Question about Cooper Wiring Devices ACE6001V-K "ACE" ROTARY DIAL DIMMER
274W-box wiring diagram - Cooper Wiring Devices ACE6001V-K "ACE" ROTARY DIAL DIMMER
I live in an old house and im changing a single switch to a switch and receptacle combo and i have wired it every way to sunday the light works but the receptacle either does not or it also turns on light ...
Open following link for specific wiring illustration and tips.
http://waterheatertimer.org/How-to-wire-Cooper-277-pilot-light-switch.html#combo
Single pole switch has 2 wires: These wires are Hot wire from breaker, and wire going to Load (light).
Combo device needs additional neutral wire.
Without a neutral wire, the combo outlet will not work.
Neutral wire connects to silver-colored screw. Neutral wires are the white wires that are twisted together and covered with wire nut and pushed to back of electric box.
Take a moment and rate answer:
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on electrical outlet or any do-it-yourself project.
Fixya is always less expensive than a service call.
Sep 05, 2011 | Cooper Industries Cooper Wiring 274W...
I have a light switch like this, I have 2 black wires and 2 white wires only. THe house was built in the 60's, I found I black wire that is constantly hot, how do I wire up the plug,light switch so...
Bit more information is needed.
Wire color is not as important as knowing what wire is for.
Knowing Hot black hot wire is good step.
Next, see if box has neutral wires. Neutrals are usually white wires that are twisted together and covered with wire nut. Test black hot to each white wire to find neutral.
If box does not have neutrals, then this device cannot be wired to code.
Other black wire probably goes to light.
Open following link for illustration of wiring:
http://waterheatertimer.org/How-to-wire-combination-switch-outlet.html
Aug 01, 2011 | Cooper Industries Cooper Wiring 274W...
Okay, I have the same problem... It is a cooper combination switch. There are two black wires that are coming out of the back . the instructions don't mention them at all. I am installing a new outlet...
Ok you have GFCI combination switch-plug.
Wires coming out of back of device are connected to "Load" wires.
Load are the black and white wires that go to fan, light, motor.
The black and white wires coming from circuit breaker connect to terminals marked "Line"
Look at back of device for markings.
Black wire from breaker goes to brass screw, white wire goes to silver screw.
There is one more set of screws on device. Device usually arrives with tape over these two screws.
This is what those screws are for: If you are working in a junction box, then three cables enter box.
One cable is for Line wires from breaker box.
Second cable goes to Load (light-fan-motor) that is controlled by switch.
Third cable goes forward to another switch or outlet >> and those wires connect to last set of screws on combo device. Black to brass and white to silver.
Add a comment for more free help.
Also take advantage of fixya expert assistance live.
For a price, expert works with you via e-mail while you work on circuit or any do-it-yourself project.
Feb 13, 2011 | Cooper Industries Cooper Wiring 274W...
Show wiring diagram for 274w combo
1) A wiring diagram can be mistaken because wire colors vary.
That's why electricians don't guess, they test.
2) Look at device to be replaced and note what color screw each wire goes to before disconnecting wires.
If old device is single pole switch, then there are 2 brass screws, and one of these screws is connected to Hot wire, and the other screw is connected to Load wire (light, fan, motor, pump)
3) Separate wires inside box for testing.
Do not untwist any wires.
Tape tester leads to wood sticks to keep hands away from power.
Turn power ON.
Test each wire to bare ground wire.
Tester lights up on Hot. Hot wire connects to dark-colored screw on combo device.
4) Hot is identified.
Test Hot to all other wires, except bare ground wire.
Tester lights up on Neutral wire. In a single-pole switch box Neutral wires are usually twisted together and covered with wire nut. Neutral wire connects to silver screw on new device.
5) Load wire that goes to light,fan, motor, pump connects to brass screw on new combo device.
6) If you do not have a Neutral wire in your switch box, then outlet will not work.
You can connect bare ground wire to silver screw and have outlet work, but this is not code, and definitely not recommended for a child's room or any room near water pipes or faucets or metal pipes of any kind. You need to add a Neutral wire and/or install GFCI protected device for any bathroom area.
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on circuit or any do-it-yourself project.
Feb 05, 2011 | Cooper Industries Cooper Wiring 274W...
I have four wires; 2 black and 2 white. I need to know how to wire 274w.
The 2 whites from the Romex cable go together along with a jumper. Now, the neutral jumper from the white bundle goes to the SILVER screw terminal one the side of the outlet where the LONGER slot is.
The black wire (load/light side), goes to the brass screw terminal on the SAME side outlet.
The OTHER black (line/HOT) wire goes to the opposite side of the switch, the side that has the connecting tab.
The grounding wires go together and then get connected to the box ground.
Feb 02, 2011 | Cooper Industries Cooper Wiring 274W...
I have a black/white/ground wire coming from my power supply into my bathroom. I want to install a 274w combination device so as I can have one plug outlet and a switch for the shower fan.I need to see a...
