Question about Vizio L32 32 in. LCD HDTV
System board replacement
Hi, I need to replace a system board on a Vizio L32, though, an A+ tech, I have never "opened" a LCD.....manual and/or help? Kimbelry
  • 1 more comment
  • Anonymous Nov 14, 2007
    Vizio Plays for about 20 Minutes and Makes a pop and has stricks or white lines going vertical on the screen and cuts out the sound, but the picture is still showing, and moving, I have to unplug the cord and plug it back up and it will start right back playing for another 20 minutes and does the same thing. I Took the back off and was going to change the main board and the board i purchase was bad, so i put the old board back in and let it play with the back off and it play for 3 hours until i put the cover back on, and it started doing the same thing. I don't think the cover is touching anything to make it ground out. Please help me solve this. Thanks
  • Rdichristo Mar 17, 2008
    Where did you get the PCB ?
  • gurner May 06, 2008
    My vizio will come on for about 15 minutes then I lose picture , Sound is still on. If you turn the set on and off the picture will return for a few seconds and do the same. Need some advice mmgurner@zoominternet.net
Where can I order the small component board with the switches for the VIZIO L32 HDTV? I have found my problem the switch is corroded and jammed due to my sister in laws cat! I have determined no other damage but the input switch and the contactor for the remote sensor. I have also placed a plexigalss barrier to prevent further damage. Oh the things you get into for family!
Posted on Aug 06, 2007
Leadtech described how to remove the back panel. However, after removing all the screws the panel does not easily come off. Do you need to pry off the back panel?
Posted on Nov 25, 2007
HTTP://www.vancebaldwin.com is the offical parts distributor for Vizio
Posted on Sep 21, 2007
    Novelist:
  • 192 Answers
As long as you know how to use a screw gun or drill, then, you will be able to replace the main PCB. There are only two main boards in this set, the main and the power supply. To remove the back, take off the stand (if it is on a stand), usually held on by four screws. Place the set face down (on a soft towel or blanket) to work on it. Remove the back and you may find a large shield covering the main and/or the power supply. The rest is up to you. You'll be fine, any help just respond to this solution and it will contact me.
Posted on Jul 15, 2007
No picture no sound on a Vizio HDTV10A. The green light comes on then turns to amber after a couple of seconds
your Main board went bad, common issue with these units. Need to be replaced, in tv land it called main board in computer world mother board. your unit has only two boards power board and that is good cause you get a amber to green to amber led. good luck Vizio field tech
Feb 01, 2013 | Vizio 32" l32 hdtv 10a high definition...
Last night our TV made a loud popping noise then the picture went out. We still have sound but have trouble turning the TV off. What could this be and is it fixable? Thanks, Anne Marie Orcutt
Question shows it is Vizio L32 lcd tv and symptom shows back light inverter board for defective for some reason and loud noise would be popping of any chip on inverter board.
Shopjimmy..com has replacement boards of that model on reasonable price and local tv repairman will replace defective board after checking/ testing the tv.
Hope these info will help.
Thanks.
May 11, 2011 | Vizio L32 32 in. LCD HDTV
My vizio vp322hdtv10A just quit working
2008?. Well anyway, Do you have a power light, if flashing... panel needs replacing...if no light...power board needs replacing
Jan 14, 2018 | Vizio L32 32 in. LCD HDTV
Vizio TV wont turn on after three weeks no use
My vizio recently did the same exact thing. Vizio sent an HDTV tech out to fix it and it was the power board. He put a new board in (took 15 min) and the tv works like new.
Jan 05, 2010 | Vizio L32 32 in. LCD HDTV
My Vizio L32 periodically turns itself off, multiple time a day.
My 42" and 32" started doing that, I bought it form Costco, they set me up with Vizio under warrarnty. A tech came out and changed out the circuit boards, but the problem persisted, they are now going to send me a reburbished replacement. I'm not Happy, they should send me a new non defective one(actually 2). I will not be buying any more Vizios!
Aug 08, 2009 | Vizio L32 32 in. LCD HDTV
Need inverter board for vizio L32 model an idea on changing same
You can get a replacement inverter board at this link below:
http://www.shopjimmy.com/catalogsearch/result/?q=vizio+L32+inverter
Just make sure you match up the part number on the board.
Jun 09, 2009 | Vizio VX42L 42 in. LCD TV
Vizio L32 TV won't turn on. yellow power light lit, should turn to green when button or remote is pressed, and set should come on. No response to either remote or manual buttons. No change after unplugging...
Had same prob;em. Replace main board and now works just fine. You need to take the back off and under the metal cover is the main board. The part number should start with 3320-xxxx-xxxx. You can purchase the board from Vance Baldwin. vancebaldwin.com sign in as a guest. I will warn you the cost of the board is high.
Steve
Aug 05, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 HDTV 10A won't turn on
It could be a inverter board I would try to replace that first
Jul 23, 2008 | Vizio L32 32 in. LCD HDTV
Vizio l32
Maybe you need change the power PCB.
Jun 27, 2008 | Vizio L32 32 in. LCD HDTV
Vizio L32 32 in. LCD HDTV Logo
357 people viewed this question
Top Vizio Televison & Video Experts
pzarnold
Level 1 Expert
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
