Question about Mitsubishi VS-45605 50" Rear Projection Television
Mitsubishi VS-45605 rear projection tv
The set does not power up at all. When it's being plugged in a relay can be heard kicking in but pushing the power switch either on the set itself or on the remote does not result in a picture or sound or even the green light illuminating - nothing happens! Fuses (4) have been checked and all are good. Any suggestions?
    President:
  • 3,130 Answers
If the green light is not lighting up, you will need to check out the standby power supply inside the TV set, or if this set has a DM board, you will need to change the capacitors. Good Luck
Posted on Jul 14, 2007
It comes on and then it goes off
This just happened to me as well. Keep it plugged in for about five minutes without trying to turn it on. Then try. This will ultimately tell you that your convergence chip is out. If the screen comes back on, it will look distorted. This is most definantly that chip going out. I suggest a tv repair kit or trash it. You can find a vs 45605 here: http://www.tvrepairkits.com/xcart/vs-45605/
Jan 17, 2013 | Mitsubishi VS-45605 50" Rear Projection...
I have a mitsu VS-45605 and it seems that all 4 main colors have split. is my tv toast?
Projection TV2_bing.gif sets have several common problems listed below.
Problem #1) Convergence
Symptoms:
  • Screen Looks 3D
  • Colors wont align
  • Screen may look distorted
  • No Audio/Video - TV2_bing.gif makes a chirping sound.
Problem #2 CRT Fluid has clouded over. Symtoms
  • Dull looking video
  • White looking video
  • Halos around objects
  • Red/Orange looking video
You can see some examples and find a fix here...
bb0cf99.pnghttp://www.fixya.com/support/r2861467-solution_video_looking_whiteish_dull
Mar 06, 2010 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi vs-45605
Sure. I have had one repair person tell me it's not worth fixing. But, I am surprised that there have been no solutions posted.
James
Oct 08, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi vs-45605
G'day mate
To all accounts it does, this can be checked by verifying that it has TWO antenna inputs. To get the PIP working, you will need to split and feed both antenna inputs. Seems to be set up this way to cater to PIP with set top boxes/convertors that have RF outputs
the 2 tuners can be spotted as the shielded assemblies with covers either side in the lower right corner of this pic. There is a mod floating around that involves bypassing the PIP to fix a fault that the set develops. This may have been done to your already.
check here for details.
Hope this helps you. A fixya rating is a great thankyou for my efforts to assist you . Cheers
regards
robotek
Sep 14, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Veertical lines
Put a fan in it. Something is overheating in the unit and by placing a small fan in the back, inside the back cover, the lines disappear. Hope it works for you, it did for me.
Sep 07, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi big screen vs45605
I believe I have a convergence problem with my VS-45605, i cannot get the front panel controls to move the blue and red crosses. I dont have original remote and a universal remote doesnt work either, any suggestions.
Jul 24, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi vs 45605 no picture
yes if the tuner is out and you want to save some money then running an external set top box or your denon are fine. more often than not you will also have better picture quality.
May 23, 2008 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45605 convergance
you will need to replace both convergence i.c.s as a pair
Nov 27, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Need help repairing Mitsubishi VS 4541 rear projection TV
This model is equipped with a self-diagnosis feature to help with diagnosis of shutdown problems, to activate this turn the unit on let it shutdown then press the input and menu buttons on the front panel simultaneously and hold them in for 5 seconds after 5 seconds the power LED on the front panel will blink a two digit sequence. This will be one set of blinks a short pause then another set of blinks, this will repeat 5 times. 1 - 2 = no error detected 2 - 1 = X-ray protect (high voltage or beam current) 2 - 2 = Short protect (short protect monitors low voltage supplies) 2 - 3 = Deflection protect (this could be loss of vertical or horizontal deflection) 2 - 4 = Vertical protect (usually loss of vertical from the source
Jul 28, 2007 | Mitsubishi VS-45605 50" Rear Projection...
Mitsubishi VS-45605 50" Rear Projection Television Logo
134 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
