Question about Car Audio & Video
AUDIO CENTRON RMA 1000
POWER SPECS AND OUTPUTS
I've bought a pyramid crystal 1000 watt 2 channel amplifier used it states it runs at 4 ohms can I run it at 2 or 1 ohms and if so what will the wattage be?
Not to disappoint you too much, but the 1000 watts advertised is just marketing hype. If your amp is the PB781X, it should have only a single 15A fuse on it. Your battery provides 12.5 volts when the engine is off, so at most, your amp draws 187.5 watts of power. Draws, not outputs. No amp is 100% efficient due to heat. When your engine is running, assuming your alternator outputs 14.4 volts, your amp's maximum power draw is about 216 watts. Again, this is what your amp draws, not what it puts out. What you should focus on is the RMS (continuous) output, not Max or PMPO. Those numbers are useless, unfortunately.
Your amp is rated to output 50 watts per channel at 4 Ohms, and 75 watts per channel at 2 ohms. This is when wiring your channels separately, not bridged. I did not see true power specs for your amp while bridged, but it's possible you'll just get the full 150 watts to the single bridged output. Do not attempt to apply a 1 ohm load to your amplifier, as you will run the risk of damaging it. It's not designed to handle a 1 ohm load. If you're lucky, you'll blow a fuse before the amp is damaged, but either way, there is nothing to be gained by attempting it.
Sep 12, 2017 | Pyramid Car Audio & Video
I need manual for audio centron acm 1406 sound mixer
Got a PDF Manual a audio centron ACM 1406 contact me at carlsgangl@yahoo.com if you want a copy
Dec 21, 2011 | Juicers
What are the RCA plugs for on the dxz855mp
Hi, your head unit has 6 RCA preamp outputs and 2 RCA sub-woofer preamp outputs. These outputs connect to amplifiers if you care to use them. You can read all the specs and download the users manual at the following URL:
http://www.crutchfield.com/S-lAJZzNi4tYJ/p_020DXZ855/Clarion-ProAudio-DXZ855MP.html#details-tab
Please let me know if you have more questions.
Dec 13, 2011 | Clarion DXZ855MP CD Player
I received an I-HD901 surround system. How do I hook it up directly to my Sony tv and do I need to buy a receiver or an amplifier?
DON'T NEED A SEPERATE AMP THE SYSTEM HAS ONE IT IS PART OF THE CABINET THE DVD PLAYER IS IN, YOU CAN HOOK IT TO THE TV WITH A HDMI CABLE OR STANDARD VIDEO CABLE OR A PROGRESSIVE SCAN CABLE SETUP, FOR AUDIO U CAN USE STANDARD RCA CABLES, OR DIGITAL AUDIO, CHECK TO TO SEE WHAT OUTPUTS AND INPUTS THE TV G THE TV HAS ALSO CONSULT YOUR USER MANUAL FOR THE SURROUND SOUND. HERE ARE THE SPECS FOR THIS SYSTEM.
1000 WATT system total program power
5.1 Cube cinema HTS, 12 active drivers/magnetically shielded
I-Cube design satellite system
4 Multi-directional 2-way speakers()
center channel has 2-way with horn tweeter enclosure (200 WATTS)
Dual sub-woofers 400 WATTS; 2X6.5" aluminum poly-laminate cone
linked through digital custom crossover circuitry finished in: high-gloss piano and composite black w/silver brushed aluminum
complete 6 piece system (HTS surround speakers
Jan 08, 2010 | Sony DAV-S300 System
No audio from analog audio outputs on denon 988
When you use VCR or DVR out, you must also turn on the VCR/Video 2 Tape Monitor function on the front input select, then it will pass audio. IF you need further help, post a comment and I can pull the specs on your receiver and help some more. Hope this helps.
Aug 23, 2009 | Audio Players & Recorders
Jl audio 1000/1 low voltage -keeps shutting off at high volume
You should definitely upgrade the power wire to the sub amp to 4 gauge -absolutely your choking your amp its starving for current-poor thing is starving !!!!!!!
Apr 16, 2009 | Jl Audio 1000/1 Car Audio Amplifier
How do I know which converter box to buy?
here are the specs for the Magnavox TB100MW9
Product details Smart antenna ? No Closed Captions ? Yes CECB certified ? Yes Recorder ? No EPG ? Yes NTSC tuner ? No Analog cable tuner ? No QAM tuner No Component video inputs 0 S-video inputs 0 Composite video inputs 0 Digital audio input No digital audio inputs DVI outputs 0 HDMI output No Component video outputs 0 S-Video outputs 0 Composite video outputs 1 RF outputs 1 Digital audio output RCA output 480i Yes 480p No 720p No 1080i No 1080p No USB/USB2 No Ethernet No
Jan 04, 2009 | Televison & Video
Sony DHR1000 Chirping in Audio output
"chirping" in the audio may be an indication of a tape path alignment problem. if the tape path alignment is off, the audio will "chirp" or drop out.
May 20, 2008 | Sony DHR-1000 DVHS VCR
Speaker Box Specs??
i need to know what the box dementions are for a 15 inch cerwin-vega subwoofer v max 1000 w peak power?
Mar 24, 2008 | Audio Players & Recorders
Logic alx1280 2 ch amp
Amps can be rated based on their RMS power or their peak power. In this case, the amp's rated RMS power is 300x2 at 2 ohms (total 600W RMS) with a peak power rating of 600x2 (1200W peak). For the most part, peak power means almost nothing.
If your head unit didn't have RCA preamp outputs, you would used the standard speaker outputs from the head unit and connect them to the hi input plug of the amp.
Mar 17, 2008 | Logic Soundlab ALX1280 Car Audio Amplifier
Car Audio & Video Logo
184 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
