Question about Mitsubishi WD-60735 Projection Television
I received a tv lamp module for mitsubishi 915b403001 top go into my mitsubishi DLP model wd-70735 .Everything hooks up but it dont come on the yellow light keeps flashing. Also the blub cover plate i
TV wont turn on. Replaced the old broken blub
  • 1153 Answers
SOURCE: Replaced lamp and now can't get a picture
Hi Sally Jo, Unit powers on and works properly for a while then shuts off with a red lamp LED (lamp error). Suspect bad lamp part # 915P020010 2. Lamp enable line at J14 pin 6 does not switch to 5 volts after turn on, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 3. At power on the lamp turns on and off three times and then the unit shuts down with a red lamp LED (lamp error). Replace the Light Engine part # 939P977010 4. Check for 12-volts DC at J-9 connector pin 4 on the Engine Driver PCB, if missing check for an open F9A09 on the Power PCB, if it is open replace F9A09 part # 283P127060 and the Light Engine part # 939P977010 5. Lamp enable line at connector J14 pin 6 on the Engine Driver PCB switches to 5 volts after turn on but does not go back to 0-volts (low) after 5 seconds, 12 and 5 volt supplies are good. Suspect the Light Engine part # 939P977010 6. Check for 5-volts DC at J-9 connector pin 1 and 2 on the Engine Driver PCB if missing replace the Power PCB part # 934C148001. Hope this helps!
Posted on Sep 18, 2007
  • 184 Answers
SOURCE: mitsubishi wd-62825 dlp
If the green front panel LED blinks continuously and the TV never comes on, its an issue with the "DM" board. When these TVs are first plugged in, the green LED should blink for 30 sec. to a minute or so. This is the TV booting up, reading its software. Mitsubishi has been having problems with this circuit for several years. In may cases the only permanent solution is to have the chassis rebuilt by Mitsubishi at considerable cost and inconvience. The chassis may have to be sent back to Mits for this rebuild. Call Mits and ask for help.
michtech
Posted on Feb 14, 2009
  • 58 Answers
SOURCE: Mitsubishi WD-52525 52-inch DLP HDTV ywllow warning lamp light
that means your lamp it is getting to the end of its life.
sometimes even if the lamp still good the TV will send you that message because that timer is closed to 5000 hours
What you can do is open the lamp door, closed again and the tv will ask you if you replaced it the lamp, and just say yes and that sign will go away
or just simple replace the lamp. 915P020010
Posted on Apr 18, 2009
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
Posted on Jul 16, 2009
SOURCE: I have a Mitsubishi WD 52628. I replaced the tv
try turning it on hold the menu button for eight seconds menu pops up try reseting the settings again as before you had the problem
Posted on Feb 10, 2010
Mitisbuski 73737 made popping sound and cut off
Check your lamp. The popping sound was most likely the arc tube exploding. Make sure you only install a real Philips or Osram lamp. WD73737 Mitsubishi Genuine High Quality Original Projector Lamps now...
These folks have good lamps.
Apr 28, 2015 | Mitsubishi WD-73827 73" HDTV DLP TV
Mitsubishi wd-73c9 status light blinking orange won't turn on
may need the lamp replaced pt# 915B403001
Recommend Phillips, OSRAM or Mitsubishi original (as from experience others will not work or will have very short life)
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73C9
Mar 08, 2015 | Mitsubishi WD-73C9 73" DLP TV
Put new lamp in 12hrs later red light was on lamp had black around it why
new lamp may have gone bad. was this the recommended lamp for the unit. Most Mitsubishi units must have the correct manufacturer recommended lamp installed.
The correct part# for this unit is 915B403001
You may find that lamp at the following web site:
http://www.shopjimmy.com/catalogsearch/result/?q=915b403001
Jan 31, 2015 | Mitsubishi WD-60C9 60" DLP HDTV
Why would a Mitsubishi WD-65735 Television turn on and have sound but no picture?
have you pulled the lamp out & checked it. It is possible you have gotten poor quality lamp. It is critical on a mitsubishi to get the proper lamp.
