Honeywell T87f 3855 Doesn't Activate Heater
Hydronic Buderus system, Honeywell controllers (above).
Three zones, each master/slave.
One zone giving trouble.
In one zone, with thermostat set at 61 degrees, heater does not kick on, even when ambient room temperature is 51 degrees. Cycling the thermostat, i.e. "off/on", then setting temperature at 65 degrees or above, will deliver heat.
When running, heater will heat room to temperature set on thermostat (e.g. 62 degrees = 62 degrees). Problem is, thermostat won't kick heat on - even with 10 degree difference in set vs. actual temp.
Anyone have thoughts?
  • acmemodelers Jan 25, 2009
    This is a master/slave combination, upper & lower floors.
    The master zone is "on/heat", and set at 61 degrees.
    The slave zone is set at 61 degrees.
    At night, the temperature in both zones, under the above scenario, drops to 51 degrees by morning.
    The master is "on".
    The other two master/slave zones in the house also remain "on/heat" at night.
    No, boiler does not have outdoor thermostat. The whole unit, boiler, expansion tank, hot water tank, air handlers. . .everything is in the basement.
  • 700 Answers
Thats becaue you need more than this zone working like you said about the master/slave this zone is a slave.
Posted on Jan 25, 2009
  • Todd Born
    Todd Born Jan 25, 2009
    ok does the boiler have an outdoor thermostat?
SOURCE:
My Honeywell HZ311 3 zone system (Cool & Heat) system all lights are flashing. Please advise how do i reset (restart) the stem. Thank you!
Honeywell TrueZONE HZ311, HZ322, HZ432 Manual
www.manualslib.com > ... > Other > HZ311, HZ322, HZ432
View and Download Honeywell TrueZONE HZ311, HZ322, HZ432 manual online. ...Page 3. Zoning System Design Manual IntroductIon Fig. 2 depicts a typical residential layout with three zones. ... Zoning System Design Manual Plan the Zones In planning azone system, here's what you need: Panel ... Restore password.
Sep 29, 2015 | Cars & Trucks
Recently purchased and moved into older home with a hydronic radiant heat system with boiler. Upon running the system in the colder temps, we are hearing a gurgling sound recurring in some of the runs
typically hydronic systems like that need to be bled, start with the highest radiator, the bleed valve have a little square head and you need to have a key that fits them, most supply HVAC houses have them sitting on the counter but you can ask them for one.
Jan 14, 2015 | Heating & Cooling
I have a Honeywell HZ311 an a red indicator light is on for zone 3, what does that mean if zones 1 & 2 are green ??
red lite for zone 3 means zone three is calling for heat green lite for 1&2 mean zones are satisfied
If you need further help, I’m available over the phone at https://www.6ya.com/expert/mike_9693b5ad75773352
Jun 12, 2014 | Honeywell Truezone HZ311K Zone Control...
MY APARTMENT HAS ELECTRIC WATER BASEBOARD HEATING SYSTEM, I found out the heat cannot be turned off even I disconnect the honeywell thermostats (only one on the wall for the whole unit - living room and 2...
Okay couple questions here because either you have hot water baseboards or you have electric baseboard heaters.
- if the system is a hydronic baseboard heater fed form main boiler, usually this means your space heat is controlled by a zone valve which the zone valve is controlled by your thermostat.
-if you find the zone is controlled by a zone valve than it is possible the zone valve is defective causing hot water to bleed past the zone valve even though your t-stat is telling it to close.
- first find out what excatly the baseboard is heated by either water or electricity
-next personal message me and I can walk you through it
May 29, 2017 | Honeywell Heating & Cooling
I want to upgade from my old water tank to a tankless water system. I have underfloor heating and it has 4 zones but i run it as one zone and it is controlled from a therm ostat that controlls a pump.I...
what you have is called a hydronic heating system.
this heating system is completely isolated from your water heater I believe this as most hydronic systems I have installed circulate water through the furnace to heat the house. If this is true you need only to connect your old water heater cold water supply side to the tankless and, old hot water side to the house system: the showers/tubs/sinks etc. in your home.
my appologies if I have missunderstood your inquiry.
Jan 26, 2010 | Rinnai Digital Remote Water Heater Control...
Valve replaced , but 1 zone out of 3 no heat when
Hello. Each zone in you home has one thermostat controlling one zone valve. Generally, when a thermostat is calling for heat the zone valve opens and the circulating pump comes on to move the water around that loop. If your other two zones are both working as they should and you now have a new zone valve on the third loop I would suspect that the thermostat is faulty. Regards, Joe
Dec 12, 2009 | Honeywell Programmable Thermostat Heater
Chronotherm Three thermostat vs Buderus Logamatic Computer.
The outdoor thermostat senses the the temp of the outside air, and adjust the boiler water temp according to what it knows is best. The reason that the boiler is running longer is the old boiler used to be constantly sending 180ish degree water to the baseboard, now that water may only be 140ish degrees. The idea behind this is to reduce off cycle heat loss, as the greater the temp difference between the air temp and water temp, the quicker you loss heat. The theory in boiler run time is this, the less times it starts and stops, and the long run times will give you the best efficiency. Hope this answers you questions.
Sep 28, 2009 | Honeywell Power Humidifier: Furnace...
Honeywell round thermostat Model #T87F continuously running
you either have 2 thermostat wires bare and touching or a zone valve stuck open
Feb 28, 2009 | Honeywell Programmable Thermostat Heater
Home heating and thermostat
It is possible the relay on the zone board is bad, You can test the thermostat if you own a voltage meter. It is possible for the thermostat to display and still be bad.
Mar 17, 2008 | Honeywell Electronic Programmable...
Heating & Cooling Logo
407 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Donni Steen
Marvin
Marvin