1) In this situation we need to test the wires.
Electricians don't guess, they test, and a diagram would be guessing which wire color does what.
2) FYI: non-GFCI receptacle located in bathroom is not code, and device will have to be replaced when property is sold. The reason for GFCI is the likelihood of you holding defective electrical gizmo from China in one hand while putting other hand in running water. Or electrical gizmo falling into bathtub occupied by wife with large life insurance policy.
If you have kids using that bathroom, I want you to avoid using non-GFCI device.
3) Your new device has color-coded screws: Dark, brass, and silver.
These colors tell electrician how to wire the device.
4) Let's test to see which wire connects to which screw:
Separate wires.
Use ordinary 2-wire tester from hardware store.
Tape tester leads to wood sticks so hands are away from power.
Turn power ON.
Tester lights up on Hot wire. Hot wire connects to dark-colored screw on device.
Hot wire is identified.
Test Hot wire to all other wires in box, except bare ground wire.
Tester lights up on Neutral wire. Neutral wire connects to silver screw, and will complete circuit to receptacle.
If box does not have a Neutral wire, the circuit to receptacle can be completed using ground wire on silver screw, but I am not recommending that.
Last wire goes to Load (light, fan, motor). Load wire connects to brass screw, and will complete circuit to Load.
Also take advantage of fixyas phone service.
For a price, fixya expert speaks with you over phone while you work on electrical device.
Leviton and Lutron both make GFCI switch-outlet combo.
Buy at Home Center or on-line
Leviton 7299
http://www.amazon.com/Leviton-7299-NI-15-Amp-125-Volt-Combination/dp/B000UJADW6
Jan 02, 2011 | Cooper Industries Cooper Wiring 274W...
Cooper Industries Cooper Wiring 274W Switch and Outlet I need help installing this switch/outlet combo...I have 3 wires...a black, a red, & a copper. I hooked the copper to the green terminal, the...
Switch-plug combo:
bare ground goes to green screw
dark screw goes to hot from breaker
silver screw to neutral
brass screw goes to load (light)
Add a comment any time
You are replacing single pole light switch?
Single pole switch has 3 wires: black and red and bare copper
New device has 4 different colored screws: green, dark, brass, silver
Bare copper goes to green screw.
Black wire goes to dark screw
Red wire to brass screw
Nothing on silver screw for a moment. Test circuit and make sure light turns on-off.
If lights works, then good so far.
Now let look at silver screw. Neutral wire has to connect to silver screw.
In back of your electrical box are white wires twisted together and covered with wire nut.
These are neutral wires.
You must connect another short piece of insulated wire to these neutral wires and run that wire to silver screw.
The neutral wire will complete circuit to receptacle.
If you do not have neutral wire, then receptacle will not work in that box without additional wiring.
Hook up neutral wire to silver screw.
Now turn on power and click switch again.
If circuit breaker trips, then reverse your red and black wires.
Otherwise this should be correct wiring.
Dec 08, 2010 | Cooper Industries Cooper Wiring 274W...
I need a wiring diagram for a 274A Light switch/ plug in. Everything we try, we are not getting anywhere.
There are more than a few ways to wire this device. The switch box where the device is installed _must_ have a neutral wire for the receptacle to work. This is usually a white wire.
The switch box should have at least 2 cables in it. One cable is the incoming HOT(black) and neutral(white) from the circuit breaker panel (or source). The second cable is the outgoing switch leg(black) and neutral(white) to the light. Each cable should have a bare equipment grounding wire.
The most common way to install this device is to connect the hot wire to one of the black screws, pick one. ( I'm assuming that you have _not_ removed the brass tab between the 2 black screws.)
The 2 neutral (white) wires are twisted together under a wirenut along with a pigtail which connects to the silver screw on the device.
The black wire that goes to the light (switch leg) is then connected to the brass or gold screw.
The bare ground wires are twisted together under a wirenut along with a pigtail which is connected to the green screw.
Aug 28, 2010 | Cooper Industries Cooper Wiring 274W...
ShockSentry GFCI duplex receptacle child safety
Those GFCI's will stop functioning (as they are supposed too) if the electronics is bad. Nearby lightning strikes and power surges can knock out the electronics. Some GFCI's come from the factory bad out of the box. Also if wired incorrectly (make sure the incoming 120 volt wires are connected to the LINE side of the receptacle) The only other thing to check is if there is power to the GFCI. Test for 120 volts at the receptacle box. (testing from hot to neutral will rule out a bad neutral connection). Should read 120 volts. Otherwise, you'll have to replace the outlet :-(
Jun 07, 2009 | Cooper Industries Cooper Wiring 274W...
Cooper Wiring Devices ACE6001V-K "ACE" ROTARY DIAL DIMMER Logo
42 people viewed this question
Top Cooper Wiring Devices Electrical Supplies Experts
ken skalski
Jim Y
Jim Y
Are you a Cooper Wiring Devices Electrical Supply Expert? Answer questions, earn points and help others
