Question about HP OfficeJet Office Equipment & Supplies
How do i print 5x7 photos on my officejet pro 8500 a910
I can print 8 and a half by 11 photos on my printer on photo paper, but when i place 5 x 7 photo paper in the printer, it only prints off the 8 and a half by 11 paper.
SOURCE: Printing 1/2 page
Ok, this is what I found when I finally broke down and decided to take it apart. There is a bar with two cams on either side of it that are used to engage the print head to the paper. The smaller cam on the bar has cracked and no longer pushes the print head down on that side of the paper, causing the half picture. What I did was remove the cam from the bar, glue it back together, then wrapped it tight with thread (only one layer, there is a clearance issue), and put epoxy around the thread(to help reinforce the cam). Once the epoxy had cured, I reinstalled the cam to the bar. The cam did crack again, but the thread and epoxy held it tight to the bar. After reinstalling the bar and putting the rest of the printer back together, I crossed my fingers and tried to print a picture. Tada!! It worked!! I have since printed a few more and have not had a problem yet. It may only be a temporary fix, and nothing could be better then the original replacement part (if you know where to get it), but this has worked for me. Good luck and be patient.
Posted on Dec 19, 2007
sodeep
  • 3267 Answers
SOURCE: how to load 5x7 photo paper into hp photosmart D7460 ??
Simply set the page layout option to select from printer. Place the cut & proper sized paper in the inlet tray, adjust the sliders so that they just rest lightly against the edge of the paper. Remember only one slider moves and the other one remains fixed to one edge. Click print preview. You might get a message saying paper orientation is not right...should I adjust the printer automatically, click yes and behold it will print in Portrait or landscape mode depending on the matter. If it warns that output does not fit on the media(paper) then select fit to page option.....sodeep
Posted on Mar 22, 2009
nalin_elliot
  • 224 Answers
SOURCE: hP officejet wireless 6500 printer won't print
Yes I will tell you why Kodak photo paper is a little thicker in size and you should not get this same error message if you use hp photo paper or regular photo paper.See of this helps.....
Issue The Out of Paper message appears on the computer and the product stops picking up or feeding paper. Solution Step one: Reset the product
  1. Without turning the product off, remove the power cord from the back of the product.
  2. Wait 30 seconds and then plug the power cord into the back of the product.
  3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
  1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
  2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
  3. Tap the stack of paper on a flat surface to align the edges.
  4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
    NOTE: Do not load too much paper in the product.
  5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
  6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
  1. Open a document in the program being used to print.
  2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
  3. Click the Paper/Quality tab.
  4. Choose the appropriate paper size from the Size is drop-down menu.
  5. Choose the appropriate paper type from the Type is drop-down menu.
  6. Click OK and then click OK again to print the document..
  7. If the issue is not resolved, continue with the next step.
Step four: Clean the rollers
  1. Turn off the product and unplug the power cord.
  2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
  3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
  4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
  5. Close the access door and plug in the power cord.
  6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product. CauseAny of the following issues can cause the error message to appear:
  • The paper trays are empty or overloaded.
  • The paper is curled.
  • The print side, or shiny side, of the paper is not loaded in the input tray face down.
  • The paper might not be engaged with the feed rollers.
  • The paper-width guide is pressed against the paper stack too tightly.
  • The paper tray is not completely inserted into the product.
  • The paper settings in the print driver do not match the paper loaded in the paper tray.
  • The rubber paper-feed rollers are coated with dust.
Posted on Oct 03, 2009
SOURCE: The Hp officejet 6310 all-in-one will print
problem fix
Posted on Jan 04, 2010
  • 5125 Answers
SOURCE: no connection ref hp officejet pro 8500 a909a
How are you connecting to the printer (over the network or a direct USB connection)? If you are using a USB connection, try a new cable or plugging into a different USB port. If you use a USB hub, try a direct connection.
If you are using a network connection, check if your firewall is blocking the connection. Also check that the router (or switch) didn't dropped the network connection and didn't re-synch with the printer (or worse changed the IP address of the printer).
I hope this helps.
