Question about Behringer B215D Powered Speaker (550 Watts 1x15 in)
Power Supply Board # PCB920090REVA/01
I need to purchase this item
  • Glenn Oliveira
    Glenn Oliveira Sep 18, 2017
    is the above PCB920090 REVA/01 purchaseable. I would like to buy one too!!
    Top Expert:
  • Behringer Master
  • 12,957 Answers
Did you try going to their web site? Did you Google it?
Posted on Sep 18, 2017
Power supply of soundcraft efx12
I assume you mean the wall wart power supply and not the actualy internal power supply in the board...either way check out Full Compass Pro Audio Video Lighting Equipment Largest Microphone Dealer... or better yet www.prosoundservice.com for your needs ..they can help you out... good luck http://www.prosoundservice.com/
Aug 26, 2014 | Soundcraft Efx12 - 12 Channel Sound Board...
I can`t load the OS in my KORG PA 80. No way to make it work. I think than the problem is the mother board.
Have you tried it with batteries? Are you sure the power supply is working correctly? It should not need the OS to operate as a keyboard disconnected from the computer.
The cable connection is just a MIDI cable that uses opto-isolators so the 2 items are electrically isolated from each other. The software driver for the Korg should load without problem. The Korg program itself may be looking for inputs that are not there when the keyboard is off and the program itself reaches a stop command.
If the PA80 will not work on just the power supply- the power supply can be the fault- it has an internal fuse. Finding a similar supply with the same coaxial plug wired the same polarity is the way to test it if the battery option is not available.
Mar 29, 2012 | Music
Where power supply goes into is broken and hanging out of deskcan this be replaced and where
you can take it to your local shop that you bought it from or contact Mackie and they might be able to do something for you
May 09, 2011 | Mackie ProFX12 Professional Compact Mixer
My Roland kc 550 will not power on.
if it does not power up, then it means its having a power problem. it might have worked fine in the past, but that's electronics for you. Power surge, irregular power supply, excess power supply, etc can affect the unit thereby not making it to power on.
This unit must have a power supply board in it where power enters from the mains. A capacitor, fuse, diode, etc may have been defective on the power board and maybe that's why its not making the unit turn on. There might also be some disconnection or something, inside the unit which is not making it to power on.
To actually find out what's wrong, you need to disassemble the unit with a screw driver and check what's wrong. You will be needing a meter in order to test the components on the power board, once you detect any bad component, you can make necessary replacement at any electronics accessories store withing our vicinity. This is the only way by which you can detect the problem.
Of course, testing the power board with a meter will require someone that has the ability. So it you can't, then you might be needing the help of a repairman or you can call a friend that has the ability to help you out.
I wish you the best of luck.
Take care........
Mar 21, 2011 | Roland KC550 Amp Keyboard
Am looking for a power supply board for yamaha keyboard
Normally if the board is there, I repair failed components. If the board is missing, call Yamaha America parts dept. They MAY have the part you need. That will be the only source of a complete replacement. Power supply boards are usually easily repaired.
Mar 04, 2011 | Yamaha PSR-295MS Portable 61-Key...
Korg 01WFD - Need service manual - power board burning smell - probably leaky capacitor. Thanks.
Go to this site:
http://elektrotanya.com/korg_keyboard-01_w-pro_prox_sm.pdf/download.html
Click on the round red dot nearthe top left of the page to download. This is the 01W document... it may not have the FD floppy but the power supply should all be the same.
Jan 19, 2011 | Korg Sound Card Disk O1w Fd 01wfd 01 W O1...
I need help on changing a fuse in PMP3000. The mixer went out on us one day, so I hooked it into an amp that we had. It works good as an unpowered mixer, but cannot get it to work as a powered mixer. I...
No, that is NOT what the problem is.
The fuse protects the power supply. The power amps have failed. The usual cause is an arc between layers of the multi-layer circuit board. The labor to repair the power amp module is extensive. I have repaired several.
You can find new amp modules and I would purchase a new one and drop into your unit. The amp module is an HCA2400.
There is probably $15 of parts blown in each side of the power amp and it takes about 6 hours to repair. One has to grind out the burned area (internal layers not necessarily visible on surface) and re-insulate and then install jumper wires to replace those taken out.
Each side of the amp will likely take out 3 switching MOSFET transistors and often a Zener diode. Sometimes a low resistance metering resistor will be fried with smoky residue underneath the board. When this happens two small surface mounted resistors will be blown open. Great care has to be taken when insulating the board damage and replacement of the blown circuit traces.
You can find HCA2400 power amp module replacements for about $175 online.
Use of the unit as an unpowered mixer is a bit dangerous as if arc re-establishes it can fry the power supply taking out two very expensive IGBT's and many other components. If the mixer still works, then your whole power supply is still OK.
Sep 09, 2010 | Behringer Pmp3000 16 Channel Audio Mixer
I have an Epiphone Blues Custom 30 amp. I have had it about 2 months - purchased used. I have probably played it about 10 hours total. This morning, I turned it on and it played for about one minute then...
There may be an internal fuse, but the unit will need to be serviced by an electronics shop.
If no odor or burning smell happened, then I suspect a bad solder joint or cracked circuit board. Look the board over with a very bright light.
LOOK for a dark circle around pins of HEAVEY components in the solder menicus for all the pins of the heavy components.
Look for board cracks with a small LED flashlight shined through the board.
Feb 28, 2010 | Epiphone Music
No power is coming through to my CTK 611, bought a new power unit and this has made no difference
There is a chance that the jack that the power supply plugs into is broken loose or has bad solder joints to the circuit board. I am hoping that you purchased a direct replacement for the power supply.
Oct 29, 2009 | Casio Ctk 496 Electronic Keyboard with 61...
I need the pin out details of a digitech rp6 guitar effects pedal
Try contacting the service center rep at (801)566-8800. They might send you a schematic for the pedal if you explain your situation. They do recommend using the original power supply which is PS0912.
May 25, 2009 | DIGITECH VOCALIST LIVE 2
Behringer B215D Powered Speaker (550 Watts 1x15 in) Logo
347 people viewed this question
Top Behringer Music Experts
Vito Vacirca Jr.
Matthew Spark
Matthew Spark
Ben Armstrong
Are you a Behringer Music Expert? Answer questions, earn points and help others
