Question about BenQ MX613ST
Mx613st goes blank
Goes blank for a few soconds when i am using it, minutes later (15 or 30) goes blank again sometimes 1 or 2 minutes past last time.
Honeywell Chronotherm iv Plus power cuts on and off
There's a trouble shooting guide here, you need to check for the presence of 24V when it goes blank, and trace back to where it's disappearing (I assume it is losing the 24v, if not you'll need to go through the installer setup or read on...
My first thought would be to check the wiring which has been touched last if it started doing that after you had coil replaced.
As an aside I'm not sure which model you have but if it has batteries you should replace them (I don't think it does have batteries but not seen a model iv so I'm unsure)
https://customer.honeywell.com/resources/techlit/TechLitDocuments/69-0000s/69-1410.pdf
May 12, 2014 | Honeywell Programmable Thermostat Heater
When the TV is on for about 10 minutes, the screen goes blank and all the lights on the front flash. Then about 1 min later the screen comes back on. Then about 10 min later it does this again. Sometimes...
approaching end of life!
The problem could be in many places and it may not be entirely possible to online diagnoseuntil it stops altogether.By then the repair cost has accellerated.
Most times this is caused by a faulty set of capacitors or even the video control drive itself. It may be time to have it tested before it does result in major failure. An experienced tech will be able to test the voltages to endure they are within tolerance and find the offenders before they take out other components that will make the repair almost untenable. Non of this is DIY.
Please rate my help++++Thanks for using FIXYA
Jul 01, 2010 | Hitachi UltraVision CineForm 55VG825 55"...
Asus Monitor boes blank and comes back after power recycle
1. You can see images on the screen for a few minutes. That means there is nothing wrong with your computer.
2. When your screen goes blank, if you disconnect and then reconnect the monitor, it shows fine again for a few minutes before going blank (or dim) again. That means the problem is not with you video card.
3. It always shows the image after reconnection for exactly a few minutes before going blank again. yes? this means that there is nothing wrong with your cable.
Conclusion: Sorry, but you do not have many options. I bleieve that the problem is with your monitor that's going bad. Its far cheaper to get it replaced than to repair it.
Oct 04, 2009 | ASUS MW221U LCD Monitor
Tv won't come one and blinks red 7 times then stops.
When the bottom half of the picture goes out this usually indicates a failure of the lower Y driver module. When this module fails it will often take out the Y sustain module and when that happens the set goes into over current shut down. Both boards will have to be replaced. All of this is assuming you have a Plasma set and not a LCD flat panel.
Jun 02, 2009 | Philips Televison & Video
Nokia 3230 screen goes blank after a few minutes of turning on.
the problem on it is the crystal IC on the display,, replace it
Apr 04, 2009 | Nokia 3230 Cellular Phone
Readings disappear on thermostat for awhile then come back
Hi Linda,
There are a few things that cause this:
  1. When the heat is starting, it will sometimes go blank for a few minutes and then resume.
  2. Most have batteries, replace them with fresh new ones, if the electricity goes out while you are away, the batteries will keep the settings.
  3. Have someone check the house when it is extremely cold or hire a service to monitor. Your alarm company can usually add temperature sensors to your home, it will add a little safety net for you.
Hope this was helpful, please rate my answer.
Thanks,
Paul
Jan 27, 2009 | Honeywell Programmable Thermostat Heater
Sony 57" rear prijection TV has a fast flashing light and will not turn on
turn on tv, after a few minutes picture goes black, but still have sound. red light blinks 5 times,turn set off same thing happens when you turn set back on. some times it want do it for 10 min.
Apr 25, 2008 | Sony KP-57WS500 57" Rear Projection...
40H80 Toshiba Rear Projection TV
it sounds as if it is solder related, bur hard to say for sure. You ay need a service manual to actually trouble shootthe power supply and opeating circuits. I will post a lnk where you can get a service manual emailed to you
http://servicemanuals.vstore.ca/
Feb 09, 2008 | Toshiba 40H80 40" Rear Projection...
Westell 6100 dsl modem
I use a Westell 6100 modem....internet goes out periodically and is not red...just blank....in a few minutes it comes back on....and later out it goes again....
Dec 02, 2007 | Westell Wirespeed LiteLine 6100...
Phone loses connection after few minutes
I looked up the battery specs for your phone. They are 3 X 200mah= 600mah battery packs. They should last 8 hrs talk time with the headsets. This style of battery pack in my experience only last about 1 1/2years and sometimes longer and "sometimes" shorter...much shorter. I bet you never had problems when you first got them. Basicly this "battery design arrangment" goes back many years before newer battery technlogy was developed. But designers still insist on using them even today. They are cheap to make. ****Time to replace them with new ones.**** Make sure you follow the mfgs charging instructions: "After battery installation, place the handsets in their base unit or charger and allow to charge for 16 hours before use. You can keep the battery charged by returning the handsets to their base unit or charger after each use. When the battery is fully depleted, a recharge takes about 12 hours. Average talk time on a fully charged battery is about eight hours depending on environmental conditions, standby time is approximately four days." Good luck
Jul 19, 2007 | AT&T E5640 Phone
BenQ MX613ST Logo
27 people viewed this question
Top BenQ Computers & Internet Experts
Tony
Tommmix
Level 1 Expert
Computer Links
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