Posted on Apr 19, 2010
Testimonial: "superb"
OfficeJet Pro 8600 will not pick up glossy photo paper from the tray
I tried everything that was suggested on the HP forum but then tried something not reccommended there and it worked. Not only remove tray 2 from the printer properties but force the print to tray 2, when you this it sets the Quality from normal or Best to Custom. Once I done that it worked... Just disabling the tray 2 is not enough.
Mar 26, 2012 | HP OfficeJet Pro K8600 Printer
I have an HP Photosmart A646 printer that I bought in the hopes of printing to 5x7 card stock. We have pre-printed card stock that we use for gift certificates and we need to be able to feed the card stock...
Thanks for visiting FixYa!
Depending on the program you are using to print your gift certificates, try this-
1) Open the program and open the file you use for your gift certificate.
2) Click on 'Layout' then 'Page Set Up' (probably found in the top menu bar by the right side of, FILE.)
3) Select 'Landscape' and then select, 'Custom'.
4) Enter 5x7 for height and width.
5) Enter the information you need in the data field, (ie, name address, etc.)
6) Select, Print.
7) When the 'Print Manager' box opens, click on, 'Properties'.
8) Click on, 'Type' and choose, "Envelope'.
9) Click on, 'Size' and choose 5x7. - and click, OK.
Your printer should have a slide where the paper is inserted. Place one of the 5x7 cards in the slot just as you would an envelope and slide the slider until it is 'close' to the card but not directly against the card.
Click, 'Print'. The printer should recognize the card (due to its thickness) as an envelope and print it.
Mar 19, 2011 | Office Equipment & Supplies
When I print pictures I have lines every inch on the picture. How do I correct this?
That is almost always print head alignment or dirty ink jets. Run the cleaning and alignment utility that is in the printer software. If that doesn't work make sure when you print pictures you change the print settings to the right kind of paper (photo) and the right print setting (photo)
Jan 27, 2011 | HP Officejet Pro 8500 Wireless All-In-One...
HP OfficeJet Pro 8500 A909 does not print wirelessly from my MacBook Pro with OS 10.6.2 (Snow Leopard). How can I get it to print wirelessly?
i cant print what happening. Its telling me to load paper but i have paper in slot. This started happening after a paper jam.
Jan 07, 2010 | HP Officejet Pro 8500 Wireless All-In-One...
I need to make copies of my little brothers highschool football pics to send into the coaches at colleges, i try to scan the image of a 5x7 to 4x6 photo paper but it ends up cutting the image in half...
The images need to be re-sized. It's important when re-sizing to keep aspect proportions since a 5x7 print is a vertical or portrait print and a 4x6 is a horizontal or landscape print. Therefore, when re-sizing if you check off keep aspect ratio, you may get either 4" tall or 6" wide but not both or you'll stretch the picture distorting it. Picasa by Google is a good and easy to use photo editing program that should suit your needs and is a free download. Picasa Best of luck with your project and please post back with any other questions.
Greg
Nov 08, 2009 | HP Officejet Pro L7590 All-in-One InkJet...
Have hp photosmart printer 7700 series problem loading 5x7 photo paper into printer
hi,
HP Officejet 5610 All-In-One InkJet Printer has few common problems. Such as Driver CD lost, Scanner does not work, Connection problem etc. For find all these software solution just click here....
http://www.hp.com/printer/prob676ijt65/solution
astrtr5
Aug 18, 2009 | HP Officejet 5610 All-In-One InkJet...
Cannot print 5x7 photo with i550 printer. What do
The i550 is capable of printing 5x7, the print software you are using may not be capable. The paper is loaded in the feeder lengthwise all the way to the right. If you are getting error codes, that's a different story.
Aug 13, 2009 | Office Equipment & Supplies
How to load 5x7 photo paper into hp photosmart D7460 ??
Mar 22, 2009 | HP Officejet 5610 All-In-One InkJet...
Printing 5X7 photos
try aligning and cleaning the cartridges
hope this helps
Apr 12, 2008 | HP Photosmart 2575 All-In-One InkJet...
Seeker5211
Seeker5211
