Question about Bulova Watch
Ibeam watch -can"t turn the chime feature off
Eddie bauer watch
SOURCE: eddie bauer ibeam watch
If your watch is the same as mine, push the mode button 4 times, which will put you in the alarm menu (AL 1). Then, push the ST/STOP button until "chime" disappears.
Posted on Mar 02, 2009
The hand on the 1-31 days fell off and is lose in the face of the watch
mcdevito75 here, Look for a small watch repair shop in your area for repair.
Jul 09, 2010 | Eddie Bauer Watches
Skips time
If it is not a feature built in to the watch to save power when it needs winding, I would say it has a bad gear wheel inside.
I would go here, join, and ask in the Rolex Forum,
http://www.watchuseek.com
These guys are really knowledgeable.
Jun 15, 2010 | Rolex Daytona 116520 Wrist Watch
Coleman wristwatch - alarm and chime keep beeping
Hey, I had the same problem with my Coleman watch. It would alarm at midnight. I used the mode feature like the poster before me said. When I got to the alarm "screen" I used the button that backlights the watch's screen. The light came on and the alarm feature was removed. I hope this helps.
Mar 12, 2010 | Watches
How do I enable the alarm on the Eddie Bauer world travel clock with flashlight? I can set the alarm time but I do not know how to enable it. I set it by 2 minutes ahead of the current time and waited for...
From the normal time position, press Mode and the AL function will come up which is where you set the alarm. Instead of pressing SET, press the up arrow. Each time you press the up arrow it changes function. When the alarm function is on a little bell appears above the colon in the time. The snooze has a ZZ that appears below the colon.The unique feature of this clock, is that it is the only one I have seen where the alarm works in the time zone selected. Most others, the alarm only works the home time zone, not the selected time zone. This is a huge improvement.
Dec 24, 2009 | Eddie Bauer Watches
Eddie bauer watch runs slow
This usually means the battery is dying. Usually the backs on these are very tight, and the back has to be taken off to replace the battery. You might be able to get the back off without damaging the watch, but you probably will not get it back on without breaking the crystal. Best thing to do is take it to a reputable watch repair place or jewelry shop and have them replace the battery for you. Before they begin, make sure they are willing to replace the crystal for free for you if they break it!
Aug 06, 2009 | Watches
Eddie bauer ibeam watch
Jan 25, 2009 | Bulova Watch
Get the back off my eddie bauer watch
when you look at the back are there three small rectangular indents evenly spaced on the edge on the back? If so you'll need a special tool for opening waterproof watches. the tool adjusts to fit the three indents then press down as you turn counterclockwise. you can find the tool on amazon.com or your local jewelry store. make sure the gasket is in place and not damaged before screwing the back on.
here is a link to the tool
http://www.amazon.com/Pavilion-Professional-Waterproof-Adjustments-Caseback/dp/B000K3SK0Y
Jan 16, 2009 | Timex Expedition 84601 Wristwatch
Can't turn off alarm
press mode four times until you get to the alarm screen (on mine it is four), then press start/stop to cycle through turn the alarm on, chime on, alarm off, chime off
Dec 26, 2008 | Watches
Can't set time on my Eddie Bauer watch
Nothing on the net, so, you will have to go back to the store.
Sorry....
Dec 20, 2008 | Watches
Eddie Bauer watch.
these watches are waterproof so the stem is screwed down to seal out water. Try turning the stem to unscrew it somewhat , then pull out the stem to set.
Jan 05, 2008 | Watches
Bulova Watch Logo
103 people viewed this question
Top Bulova Watches Experts
Geoff
Jimmy Accardi
Are you a Bulova Watch Expert? Answer questions, earn points and help others
