisher and Paykel GWL11 Top Load Washer
Fisher and Paykel GWL11 Top Load Washer Logo
244 people viewed this question
Top Fisher and Paykel Washing Machines Experts
Dan Webster
Dan Webster
Owen Barnes
Are you a Fisher and Paykel Washing Machine Expert? Answer questions, earn points and help others