Lamp-Cartridge 915B403001
http://www.shopjimmy.com/mitsubishi-915b403001-dlp-replacement-lamp.htm
May 08, 2014 | Televison & Video
I have a blinking yellow status light on my mitsubishi 73837
blinking yellow indicates no lamp or the lamp door is open. if you had the back off you may have gotten the door switch aligned improperly. the door switch is located just inside the lamp door.
the lamp may also be bad.
lamp part# 915B403001
see website:
http://www.shopjimmy.com/dlplamps?tv_brands_select=Mitsubishi&tv_models=Mitsubishi+WD-73837
Apr 29, 2014 | Mitsubishi WD-73837 73 in. HDTV
I replaced the lamp for my Mitsubishi 915b403001 tv and the "lamp" light is still on
you need to reset the timer
I will tell you the way to reset the timer ,Pls let me know your Projector's Model
Have a good day!
We supply original projector parts: lamp, bulb, Lcd, Lens, DMD,
motherboard, powersupply ... with high quality and competitive price.
Jerry China
Tel: +86 131788 67858
E-mail: lampdeng@hotmail.com
Skype: lampdeng.com
YM: lampdeng@yahoo.com
http://facebook.com/lampdeng
http://www.lampdeng.com
Oct 12, 2013 | Mitsubishi 915b403001 Lamp For Wd-73735 /...
I see no picture
Televisions covered: Mitsubishi DLP High-Definition Televisions:
C Series: WD-60C8, WD-65C8, WD-73C8
735 Series: WD-60735, WD-65735, WD-73735
736 Series: WD-65736, WD-73736
835 Series: WD-65835, WD-73835
Here's an online version of your televison's (94 page) "Owner's Guide":
http://www.mitsubishi-tv.com/pdf/ownersguides/WD-60735.pdf
It sounds like the lamp in your "Mitsubishi Lamp-Cartridge" blew.
If your TV remains under warranty, you'll want to call Mitsubishi at 1-800-553-7278, and you'll need to have (a) Mitsubishi Model number, (b) serial number, (c) TV purchase date, and you'll have to ship the old lamp module back to Mitsubishi so that:
"All lamps replaced under warranty must be returned to Mitsubishi where they will be inspected for defect verification."
Return old Lamp-Cartridge to:
Mitsubishi Digital Electronics America
1001 Cherry Drive, Suite 2
Braselton, Georgia 30517
If you have trouble finding your TV's information, you need better "Warranty Management". Warranty Management can be done with software, or on paper. You may even choose to toss all your Owner's Manuals into a box, with the receipts. In case anything malfunctions/needs to be reprogrammed/reset then the manual & spare parts/cables (in a large Zip-Loc(R) baggie or two) can be quickly located and consulted.
If you television happens to be out of warranty, a nice (expensive) new lamp module can be ordered from Mitsubishi by calling 1-800-553-7278, or by ordering online at http://www.mitsuparts.com.
Refer to pages 75-76 of your Owner's Guide for complete Lamp-Cartridge module replacement instructions (with nice illustrations).
Your TV's Lamp-Cartridge part number is: Mitsubishi 915B403001
Here's an online source for the Mitsubishi 915B403001 Lamp-Cartridge:
http://www.dlplamps.com/products/mitsubishi-dlp-lamp/mitsubishi-915b403001.html?gclid=CLzb6ciaiq0CFQdN4AodZkMonA
Note that with the dlplamps.com offerings, you can purchase the lamp only for $109, or the entire lamp-cartridge module for $129. So you can save yourself $20 if you're handy. Remember to keep all fingerprints off the lamp glass element - this small amount of oil will weaken the glass, and cause premature failure of the lamp. In the event that you get a fingerprint on the lamp glass, erase it thoroughly with rubbing alcohol. Alternatively, one may prevent fingerprints with latex gloves (make sure you haven't an allergy to latex, though).
If the reason that the lamp blew turns out to have been a clogged Lamp-Cartridge Filter (once you have the Lamp-Cartridge out of the TV and in your hand, you'll be able to easily see the mesh filter), then place a regular PM (Preventative Maintenance) of this filter on your calendar.
Dec 17, 2011 | Mitsubishi WD-60735 Projection Television
When the tv goes out can you purchase just a bulb or do you need to buy the lamp
you can't buy just the bulb
http://www.discount-merchant.com/Mitsubishi-915B403001-Lamp-DLP-TV-lamp-p/mitsubishi-915b403001-lamp.htm?1=1&CartID=0
Jan 25, 2011 | Mitsubishi WD-65735 Television
New lamp replaced but yellow lamp light is flashing
Go to this Website they will list all Parts/boards and everything you need for this TV
WEBSITE:
Encompass Parts Distrubtion 1-800-638-3328
Jan 16, 2010 | Mitsubishi WD-52525 52" Rear Projection...
Mitsubishi WD-60735 Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
