Question about Samsung LA40A550 40 in. HD-Ready LCD TV
Sony Bravia KDL-52W5150 screen issues
I have to turn on and off the tv a couple times before the screen works , there are diffuses lines all over or sometimes it just works right away from the beginning.
4 Suggested Answers
lukster
  • 217 Answers
SOURCE: Vertical Lines all over then starts to move lines back and forth
you should first check all the cables inside the set to make sure they all are seated properly, check some other sources like a dvd player and see if it does it on a dvd, after that it is probably a defective main board
Posted on Apr 30, 2007
Big Hev
  • 64 Answers
SOURCE: samsung 42" Plasma -Black vertical line when turned on.
It sounds like an Intergrated Circuit (IC) has fried. Even on a good day, this is not something you can attack at home. As a tech (and as an owner of that model samsung), I'd need a map & tools to know what's going on. Your best bet in this situation is to contact Samsung and let them recommend an authorized service center in your area. Sorry I can't be of more help, but this is a rather serious problem.
Posted on May 25, 2009
AndroidLVR
  • 31 Answers
SOURCE: green lines down length of screen on my samsung 40 inch LE40F8
The reason for the green lines are the resolution. I'm assuming you're TV is set at 1080i, not 720p or 1080p correct? What happens is the "i" stands for interlaced, meaning, your TV displays your images with scan-lines. The "p" stands for progressive, meaning, TV displays picture as a whole. You can not visibly see the scan lines when seeing 1080i, but certain TV programs are not outputting their show to the resolution you're at, which will cause you to have the green line up at the top of your TV. SOME TVs might let you adjust the settings to rid yourself of the scanline, but most consumer TVs will not let you without the maintenance code to protect your unit from over calibrating and braking your television. Hope this helps.
Posted on Mar 20, 2010
Sony bravia KDL 40s4100 vertical lines on left
LOD (lines of death) are a known service issue with the Sony bravia line of TV's contact Sony and cross your fingers. Wish I had better news for you. I had a 52w4100 and Sony arranged me with a service center to get it taken care of.
Aug 18, 2012 | Sony Bravia KDL-40S4100 40 in. LCD TV
Sony Bravia KDL-40w4100 vertical line issue
Ok after over a year i figured out it was the tcon board. Good luck getting finding one. The first one i ordered from shopjimmy was faulty, didn't realize until after the warranty so i ate the cost of it (honestly i thought that it was good and there was another thing wrong with the tv) so i said wtf and bought one last week from ebay. Bam! it works great!!!
Jan 10, 2012 | Sony Bravia KDL-40W4100 40 in. LCD HDTV
We purchased a Sony KDL-46W3000 LVD TV in May 2008. Just recently the left side of the screen has started having problems with hortizontal grey bars and white lines and the screen jumping around when the...
Hi I have an old school solution for your problem with your tv. Hit it!!!!! When you turn on your tv, go to it and lightly tap on the middle of the left frame. You should see it affect your screen. Do it until your screen is perfect. Hope it works.
Jun 22, 2011 | Sony BRAVIA KDL-46W3000 Television
Have horizontal lines across the screen and some
Yeah we have the same exact problem here. Defective TV....ours would correct itself after 30 mins, but now it's blurry all the time. I'm never dropping 2K on a SONY tv again.
Aug 01, 2010 | Sony Bravia KDL-46VL130 TV
Thin vertical line runs across the top of screen on my Sony Bravia KDL-32L4000
Hi my name is Roety,
I can help you with your issue ,
 Try the format, aspect buttons on the Box remote, if the line is there on every input and effect the TV menu your panel (screen) is bad.
A new panel would cost as much as a new TV.
If I have helped you with your issue please click accept.
If you have more questions you can still respond until this post expires,
I will reply asap
Thanks
Oct 24, 2009 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony bravia kdl-52w3000, turn tv on, no picture or
Most likely this is caused by a defective main board. Changing the main board will fix the issue about 95% of the time.
To be absolutely sure, the voltages need to be checked on the power supply. If they are not the values listed in the service manual, then you should replace the power supply instead (accounts for the other 5% of the time).
Oct 07, 2009 | Sony BRAVIA KDL-52W3000 52 in. LCD...
Sony Bravia has sound but no picture
hi have you check the sleep timer on the tv cause it might be on and you need to turn it off
Jan 12, 2009 | Sony BRAVIA KDL-V40XBR1 40 in. LCD HDTV
Sony Bravia - picture don't fit the screen
I have a Scientific Atlanta cable box w/ Time Warner. I followed the instructions below for the cable box. Somehow it reset my picture and I can now read the ticker at the bottom of the screen and the different picture sizes seem to work properly. Good Luck.
http://newteevee.com/2007/12/15/six-steps-to-get-more-hd-from-your-scientific-atlanta-set-top-box/
Aug 03, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Samsung LA40A550 40 in. HD-Ready LCD TV Logo
37 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
