Question about LG Xnote RD400
Screen 75% working correctly 25% screen black battery discharging within 35 min.
7 years back i purchased this one it is still working very nice but now battery discharging within the short time the screen problem came is any interlink between the battery and screen
  • LG Master
  • 2,386 Answers
No there is no connection of battery with screen it should on full even for short time
the screen needs repair and battery needs replacement
Posted on Jan 18, 2013
APC 1100 pro UPS - last two sets of batteries failed: hot and swollen failed within few years. Overcharging? Is there a fix? These batteries last in different applications for 5-7 years.
What you need to do is connect a Voltage Meter across the two terminals to monitor the VOLTAGE coming from the Charger portion and pushing power into the battery at a 'trickle' current(usually 20 to 1000mA). The battery is designed for 400-600 cycles of discharge, where the unit is on standby and runs till the battery is at 25% State-of-Charge.
If the battery is drained lower than 25-30% SOC, then it may never recover, and fail prematurely.
The idea of the UPS is to save the system files, and do an orderly shutdown. Not to continue with war-of-worlds until the lights come back on. (I am teasing about the first-person video game).
So, see if the voltages going into the battery are about 13.5 volts to 13.75 , if they are higher, then the main unit needs to be re-calibrated for the battery size.
Sep 06, 2017 | APC Computers & Internet
INTERNAL TEMPERATURE FOR BEEF
it all depend how you want your Beef
Rare:
• 120-130 °F (50-55 °C) Internal appearance very red; very moist with warm juices. Approximate cooking and resting time: 20-25 min./lb. plus 8-10 min. resting
Medium-rare:
• 130-140 °F (55-60 °C) Internal appearance lighter red; very moist with warm juices. Approximate cooking and resting time: 25-30 min./lb.. plus 8-10 min. resting
Medium (with a touch of pink):
• 140-150 °F (60-65 °C) Internal appearance pink red color; moist with clear pink juice. Approximate cooking and resting time: 30-35 min./lb. plus 8-10 min. resting
Well-done:
• 150-165 °F (65-75 °C) Internal appearance no pink or red, slightly moist with clear juices
taken from
Cooking Temperatures for Beef
Oct 30, 2016 | Cars & Trucks
I am having error codes 35 and 75 come up on my induction cooktop
Thank you for your post, friend!
I located that on Electrolux Cooktop error codes "35" and "75" stand for input voltage too low. It could be an issue with your filter board or an issue within the voltages. I would recommend having a professional come out to your cooktop to properly diagnose to avoid any unnecessary part purchases. -Matt
Sep 20, 2014 | Frigidaire 36-Inch Smooth Surface...
My lg screen touch wont work but can answer calls
The reason your phones touch screen is not working is simply because there is a problem with the flexi of the phone.
If the screen is not damaged in any way, then the assumption of it being the screen is absolutely correct.
To fix the flexi of the phone;
1. Get the appropriate screwdriver,
2. remove the battery, the battery cover, and your sim,
3. Turn the back of the phone,
4. you will see five rubbers,
5. pick them off with a pincher,you will see screws under them, unscrew the phone,
6. Get a credit card and slip it through the line around the phone then apply a little force in separating them apart,
7. you will see the panel of the phone, carefully lift it up,
8. you will see a flexi that runs through the screen to the panel, carefully detach the flexi from the panel,
9. unscrew the screen of the phone, remove the flexi connected to the screen also and replace it.
10. Reverse the process to reassemble the phone.
Take care
Aug 08, 2011 | LG KP500 Cookie black on T-Mobile U-Fix...
Whenever i turn my phone on the screen is just black. i can accept phone calls and the touch screen responds when i touch it but i cant see anything.
Hi,the screen of the phone is bad is not together with the touch screen.The screen is located at the back of the touch screen.The touch screen is working fine as you said.
Ones you replace screen, phone will work as normal again.
Take nice.
Jul 02, 2010 | LG KP500 Cookie black on T-Mobile U-Fix...
Battery runs out in less than 60 min, used to go for hours.
Hi. With batteries it is very important to recharge them after each use, overnight. I have seen batteries last 7 years in a mobility scooter, because the batteries were charged properly. Batteries store electrical energy by means of a cemical reaction, and if left in a discharged condition for too long, damage is done to the internal plates of the battery.
Batteries are designed to do so many charge cycles.
If a battery is run down to 75% or more, you will not get many cycles out of it. If you only run it down by 25%, you will get 100's of charge cycles out of it.
I would say that you will need to purchase new batteries for it.
When changing the batteries, change one completely first, and then the other. This way you will be less likely to mix up the wires.
Red is positive, and black is negative.
Good luck. Neil.
May 30, 2010 | Quickie Wheelchairs Quickie Wheelchair 18"...
Cost of smashed screen, samsung f480t
The cost of this screen is around 25-30 bucks including the tools. If you want it to send it for repair, it might cost $ 75- $ 100.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Nov 07, 2009 | Samsung Tocco F480 - Pay Monthly Cellular...
LCD display Proview
If the screen is pinkish chances are the panel is defective.Should follow-up with Company Proview and do some correspondence.
Samir
May 23, 2008 | Proview PL926WBi 19" LCD Monitor
Black Screen after 5 mins. of use
Question when u loose picture do u loose sound also ? If so there is an 27Mhz xtal on the (SSB) small signal board that needs to be changed when it heats up it cycles out of phase. when it cools down it will work again till it heats up.
Mar 05, 2008 | Philips 42PF9630A 42 in. Plasma Television
How many images can the DiMAGE A2 capture using a 256MB memory card ?
In general, storage capacity depends on which image size and quality you have selected. For your information, here is the number of images recordable in a 256MB Compact Flash in the respective image size and quality. Since the image size may vary depending on scenes and subjects, these are approximate values only. Image size 3264x2448 / 3264x2176 / 2560x1920 / 2080x1560 /1600x1200 / 640x480 Std: 106 / 118 / 167 / 243 / 381 / 1043 FINE: 61 / 69 / 99 / 146 / 235 / 781 X.FIN: 31 / 35 / 50 / 75 / 124 / 594 TIFF: 10 / 11 / 17 / 25 / 43 / 245 RAW and JPEG: 15 / 16 / 17 / 18 / 19 / 20 RAW: 21 Movie : Image size 544x408 / 320x240 Movie(15fps) : 7 min. 9 sec / 13 min. 44 sec Movie(30fps) : 4 min. 15 sec / 7 min. 3 sec
Sep 15, 2005 | Konica Minolta DiMAGE A2 Digital Camera
LG Xnote RD400 Logo
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
