Question about Baby Gear
Need replacement center support slat for WM1646
We have another Home Sullivan bed that has a lot more slats. This one only came with three. How can I order more slats and leg sets for those slats?
If it is new then just return the bed or ask the place you bought it from to get you more slats.
If you bought it used order some.
If your are ambitious you can take a slat to Home Depot and they can cut and make you some more.
Sep 08, 2015 | Furniture
Under the oil filler cap on my Volvo s40,there's only what I describe as a slatted cover can I remove it to fill engine and do I need to replace it
There was no slatted cover on my S40,the slatted cover on yours sounds like a custom filter put there to prevent any foreign object from falling into the engine space, don't remove it . If you do remove it remember to put it back
May 25, 2015 | Volvo S40 Cars & Trucks
How to fix laminate floor tiles gaps?
First, you need to get to one edge on the narrow side. (Where the slats run toward)
Second, you need a mallet and a hook tool.
Essentially, you need to put force on the edge to push the slats/planks together.
The mallet is used to put a lot of force on the slats to push them together.
The hook tool is inserted at the end of the row of tiles/slats/panels. The mallet is then used on the other part of the tool, so every hits force is transferred to the tile.
The slat/tile then will slightly shift toward the next one. Eventually this will put them together. Probably 4 to 8 mallet strikes should do on each row.
If this is an already installed floor, you may need to take the floor trim board off to get access to the edge of the tiles.
Jan 25, 2015 | Building Materials
Lights not working, and can't find the ballast location
The ballast is located down by the compressor if you take off the cover the ventilation slats. Then in the very center where there is a plug from the compressor plugged into the side of the center support as a cover on the front of that open the cover and inside you'll find The ballast.
Mar 09, 2013 | True GDM-69 Refrigerator
What is a slat bed?
A slat bed is a type of bed with built-in frames that support the mattress without the use of a box spring. The slats run parallel to each other and are secured on each end to the frame of the bed.
Aug 19, 2012 | Furniture
I neede an instruction booklet on my dorel alexander wm1646c i can't put it together
On the condition that I am not to be held liable for any damages associated with following the instructions that I've scanned and made available, you can find the instructions for the assembly of the Doral wm1646 wm1646c and wm1646w sleigh bed here:
http://www.krenim.org/jeff/WM1646-Dorel-Asia-SRL-Toddler-Bed.pdf
Again, by using these instructions, you agree to not hold me liable for any damages, injuries, or any way liable.
I'm making these instructions available without any warranty.  I simply scanned them and put them into PDF format.
Doral Asia SRL Toddler Bed models WM1646, WM1646C, WM1646W
Sep 01, 2010 | Dorel Alexander
I need a replacement handle
I had to replace all the wood on my grill. I used a wooden clothes dowel rod for the lid handle (planed one side flat, routed a grove for the insert and kept the old wooden insert), replaced the shelves with 5 in. redwood fencing slats (2 per side works better than the original 3 in. slats), and used a smaller dowel for the bin handle. It is now better than new.
Jun 28, 2010 | Patio Classic 2000 Series Grill
Need instructions for toddler bed dorel wm1646
May 11, 2010 | Dorel Alexander
I need owners manual for a dorel toddlers bed model wm1646c
Apr 23, 2009 | Baby Gear
Keypad
Slats, on each side of the top consol there is a clip. Slide a putty knife under each end and push on the clip. The top should pop up. From there you should be able to see how the end caps are removed so you can replace the touchpad panel. Catriver...post back.
Dec 10, 2006 | Whirlpool Calypso GVW9959K Top Load Washer
Baby Gear Logo
77 people viewed this question
Top Baby Gear Experts
Dorel UK
Dorel UK
Jennifer Rock
Jennifer Rock
Are you a Baby Gear Expert? Answer questions, earn points and help others
