Question about SanDisk Sansa Clip MP3 Player
My sansa 2 gb clip stays at writing when plugged in and refresh
When i got my clip i could put music on it but i couldnt listen to it when it is plugged in it will be at the writing screen but when i unplug it and try to turn it on it says refresh database . so how do i refresh databaes?
  • 758 Answers
You can try to reset the device by pressing the power button for about 15 to 20 seconds..if that doesnt work I would recommend you to go to the sandisk site to update the firmware on your device or you can contact sandisk to they can help you with updating the firmware on your device..Please follow the link below to get the firmware
http://www.sandisk.com/Retail/Default.aspx?CatID=1376
The number for sandisk is 1-866-726-3475
Please rate accordingly
Thank you
Computerrep
Posted on Jan 26, 2009
How do you put music on the SanDisk Sansa Clip MP3 Player
1. First, you have songs saving in your computer.
2. You have 2 ways to put music on the Sandisk Sansa Clip:
2.1. Plug device into computer, Drag and Drop music from your computer into "Music" folder of the Sandisk Sansa Clip.
2.2. Use Windows Media Player in your computer to transfer songs to your device; Plug device to computer, open Windows Media Player, click on Sync tab, drag and drop music into "Drag items here " on the right side of the windows media player, click on Start Sync button.
Good luck
Jan 31, 2010 | SanDisk Sansa Clip MP3 Player
How do I get the downloaded music from my computer into the clip?
You have 2 ways to transfer your songs from your computer to your sansa clip:
1. Plug sansa clip to computer, double click on "Sansa Clip ...GB", double click on "Internal Memory", you will see the file "Music", copy your songs and paste them into Music file of the device.
2. Using Windows Media Player: open windows media player, plug sansa clip into computer, click on Sync tab, select songs that you want to sync, drag and drop song selected into "Sync list" on the right side of the windows media player (you should update wmp11), then click on button Start Sync.
Good luck
Jan 24, 2010 | SanDisk Sansa Clip MP3 Player
My sansa freezes refreshing database, it will no go any further.
this is kind of a b*****....what u do is only put a 2 or 3 hundred megabytes on the memory card at once.then unplug from computer and let it refresh...if this doesn't work try putting less on memory card...worked for me
Jun 06, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
Database not refreshing, Could not listen the new songs added
go into your menu go into veiw all songs then go to play all
May 06, 2009 | SanDisk Sansa c250 (2 GB) MP3 Player...
"No Music"
Either:
1)The licenses on the songs expired, which means you will have to update them through the music service that you acquired them from. (Not likely since the ripped songs are doing the same thing - although you could have inadvertently checked the option in Windows Media Player to add a DRM license to them).
Or:
2) Switch the USB Mode in the Settings menu of your Sansa clip to Auto-Detect or MTP.
-Tha Mp3 Doctor
Feb 20, 2009 | SanDisk Sansa Clip MP3 Player
Try to listen to songs on my Mp3 player (sansa c240) it no wrk
You have to connect the mp3 player to the computer and refresh your device through Bearshare - their songs have fixed licenses, which require you to refresh every 30 days or less.
-Tha Mp3 Doctor
Nov 17, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Refresh database
it's supposed to refresh database anytime you make changes to your clip. also, check in the settings what usb mode you're in as well as "my computer" to see if the device shows up when it's plugged in. as for transfering media, if you want to use a program to do it for you, use mtp (under settings on your clip). if you want to manually drag and drop, put it in msc (also in settings). also in msc, it doesn't really matter where you decide to drop the files onto the player, although there should already be a music folder to help keep things organized.
Jul 10, 2008 | SanDisk Sansa Clip MP3 Player
Refreshing data
Reformat the player and update the firmware
May 18, 2008 | SanDisk Sansa Clip MP3 Player
Very weird...
'Refresh Database' doesn't mean everything is erased. It only means it's writing the progress that you made, onto the computer. It stays on 'Refresh Database' for about maybe 5-10 minutes. It refreshes its database every time you disconnect your MP3 player from the computer. What it does when you disconnect it from the computer is it saves any unsaved changes made to it and overwrites the memory or data.
Oct 28, 2007 | SanDisk Sansa E280 MP3 Player
HELP ME PLZ
That's a pretty weird problem. The only suggestion I can give you is to check to make sure the music you put on was 1) in mp3 or wav format and 2) if this is music you have purchased, to ensure you have the rights properly set to play the music
Aug 06, 2007 | SanDisk Sansa c250 (2 GB) MP3 Player...
SanDisk Sansa Clip MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
