Question about GE PSA1201RSS Microwave Ovens
Replace door handle psa1201rss01 - GE PSA1201RSS Microwave Ovens
Model Psa1201rss01 key pad shorted msg. Does it need both the main control and keypad control panel?
The keypad must be replaced, it is shorted just as the message states.
Feb 15, 2017 | Microwave Ovens
The bottom of the door handle has broken loose. There doesn't appear to be screws on the inside of the door. Can I order a new handle and replace it (how do I take the door apart) - or am i going to need...
Go to RepairClinic.com. They have detailed exploded views of many appliances. This will show you how to replace the door handle or what you need to do..
Jan 16, 2011 | Microwave Ovens
I need to replace just the door handle on a Maytag Microwave (Model No. MMV4205BAS). All I've seen online for parts is a complete new door for anywhere from $220 to $300. Surely there is a cheaper...
The handles run about $25-35 here.
Here are the part numbers & descriptions:
W10279351 Black handle
W10279353 White handle
W10279355 Bisque handle
Sep 07, 2010 | Maytag MMV4205 Microwave Oven
Replace door handle
The door handle can easily be replaced on MOST microwave ovens by removing the inner door panel that goes around the perimeter of the glass. The following link explains how to access and replace the door handle:
http://www.fixya.com/support/r3696942-microwave_oven_door_handle_replacement
The average cost for a replacement handle (if required) usually runs about $20 - $40. Replacements may be purchased at the websites listed in the link I provided.
The door handle is a simple repair that can be done with the door in place, or with the door removed. You do not have to uninstall the oven if this is an over the range model.
NOTE: If you wish to remove the door, all you need to do on most models is open the door all the way and lift straight up at the hinges.
If you have any questions, please post back with your MODEL NUMBER and let me know. I hope this helps you.
Aug 23, 2010 | General Electric Advantium 120 Microwave...
I am trying to replace the door handle. How to I
On MOST microwave ovens, you just have to remove the inner door panel that goes around the perimeter of the glass. The following link explains how to replace the door handle:
If the model number is correct, and you haven't purchased a replacement handle yet, the part numbers are WB15X10119 and WB15X10120. There are two pieces with the door handle on this model oven. Replacements may be purchased at the websites listed in the link I provided.
If you have any questions, or if your model number is different than the one listed, please post back and let me know. I hope this helps you.
Dec 30, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
How to replace the door handle on a GE, JVM1490SD 003 microwave?
around the door you will see a plastic cover strip. gently pry it off and under there you will find the screws to open up the door and get to the door handle screws. you dont have to worry about breaching the seal.
Aug 13, 2009 | GE JVM1490 Convection/Microwave Oven
Need to replace broken door handle. Cannot get to screws inside door to release broken handle and replace with new handle.
Look for a removable insert around the inside window. If not there may be screws along the outside edges to separate the door sections. Eric
Aug 02, 2009 | GE JVM1650 1000 Watts Microwave Oven
I have a GE Profile Microwave and the handle is broken....
I have the same issue. The Handle broke off my GE Microwave Oven (Model JVM1190SY 001). GE does not sell the handle seperately from what I can tell. I just ordered a new door. It's rediculously expensive. I tried to replace the handle with a nice drawer pull but couldn't find a size pull to match and I broke the plastic cover trying to get access to the screws for the handle, which is why I decided to buy the new door. Hopefully installation is not that difficult. This oven was manufactured in 2001, seems the handles have a 7 year life span.
May 28, 2008 | GE JVM1190SY/WY/AY/BY Microwave Oven
Need to replace GE Spacemaker XL1400 door
On most microwavre ovens all you have to do is open the door all the way and lift straight up at the hinges. The door comes right off the hinge pins. In some cases you may have to remove the top louver panel (right above the door). You should NOT have to unmount the oven to complete this. In fact...I would not recommend it.
Is this a simple matter of replacing a door handle? If you need to only replace the door handle, you just lift slightly on the INNER door plastic around the glass and you will be able to access the door handle screws. There are a series of small grooves in the panel that you can use a small screwdriver to gently pry. You should not have to remove the entire panel. Just open it enough directly behind the door handle. Be careful when prying on the plastic. It can break if you're not careful. I hope this helps you.
Feb 27, 2008 | Microwave Ovens
GE PSA1201RSS Microwave Ovens Logo
70 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
