Question about HP Laserjet P3015X Printer
HP LASERJET P3015 X PRINTER wireless capability
Is the HP LASERJET P3015 X PRINTER capable of connecting to the network wirelessly?
CoachTim
  • 202 Answers
SOURCE: Printer Pinging problem?
Make sure your wireless workgroup/domain are the same as your wired network. If they are, you should reinstall the printer from control panel. Choose add network printer, choose the proper workgroup/domain, you should see the available printer, select it, it may need to download drivers and install them. Tim
Posted on Jan 29, 2007
  • 68 Answers
SOURCE: I would like to network
What model of HP LaserJet do you have?
You will have to go into the configuration menu on the printer itself and set up the network connection.
I don't know what model you have, but here is a generic answer
Press the Menu Right until you find the HP MIO Menu - Select it. Next press the Item right button until you find the Cfg Network Card = No, - make it say yes by pushing the value right button, then push select to put an asterisk ( * ) next to it. Then press the item right button until you find Cfg TCP/IP = No, - make it say yes by pushing the value right button, then push select to put an asterisk ( * ) next to it. (assuming you are on a basic network) Last press the item right button and insert the following information.
IP Address: Not one already in use - generally 192.168.1.XXX (where XXX is some number between 2 - 253) Subnet Mask: generally 255.255.255.0 Gateway IP Address: Generally 192.168.1.1 or 192.168.1.0 or 192.168.1.254
Once you give it this information, print out the config page and it should be there. If this doesn't work, or you don't know how to find those numbers, I would be glad to help you further.
Posted on Dec 04, 2008
El Geek
  • 148 Answers
SOURCE: no wireless capability
If your model does not have wireless capability, even if you had a switch on the machine, if there is no internal wireless card you can't make this wireless. My suggestion would be to purchase a PCMCIA or USB wireless card that you can load to your system to make this wireless capable.
Posted on May 22, 2009
  • 16 Answers
SOURCE: HP photosmart C5580 wireless printing problem
You laptop will not be able to connect to the printer using the bluetooth technology. But the good news is that you can use the printer thru your home network by having the desktop that the printer is connected to be part of the same home network that your laptop is part of and then share your printer on our desktop and then select it as a printer to use on your laptop.
This link has instructions for all of your home network instructions.
http://www.microsoft.com/windowsxp/using/networking/setup/default.mspx
Posted on Aug 05, 2009
SOURCE: Wireless printer won't print wirelessly.
Has the printer software been installed on the computer? Have you added the printer to your printer list on the computer?
Posted on Aug 24, 2009
Is the hp laser jet 3050 printer capable of wireless?
Yes, if the printer is already a part of a wireless network.
Mar 21, 2013 | HP LaserJet 3050 Printer
Is the hp Laserjet 3030 WiFi compatible?
This printer only have a USB and Parallel connection that you can use to connect to yur computer it don't have a built in wireless capability.
But if you want to use this for wireless you can get a wireless print server for it.
Nov 08, 2011 | HP LaserJet 3030 All-In-One Printer
Can I do network scanning with hp laser jet 3055 printer
Yes you can print, fax & scan with HP Laser jet All-in-one through LAN port (wired or wireless). Un-install and re-Install driver and Check "Extended Capabilities" when prompted.
Feb 16, 2011 | HP LaserJet 3055 All-In-One Printer
How can i use my hp laserjet p1120w with my iPad by airprint
AirPrint lets you print wirelessly to AirPrint-capable printers. Make sure you have an AirPrint-capable printer.
AirPrint-capable printers don't require printer software; they just need to be connected to the same Wi-Fi network as your iPad.
If you're not sure whether your printer is AirPrint-capable, refer to its documentation or contact their support.
Here are the steps.
1. Tap (the back arrow) or (the forward arrow) (depending on the app you're using), then tap Print.
2. Tap Select Printer to select a printer.
3. Set printer options, such as number of copies and double-sided output (if the printer supports it). Some apps also let you set a range of pages to print.
4. Tap Print.
Dec 25, 2010 | HP LaserJet 1020 Printer
Iam trying to set up a photosmart D7360 to work in my home for all PCs so I'd like to set it up wireless. I'm currently using a router. How do I start? I have a brand ne HP lap top and the photosmart is in...
HP Photosmart D7360 is Not completely Wireless Capable, However if you want to make it Wireless, You will have to use HP bt450 Bluetooth Wireless.
However since this printer has Ethernet Port, you can still make this printer wireless.
You will have to connect this printer thru Ethernet cable ( network cable ) to Router ( this is called wired networking )
Once you have connected the printer to Router, insert the disk in CD Drive and start the installation process, It will prompt you to choose the type of Connection, Choose Wired/Wireless Network and continue with further installation to complete.
How this works,
With any PC that is connected Wireless to Router, You will be able to print wireless from the PC to Printer.
Jul 03, 2010 | HP Photosmart D7360 All-In-One InkJet...
I have an HP LaserJet printer 4050N with RJ45 and Parallel Port. The Printer is kind of far from the WireLess router and I can't connect it. Unfortunately, my PC doesn't have a parallel port. The best...
Another option is to find an old laptop, with "wireless" capabilities and a Parallel Port.
Connect the printer to the laptop.
Connect the laptop to your wireless network.
Tell the laptop to "share" the printer.
Then, any computer on your network can "find" the networked printer, and can print to it.
Jun 12, 2010 | HP LaserJet 4050 Printer
How to connect the printer wireless
I don't think the HP 3055 has built in wireless capabilities. It does however have a built in 10/100 Base-T TCP/IP networking with 1 RJ-45 port, Hi-Speed USB 2.0 port, RJ-11 fax port, RJ-11 line-out telephone port. You should be able to connect directly into your hub or router and access the printer through a wireless router. You can get more information on set up at the link below.
http://h10010.www1.hp.com/wwpc/us/en/sm/WF06a/18972-18972-3328064-12004-3328082-1161389.html
May 31, 2009 | HP LaserJet 3055 All-In-One Printer
Is this printer wireless capable?
It doesn't have wireless built in but if you've got a wireless router you can link to it through this by plugging it into a network port. It would need setting up then...
Feb 10, 2009 | HP Color LaserJet 2600n Printer
Can I print via my wireless network with HP OfficeJet 6310xi?
Nothing helps. Print servers are capable of connecting a multifunction printer for printing capabilities only. For scanning, you have to connect directly to the Computer or by a Multifunction printer with wireless capabilities.
Jan 15, 2009 | HP OfficeJet 6310 All-in-One Printer...
Wireless or Blue tooth capable
You may call HP Tech Support At toll free- 1-800-585-2494 and ask any technical question to hp support agent. you may also contact them via chat support by visiting: HP Customer service . hope this will help you better.
Aug 08, 2008 | HP Deskjet 6980 InkJet Photo Printer
HP Laserjet P3015X Printer Logo
658 people viewed this question
Seeker5211
Seeker5211
