Question about HP DeskJet 5550 InkJet Printer
My hp 5550 printer won't print. I refilled the black ink cartridge manually. The color cartridge might be empty. If its empty will that make the printer not print?
  • 3 Answers
Yes, remove the color cartrage and it will print
Posted on Feb 13, 2009
How can I trick my hp color laserjet 3500 to keep working with one of the ink cartridge empty???
Some printers offer the option of printing in Black only in Preferences so you could try that. Another choice is to remove and reinstall the cartridge as sometimes it will reset. If your black cartridge is empty, the color cartridge can print black for awhile but it is probably more expensive per page to do it that way. If the color cartridge is empty, then it would be probably cheaper to print from only it.
You could also inject so ink with a needle into the empty cartridge then set your printer to not use that cartridge but this can make a mess unless you know how to refill cartridges at home.
Jun 30, 2011 | Office Equipment & Supplies
How to refill the cortrideg hp deskjet f4288.
Hi
the most important is to remove all
the air from the cartridge that has
left inside durring refilling that is why
professionals are using special machines
that refill in 0 air πρεσυρε using vaccum pump
you can check here a video on how to refill
with out any special equipment
Hope I had help you
Dec 08, 2010 | HP DeskJet F380 All-In-One Printer
1. Replaced Color and Black ink cartidges on my HP D5160: Color cartridge - NEW Black cartridge - REFILL SYMPTOMS> Red flashing exclaimation LED, black ink cartridge appears empty (0 dots in the...
Black printer ink in HP Printer may fail to be recognized by the printer. Most times an error message will be sent indicating that something is wrong with the black print cartridge. Sometimes the printer may accept to print with the black ink, but the printouts may have horizontal lines and very illegible letters. In such a case a manual cleaning of the print head should be carried out. In doing the manual cleaning, one should spray Windex heavily on paper towel and wipe off the surface of the print head.
http://en.kioskea.net/forum/affich-40171-printer-not-printing-black
Oct 26, 2010 | HP Photosmart D5160 InkJet Printer
HP5550 printer is printing everything in green. We have true HP cartridges
So, your "blue" and "yellow" ink-cartridges are OK, and are mixing to produce "green".
But, either your "red" ink-cartridge is empty, or the ink-jets that shoot that colour onto the paper are BLOCKED.
Run a print-head-cleaning-cycle, using the HP Support Tools that were installed from the HP CD-ROM, and then, if necessary, replace/refill the "red" cartridge.
Aug 30, 2010 | HP DeskJet 5550 InkJet Printer
HP Deskjet 5550 quit printing red color. Installed new color cartridge HP57. Quit printing red again after 5 pages. Is it a printer problem or cartridge problem?
Have you check your color cartridge if they are properly installed.
Make sure your are not using a refill cartridge.
Replace your tri-color cartridge with original an HP tri-color cartridge.
Aug 26, 2010 | HP DeskJet 5550 InkJet Printer
I have an HP 5550 printer. The Ink Cartridge light continually blinks (and nothing prints) when I have both the colored and black cartridges installed. When I remove the black cartidge, it works fine and...
More than likely you have either a defective 56 (black) cartridge or it's empty. If you have Windows XP you may go to control panel and select printers and then right click to get to properties and preferences. From one of those you can get maintenance and attempt to do a clean and see if that works. If you have a cartridge refiller in your area take the cartridge to them and get it weighed....they'll know if it's empty or not by the weight. If you're lucky enough to have a kitchen scale that weighs in gms then weigh it yourself...if it's empty then it will problem be in the mid 20's vs. mid to upper 30s when it's full. EBAY has lots of 56 cartridges for sale and they will usually work just fine. The tri-color ones are more of a crapshoot.
Aug 14, 2010 | HP DeskJet 5550 InkJet Printer
My printer is printing to much pink when I print a picture
One or more ink in the color cartridge runs empty
change or refill your color cartridge.
Sep 09, 2009 | HP DeskJet 5550 InkJet Printer
Can't find ink levels on my printer
I just had this same problem on my Deskjet 5550 printer. The orange light (ink indicator) was staying on. I found out that all you need to do is just open the front cover to the printer. If your printer is running out of ink, the print cradle will move to either the far left or far right side. If it moves to the far left side, the BLACK cartridge is low or empty and should be replaced. If the print cradle stays on the far right side, the COLOR cartridge should be replaced. Normally, when you open the front cover, the print cradle should move to the center. Hope this helps!
Aug 11, 2008 | HP DeskJet 5550 InkJet Printer
Ink cartridge light keeps blinking
you need to print only in black if that is all the ink you have, and also you need to remove the color cartridge as it still registers in the printer as able to be used, although it is empty or near so. Did you remove the tape over the print head fron the new ink cartridge? Do a print head alignment, or use the toolbox icon to tell the printer that you just replaced the cartridge. Some HP models chip the ink cartridges so even a refill wont register as a full tank and the printer wont print. chip needs to be reset (difficult) or just replaced with a new cartridge.
Jul 07, 2008 | HP DeskJet 940c InkJet Printer
HP DeskJet 5550 InkJet Printer Logo
190 people viewed this question
Seeker5211
Seeker5211
