Question about Elna Sewing Machines
Can you drop the feed dogs on elna 2004 - Elna Sewing Machines
  • 8 Answers
SOURCE: Dropping Feed dogs on kenmore model 19233
Remove extension table/accessory box by gentle pulling it away from machine. You are left with just the free arm. In the back of the free arm, lower left corner, you will fine the feed dog lever. Push the leaver to the right to lower the feed dog.Instructions for lowering and raising the feed dog are on page 48 of your owner's manual. Good luck!
Posted on Jan 01, 2008
  • 3 Answers
Pull out the removable table and you will see the drop down feed dogs switch lever behind the back of the machine. Move that lever to the left or right to have feed dogs go back to normal sewing mode OR for embroidery mode.
Posted on Mar 07, 2009
raycolinashb
SOURCE: janome mermory craft 8000 drop feed dog
I hate to sound dismissive but: read the manual. Duh. It is not as written above: drop dog........
The feed dog is the toothed pieces in the sewing machine deck, under the needle, which move the material away from you when you push the operating pedal.
Dropping the dog - ie making it inoperative - (see manual for how to on your machine) means the material has to be propelled by hand under the needle. This is especially good for freehand machine embroidery as it means you can move the material in any direction whilst sewing.
It can be easier to freehand embroider if your material is fixed in to an embroidery hoop to hold it flat while you work.
Posted on Apr 24, 2009
  • 13 Answers
SOURCE: How to Drop Feed Dogs on Sewing Machine...
On many machines you tilt the machine back on its hinges to see the underside and there you will find a thumbscrew to lower the feed dogs...you also need to be sure that your machine is capable of having its feed dogs lowered...not all machines can do this!
Posted on Aug 28, 2009
SOURCE: Feed dog lever not working on my Kenmore 385 24 stitch machine
I surfed around this site for various suggestions, finally took the bottom plate off and cleaned and oiled all the parts along that rod that goes right across (think it's a drive bar that rotates). Ran the machine without thread in for a few minutes to let the oil soak in. Machine now works fine.
Posted on Oct 07, 2009
Elna 5200Q The material is bunching up in front of the feed dogs
Are the feed dogs actually raising, moving, and dropping (raise the presser foot and hand-rotate the handwheel and watch how the feed dogs are moving)? If not, check to see if the stitch length is set well above the zero (which means it sews in place)? Perhaps the presser foot pressure is set too firm and is preventing the fabric from moving under the foot.
May 17, 2017 | Elna Sewing Machines
How Do I lower the feed teeth on my Elna 3003 machine for free sewing. Thank you.
This may help:
How to Drop the Feed Dogs on Elna Sewing Machines eHow
However, some machines do not have the ability to drop the feed dogs but instead has a plate that attaches to the machine to cover the feed dogs. Your manual is probably the best source for information.
Apr 11, 2017 | Elna Sewing Machines
I have an Elna 3210 and my feed dog won't raise anymore. How do I fix this?
When you drop the feed dogs they drop instantly. When you raise them it takes 1-2 stitches for them to com back up. Move the switch on the back to the up position and sew a couple of stitches.
Jun 07, 2014 | Elna 3210 Mechanical Sewing Machine
Can you drop the feed dogs with an Elna Grasshopper?
No the grasshopper has fixed feed dogs. There was a feed dog cover plate when the machine came out. This part is no longer available
Apr 06, 2014 | Elna 2007 Mechanical Sewing Machine
Need to drop the feed dogs on my elna carina sewing maching
The Carina came with a metal plate that you clip over the feed dogs onto the metal plate (rotary hook cover), they don't have the feed dog drop feature.
Sep 06, 2013 | Elna Sewing Machines
Elna Envision 8007 feed dogs dropped and can't get get them to go back up ...the switch doesn't make a difference. Had this problem before and thought it was fixed. This is the first time I needed to...
Have you actually starting stitching a seam after sliding the feed dog control back to normal position?
In most cases, the feed dogs don't magically pop up until the machine has moved through a stitch sequence.
Put a piece of fabric under the pressure foot, lower the pressure foot, then turn the flywheel towards you two or three turns or use the needle up, needle down control button to make a couple of stitches - this should get them back.
Apr 15, 2011 | Elna 8007
How do I raise the feed dog in my Elna 5000, a machine I recently inherited.
I have a 7000 manual and from memory the 7000 was released a year after the 5000 and very similar. Look at top middle image below, for feed dog release at back of the sewing free arm.
tally_girl_19.jpg At the back of the sewing free arm (remove the accessories tray) is a slide to lower the feed dogs, there is a little stub that you need to push to release it. Manual says "Drop the feed by pushing the slide (a), which is at the rear of the elevated sewing surface, to the left. To raise the feed dog again, press down the stud (b) and the feed dog will rise when you start sewing." You might need to wind the flywheel towards you half a turn to visually check they have come up.
Apr 12, 2011 | Elna Sewing Machines
Sewing Machine fault
Perhaps the manual would be helpful:
https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjv-KjEyNLXAhXDwFQKHZJtD4sQFggmMAA&url=https%3A%2F%2Ffiles.tv-sewingcenter.com%2F2015%2F04%2Felna-sew-fun-instruction-manual.pdf&usg=AOvVaw08q0vhbb6YSyyVVTwMCUKH
ELNA Sew Fun Instruction Manual
The feed dogs on your machine do not drop. Instead, the machine has a darning plate that covers the feed dogs (see the accessories listed in the manual). If the darning plate is installed properly, it should prevent the feed dogs from contacting the fabric.
Make sure the stitch length dial is set @ 2 or higher. This will insure the fabric will move as the machine stitches.
Nov 22, 2017 | Elna 2007 Mechanical Sewing Machine
Sewing Machines Logo
104 people viewed this question
Top Elna Sewing Machines Experts
Tally Girl
Tally Girl
Douglas Plant
Douglas Plant
Are you an Elna Sewing Machine Expert? Answer questions, earn points and help others
