How do you turn on a maxi-heater model #nh400be
Manual for maxiheat nh400be
Maxi heat is a product of Allmand Brothers.
Allmand.com
(308)995-4495
(800)562-1373
Explore the above and you will probably get your
manual. Good luck.
Regards,
Dennis
Sep 28, 2014 | Heating & Cooling
What r13 code mean
There is no r13 code on your heater. The r13 flashes everytime you turn on your heater, wait, then see if it fires, if not, you will get an error code starting with EO then a number, or the "service system" or "service heater" light will come on.
Aug 06, 2014 | Sta Rite Maxi Therm 400k Btu Propane...
MAXI hEAT CERAMIC HEATER CH 110
Possible problems:
Adjustable thermostat dirty or worn out. Can bypass thermostat with a wire, if you do this thermostat will not function since it has been bypassed.
"Too hot safety piece" (located between large yellow and large white wire) is dirty between contacts. Disassemble, clean with sandpaper, reassemble.
Nov 21, 2013 | Rinnai Vent Free Gas Heater/: 6,000 BTU...
Does Maxi cosi pebble car seat cover fit to maxi cosi mico car seat?
Hi
We wouldn't advise a Pebble fabric on a Mico as the models are a different design so the Pebble fabric wouldn't be an optimum fit on the Mico model.
For replacement Mico fabric contact crelations@djgusa.com
Apr 25, 2013 | Maxi-Cosi Mico Infant Car Seat
I have a Maxi Heat OH-107C. The knob to turn it down and off just broke. Where can I get a replacement?
King of Fans Ltd, Ft Lauderdale, Florida, (800-330-3287) is the manufacturer/distributor of your heater. They should be able to help you with a replacement knob.
Apr 08, 2011 | Heating & Cooling
I use a small portable propane heater that has 6
Carbon monoxide poisoning !! do not use !! Get it checked for clogged intake air, as well as have burner checked and cleaned. Obviously running too rich, and intake air supply is getting cut off somehow.
Dec 29, 2009 | Sta Rite Maxi Therm 400k Btu Propane...
Error AD0 SF0 180 r8
the stack flue sensor is bad make sure you order the identical part since is two model for thre same heater
Oct 09, 2009 | Sta Rite Maxi Therm 400k Btu Propane...
Where can I purchase new wiring for my Maxi Therm 400? I recently opened the shell and discovered that rats have eaten through much of the wiring.
get the exact model # send to joespools@gmail.com i have my own compay joe's pool & spa service in san jose ca.or call me find my # at google or yahoo so you know im for real
Oct 06, 2009 | Sta Rite Maxi Therm 400k Btu Propane...
Not able to turn on and see anything on display of starite Spa / pool water heater. Any tips on where to start troubleshooting.
I just had my service heater light turn on with no heating and not able to increase or decrease any temp numbers. Any suggestions
Aug 30, 2009 | Sta Rite Maxi Therm 400k Btu Propane...
Heating & Cooling Logo
298 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
