Question about BOSS AUDIO SYSTEMS Boss BV9560B 7-Inch DVD/MP3/CD Widescreen Bluetooth Receiver with USB and SD Card
Wiring diagram key 1 wire - BOSS AUDIO SYSTEMS Boss BV9560B 7-Inch DVD/MP3/CD Widescreen Bluetooth Receiver with USB and SD Card
1967 buick riviera 430 dist firing order also vacuum diagram for engine and does dist wire go on pos side of coil?
F.O. is 1-8-4-3-6-5-7-2. Rotor turns clockwise. Wire from coil to distributor is from negative side of coil. The positive side of coil is for hot wire originating from ignition switch. Always hot with key on.
For vacuum diagram, just google "1967 Buick Riviera 430 cu in, vacuum diagrams" . It is there.
Oct 14, 2017 | Buick Cars & Trucks
Need wiring diagram
Wiring diagram for a 3-way switch, one of the many wiring diagrams showing different methods of wiring a three way switch circuit. This electrical wiring diagram shows power into light switch Box #1 – wire to light from switch box #1, and from switch box #1 to three-way light switch box #2.
Jan 06, 2016 | Holmes Products Heating & Cooling
Wiring diagram for a rigid frame with a shovelhead engine
i doubt that one exists for a assembled bobber. but dude all you need are 3 wires on ignition switch 1 from the batt. 1 to the coil 1 to the lights if you want to rewire your bike (kick start only) very simple..1st post on the ignition switch (key switch), 1 wire, from the battery to the ignition. on the second post (key switch), 1 wire from the top post on the coil, (note on the bottom post of the coil another wire goes to your points), on the top post of the coil add 1 wire to one side of the brake light switch, then another wire from the other side of the brake light switch to the brake light, 3rd post (key switch), 2 more wires, 1 to the head light, 1 to the tail light (if you want high beam run a extra off the 3rd post to the hi lo switch then 1 from the hi lo switch to the head lights high beam wire)
last 1 wire from the regulator back to the battery.
you have just rewired your bike. if you have a electric starter then just add another from the 2cnd post (key switch) to the starter button, then 1 from the starter button back to the solenoid.
Oct 03, 2014 | Harley Davidson Motorcycles
Wiring diagram
In cavity 1, the 30 amp fuse has no power with key on? A wiring diagram shows that fuse gets power right from a wire from the ignition switch, with key on.
Wiring diagrams here: http://www.bbbind.com/tech_database.html
You just have to agree to license agreement, go to "technical information". To TSB's and wiring diagrams: enter year, make, and model-make sure you are on wiring diagrams, not tsb's, then pick the diagram you want to look at. Every wiring diagram on your vehicle is available.
Rate if this helps you. Always appreciate a reply.
Dec 20, 2013 | 1990 Dodge Ramcharger
Ford red light flashing
Its advisable to see the wiring diagram.See the first diagram to the left side.As per that wiring diagram,you can disconnect and reconnect the wires to reset the key switch.Click the link for wiring diagram:----http://technoanswers.blogspot.in/2012/02/vehicle-wiring-diagram.html
--------Thanks.
Feb 03, 2012 | 2004 Ford Freestar
Trying to install a push button ignition need to know which two wires to run to the button, without having to spend hours tracing and guessing. A diagram showing the wires would be great.
Your switch has 4 terminals.
1. Red is the hot wire from the battery.
2. Dark Blue is the run wire. This wire powers PCM, and engine and well as all accessories when the key is on.
3. Yellow is the start wire. It powers the engine, ECU and starter circuit when the key is turned to start.
4. Last terminal is accessories. I don't know the color, but it will power the radio, blower, windows, mirrors, etc. when key is turned to ACC. Some diagrams of the switch are below. Please let me know if you have any questions.
Nov 12, 2010 | 1996 Dodge Dakota
Lg crt monior display cable wire circuit diagram
Pin Signal 1 Red Video 2 Green Video 3 Blue Video 4 Monitor ID - Bit 2 5 Ground 6 Red Ground 7 Green Ground 8 Blue Ground 9 [KEY] 10 Sync Ground 11 Monitor ID - Bit 1 12 Monitor ID - Bit 0 13 Horizontal Sync 14 Vertical Sync 15 N/C (Reserved)
Feb 11, 2010 | Computers & Internet
Wire Diagram
If the plug is not keyed and you cant tell from the wires, it probably doesn't make a difference. You are telling me it is 21 VAC ... AC dont care - and you dont appear to have a common ground situation.
Sep 07, 2009 | GE JE1460 Microwave Oven
Need wireing diagram for a rci 2980 to tug8 mic
Here is what I have: If the Tug 8 is a 4 wire cable,1/shield 2/white 3/red 4/black 5/N/C 6/N/C
If the TUG 8 is 6 wire cable,1/shield & blue 2/white 3/red 4/black 5/N/C 6/N/C .The reason I gave two diagrams is I can never remember if the 8 or the 9 is 4 wire cable.Also if your radio keys up when you plug mic in reverse the black and red.Good Luck and take care!
Feb 24, 2009 | Uniden Bearcat Pro PC68XL 40-Channels Base...
BOSS AUDIO SYSTEMS Boss BV9560B 7-Inch DVD/MP3/CD Widescreen Bluetooth Receiver with USB and SD Card Logo
151 people viewed this question
Top BOSS AUDIO SYSTEMS Car Audio & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Kazim ERGUNEY
Kazim ERGUNEY
Jerry Umali
Are you a BOSS AUDIO SYSTEMS Car Audio and Video Expert? Answer questions, earn points and help others
