What does the 1E error code mean? - Washing Machines
  • Washing Mach... Master
  • 17,129 Answers
Details can be seen on this link: error code1 E
Posted on Jan 18, 2013
Daewoo DWD-F1011 1E error code I have a daewoo washing machine model DWD-F1011 and it start working the wash before no working spin and gives error code 1E. Any idea what that might be?
I do not believe that is a 1E I think it's an IE error code which would be water inlet wiring or something like that. Here is the code list, scroll down until you find IE, Daewoo errors start at E2, hope this helps.
http://removeandreplace.com/2015/11/02/daewoo-washing-machine-error-fault-codes/
Aug 30, 2016 | Daewoo Washing Machines
Showing a 1E error code
You need to post more info like a model number
Aug 29, 2016 | LG Dishwashers
I have a LG dishwasher that exhibits occasional groaning, 1E error and poor cleaning. Sometime it works fine but lately it's getting more common.
Since you have replaced the water inlet valve and still have the 1E error code, this leads me to believe that your water pressure could be too low.
1E error code means that your machine is not filling with enough water to operate correctly, so check the supply system completely and also the filters where the supply hose enters the machine.
The poor cleaning could be food clogging the lower filter screen, the groaning is the circulation pump cavitating.
Apr 28, 2015 | LG LDS4821ST Stainless Steel 24 in....
WHAT DOES ERROR MESSAGE 1E MEAN AND HOW DO WE FIX IT?
On LG's, a 1E error message usually means there is a problem with the water inlet valve. Check your shutoff valve under the sink, first, just to make sure someone didn't accidentally turn it off. If it's on, then it's most likely the water inlet valve located under the dishwasher.
Oct 18, 2014 | LG Dishwashers
What does the error code on my refrigerator mean?
fix 1E error code on my samsung refrigerator.
Jan 01, 2014 | Computers & Internet
I keep getting the 1E code. I go into the washer and try and rearrange the load, and want to be able to restart the load but can't do that. Typically it happens when there is only about 10min. left in...
Hello there and thank you for choosing fixya
  • The error code of "IE" signifies a water inlet error. This means that your machine is not filling to the proper water level, and may be fixed by ensuring that machine's water supply is properly connected and turned on.
  • If every thing there checks out fine then the inlet valve on the machine is faulty and needs to be replaced ...
  • drain error will result in an error code of "OE." This means that your washer is not properly draining. Ensure that your drain hose is free of kinks and clean. Your filter also must be clean
    An error code of "FE" represents an overflow error. This means that the water level is too high, and the machine will start draining itself automatically.
    An error code of "E1" represents a leakage error. This means there is a leak in one of your hose connections.
Aug 04, 2011 | LG WM-2077C Front Load Washer
When I switch on my washing machine, it gives me the time period it will wash then it writes 1E and stops. What does that mean
1E means inlet error,your inlet valve is mechanically jammed shut & needs to be replaced.
Feb 09, 2011 | Washing Machines
Error message 1E is displayed at start up samsung model SW75C3S
1E error mean there is malfuntion on your sensor pressure. Maybe because the sensor is damage or rusted. You must replaced, it's cost me about $15
May 19, 2009 | Samsung SW62ASP Top Load Washer
LG LDF7811ST 1E code
Are you sure it's 1E and not LE error code??  The symptoms you mentioned indicates that it is an LE error code and the motor has an issue.  You will need to call a qualified LG technician to diagnose and resolve the problem.
Jun 28, 2008 | LG 24 in. LDF 7811 Stainless Steel...
MAGTAG STACK WASHER
The 1E error codes relates to a lid lock failure. You should replace the lid lock switch. Good luck!
Nov 21, 2006 | Maytag LSE7806A Top Load Stacked...
Washing Machines Logo
46 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
