Question about Kicker CVR12 Car Subwoofer
Subwoofer/speakers are hooked up to my amp but making bad noise
Ok I have a kicker subwoofer and I'm not sure what kind of speakers or amp I have, but when we connected the sub up first everything worked fine, then we started adding speakers to the amp but when we turned it on both the sub and speakers make this awful screeching noise. What is wrong? Did we blow the ground wire? Please help!!!!
It sounds like you have some wires crossed or a bad ground
Hope this helps
Posted on Jan 26, 2009
When i turn my two 12" kicker l7 up they cut out
You could be having an amp overload condition. Make sure your speaker impedance matches the amp specification. Esp if you have bridged the Amp the impedance should be at least 4 Ohms and not below. When you connect two 4 Ohms speaker in parallel the total impedance becomes 2 Ohms !!!.
Sep 26, 2011 | Car Audio & Video
How do i wire two kicker l5's already in a box
if you have an amp then you hook it up normal... left side + from amp to + to speaker... - from amp to - to speaker, and same for other speaker....
if no amp then i'm not sure your radio will push that big of speakers, but you would hook them up normal.... hope this helps.....
Apr 14, 2010 | Kicker Solo-Baric L5 Car Subwoofer
Does not want to work
to make sure it's the subwoofer at fault and not the amp, speaker wire, rca's, radio, power, or ground wiring, you should, if possible, hook up a known good subwoofer to see if it works properly. if it doesnt, check fuses, grounds, the remote amp turn on wiring, etc. it could even be something as simple as a setting on the stereo itself. if the substitute subwoofer does work properly, double check to be sure the original sub is wired correctly. if it is, i'm afraid you've got a faulty/bad subwoofer. I hope this helps and good luck!
Feb 17, 2010 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Amp 4 a Kicker S17L7
just make sure your kenwood amp can at least handle a 2ohm stereo load.Most amps now are able to .Your amps manual should list this or go online and check for that model .You basically have 2 subs in one allowing you to use one sub box in stereo mode.And just hook it up like two speakers left and right ..make sure amp has a crossover so that you only get bass at your woofer
Jul 30, 2009 | Kicker Solo-Baric L7 S12L7 Car Subwoofer
Amp goes into protection
make sure the impedance is right for the amp you're using. If you're using a 4ohm amp and a 2ohm sud that may be the problem. It may be overdriving the amplifer which is bad and can cause damage to the amp. Hope this helps.
Jun 01, 2009 | Kicker 12" Solo X Subwoofer S12X - 5000...
Subwoofers not bumpin, amp is still on
Check to make sure there is a good input to the amp. Next check each sub to another source to make sure they are good. Look for any reset on the amp.
Apr 26, 2008 | Kicker CVR12 Car Subwoofer
Need help bridging
First check your gain it may be turned down. I personally dont bridge speakers. I put each speaker to its own channel on the amp.Make sure positive to positive and negative to negative. Try hookin up two speakers to the amp (not bridged) and turn your gain up around half way. Make sure you amp is switch to lowpass not high since most amps have crossovers built in now. The more speakers you have the less output from each speaker from one amp youll get.
Mar 02, 2008 | Kicker 01C8VR4 Car Subwoofer
Subwoofer wiring diagram
parallel wiring. hook all 4 positives together and run to the positive output from the amp, hook all 4 negatives together and run to the negative output from the amp.
hope this helps,
trin
Nov 19, 2007 | Car Audio & Video
Kicker CVR12 Car Subwoofer Logo
1,224 people viewed this question
Top Kicker Car Audio & Video Experts
Tygh Duval
Tygh Duval
hoyzee1
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
