Question about Vehicle Parts & Accessories
Manual for a clifford remote fcc id cz57rrtx12r
Clifford auto alarm remote
insanegtp
  • 112 Answers
SOURCE: Car Alarm
Key on, push the button, if that doesn't work, please post with model #, you can find that by looking under dash and finding system...
Posted on Jan 24, 2009
  • 87 Answers
SOURCE: I NEED PROGRAMING INSTRUCTIONS PLEASE!
Copy and paste or click - then program!
http://www.directed.com/guides/manuals/og/viper/429V.pdf
Posted on Jun 02, 2009
  • 33 Answers
SOURCE: battery went dead,clifford alarm locked the engine
Assuming that all is well with the vehicle's electrical system (fuses, etc...), the following should work, as Viper/Clifford uses the "fail safe" method of starter disable, and it only works to lock out the starter when the alarm is functioning properly and in the armed state.
That system has a "starter kill" system. When the alarm is actived, the starter kill is engages, and won't let the starter get voltage from the ignition switch. First thing I'd try is connecting the car's battery while the ignition key is turned to the "on/run" position. Cycle the alarm to arm, then disarm, so that the LED is not blinking. It also may require using the manual override button/switch (with the key on) to reset the alarm. Should start after that.
If all else fails, reconnecting the starter wires back together (they are spliced and running through the alarm via a SPDT relay.
Posted on Oct 23, 2009
  • 7 Answers
SOURCE: lookin for a install guide for a Clifford Matrix
I should have one of those, send me your email address ti m.kite1@yahoo.com
Posted on May 13, 2010
  • 139 Answers
SOURCE: will the excalibur touch remote
The Touch remote can be used with any Echo compatible systems. These systems can be identified by their model numbers. Systems ending in E, EDP and EDPB are Echo compatible.
Posted on Dec 12, 2010
GTI. How can I get my Clifford alarm to operate the central locking?
My best advice is to contact clifford direct and explain your problem normally very helpful.
Mar 02, 2016 | Seat Ibiza Cars & Trucks
Clifford g5 alarm how do i reset it after i was checking fuses it wont let me start the car
The car won't start because the Clifford alarm has a starter interrupt wire where the start wire runs through the alarm system module/relay. The unit then must still be active for the car not to start. If pressing the disarm/unlock button on your Clifford key FOB does not turn the system off, you will after to do it manually. You will need to locate the manual override button installed somewhere in the car that is connected to the alarm system. Turn the ignition switch to "on" or "run" and within 10 seconds press the manual override switch. That will turn the alarm system off and allow the car to be driven normally. I would then take the vehicle to an authorized Clifford or other DEI (Viper) install shop and have them diagnose your apparent problem.
Jul 31, 2014 | G5 IntelliGuard 770 P/N 919621 Car Alarm
Constant sounds coming from my truck alarm
Pull fuses until it goes away. Also pull relays you could hae a bad relay
Jan 03, 2014 | 5704x 570.x 2-Way Security and Remote...
Lost key to alarm
You will need to contact Clifford and provide the alarm unit serial number and some other details, they should then be able to send you a new key. Failing that, call a car recovery service (AAA, RAC ADAC or AA) they can usually help.
Jul 21, 2013 | Clifford 507X Security alarm + Remote...
I need a Clifford 50.7x installation manual
go to www. fitnessmanualsonline.com and download for freeGod bless youcreateLink
Dec 14, 2012 | Clifford Matrix 50.7X - Car Alarm with...
The indicator light (blue) on the sensor that attaches to the windshield is flashing repeatedly. My remote is also not working.
Hi ,sounds like a Clifford well known for problems would suggest calling an alarm specialist for you alarm,but usually cheaper just to have a new alarm fitted.
Aug 06, 2009 | Vehicle Parts & Accessories
I need help to reset the car alarm. There is no keyless remote. It's a clifford alrm. It started fine then when i turn the car off the alarm light was blinking and now i can't start the car
Look under the dash for a little button that youll push to bypass the alarm. If not one you will need to disconnect the alarm sysem and remove it. It is useless to you anyway without the key pad
Jul 31, 2009 | 1994 Pontiac Bonneville
Car alarm wont turn off
Try changing the batterys in the remotes mate
Feb 16, 2009 | OEM Systems Vehicle Parts & Accessories
Vehicle Parts & Accessories Logo
231 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
